03-06-2024, 08:29 PM | #1 |
105
Rep 91
Hello, any one running the M2cs Racing DCT Pan? If so, what are your thoughts on the pan.
Install write up DCT Pan Link |
03-08-2024, 07:41 AM | #3 |
2840
Rep 3,715
I’m running the M2 CSR pan for the track instead of a larger DCT cooler. Works great, and I’m tuned a decent bit higher than a stock CS.
More info in the later pages of this thread: https://www.m3post.com/forums/showthread.php?t=1751905 |
2020_M2CS105.00 |
03-08-2024, 11:56 AM | #4 |
105
Rep 91
Looking at cost, might make sense to go with the fall line pan given it has a better seal and has decent ground clearance. Im considering transmission/filter service so was looking at different options than the plastic pans. Cost up front is expensive but do two tans services. And you come close to brake even.
03-08-2024, 12:41 PM | #5 | |
2840
Rep 3,715
I believe the Fall Line sits lower than the M2 CSR pan? I can’t remember. Altho, I do know the stock under tray can still be fitted with the CSR pan. You can get the pan gasket from BimmerWorld pretty cheap and the bolts are only $50-60. So, the CSR pan setup is ~$800 all in when I did mine in 2022 (got my pan from Rahal BMW). How much is the Fall Line setup? |
