09-30-2023, 04:11 PM | #1 |
139
Rep 562
I did preventative maintenance by changing fluid at 150,000km and now I have slipping when hot and high torque/low-rpm. Second fluid service, first was done at half mileage by warranty but without changing filters. This time I took out the gross filters.
I do track the car, and I used to run gts tune ages ago. I did full recalibration in ISTA and paid dealer to inspect everything. Currently I’m running fluid dealership sells. No issues at high rpm and no issues until engine hot. Thanks! |
10-03-2023, 02:47 AM | #2 | |
1430
Rep 3,008
Sounds like the clutch packs need replacing.
INSTAGRAM: GORDON.M3
North American Mr12Volt Carplay/Android Auto Distributor DINAN | EVOSPORT | VAC | ARP | RD SPORT | NEEZ | EIBACH | CSF | IND | BILSTEIN | KLASSEN | BREMBO | ENDLESS | BBS | BPM SPORT | PROJECT MU | EVENTURI |
12-03-2023, 10:15 AM | #3 |
44
Rep 50
Did you only start to notice the issue after the fluid was changed? If so, are you certain the BMW procedure was followed to ensure all of the needed fluid was added? It is easy to miss as it is not intuitive. Even YouTube pros not familiar with BMW miss it as seen in this recent Speed Academy video here.
Check out this thread here for the fluid topping off procedure if you aren't familiar with it. |
12-03-2023, 05:25 PM | #5 |
139
Rep 562
Thanks guys, yes it started on refill even though I insisted the Indy shop do the ista procedure while filling. But I think they didn’t do it properly as I was watching it and they didn’t know what they were doing. I ended up paying BMW a lot of money to top up the fluid and do the procedure, they said clutches are toast. Then I kept driving and now the issue is gone. Honestly I think good help is hard to find with these DCTs.
///M Power-Belgium64536.00 |
12-03-2023, 06:34 PM | #6 | |
64536
Rep 24,941
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
12-16-2023, 08:49 AM | #8 | |
139
Rep 562
12-17-2023, 07:37 PM | #9 | |
2440
Rep 5,906
FYI, Redline DCT fluid is also an exceptional option with the same or better performance than BMW/Pentosin DCT fluid |
The-Traveler139.00 |
