02-06-2024, 09:13 PM | #1 |
The Seeker
14201
Rep 3,427
Anyone remove the metal/rubber from the dead-pedal?
Recently installed my Sullivan Racing pedals and I'm needing to add the dead pedal as well. Ideally it'd lay flat, but to make that happen I either need to shave the rubber down, or remove the metal, then the rubber, then replace the metal? Anyone done this?
02-09-2024, 10:34 AM | #2 |
1845
Rep 1,614
I think I answered this on fb already but yeah I just removed the plastic and bolted the dead pedal straight in. Much cleaner install than not. Been a few years and still looks perfect
///MPhatic14200.50 |
02-09-2024, 12:38 PM | #3 | |
The Seeker
14201
Rep 3,427
I think I've decided to just leave the main part in, but remove/replace the bright finisher with 1/8" abs plastic (to make it level since the rubber can't be removed), then another layer of abs plastic, then the dead pedal over that. This will allow me to undo the entire thing if I ever change my mind about it, having caused no damage to the original pedal. |
02-09-2024, 01:30 PM | #4 | |
1845
Rep 1,614
