01-20-2020, 03:45 PM | #1 |
29
Rep 41
A/C touch panel cracking
Hi everyone, yesterday I noticed two cracks on my A/C panel. I did not ever hit or even scratch the panel as I use very soft microfibre to clean it. The cracks just showed after a year of using the car. Anyone had the same problem before?
Today I just set up a visit in the dealership this friday and will ask them to do it under warranty. Hope that they will not scratch the interior when replacing this panel, as probably it is not easy to remove it. |
01-20-2020, 03:56 PM | #2 |
What goes here?
450
Rep 1,356
Drives: 2019 G30 M550i
Garage List 2019 BMW M550i [0.00]
2021 BMW M3 Competi ... [0.00] 2019 BMW M5 Competi ... [0.00] 2016 BMW M3 [0.00] 2014 BMW M235i [0.00] |
I have two lines down the middle of my climate control unit too! I took it in and they agreed it should be replaced but I held off on the repair due to expected invasive replacement.
The cracks showed up less then one month into ownership.
2019 G30 M550i
GBNF: 2021 G80 M3, 2019 F90 M5 Competition, 2016 F80 M3, 2014 F22 M235i |
01-20-2020, 04:07 PM | #4 |
29
Rep 63
If I remember correctly, this has happened a lot with people who own a 7 series. Lines down the touch screen. If I recall correctly, they were replaced under warranty, but some of the new units had the problem reoccur. If you search the forums for the 7 series, you'll likely find more info on it.
Longing for the old days of fewer fragile electronics ..... |
01-20-2020, 05:47 PM | #5 | |
What goes here?
450
Rep 1,356
I went out and took this picture to show and in the picture smaller lines up towards the top show up (kind of like yours) but they are not visible when just looking at it.. must be something with my phones camera exposure in night mode.
2019 G30 M550i
01-20-2020, 06:17 PM | #7 | |
407
Rep 2,704
Mine are red with red lines. Just another food for thought. |
01-20-2020, 06:32 PM | #8 |
197
Rep 572
01-20-2020, 09:35 PM | #10 |
29
Rep 63
Another thread from the G30 forum:
https://g30.bimmerpost.com/forums/sh....php?t=1558489 And from the G11 (7 series) forum: https://www.7post.com/forums/showthr...t=touch+screen |
01-21-2020, 01:24 AM | #11 |
29
Rep 41
Replacing the panel is actuall not as complicated as I thought -
As the problem is so popular I hope that they improved the construction of the panel and after the replacement it will not crack again. |
01-21-2020, 03:48 AM | #12 |
153
Rep 130
Cześć
Struggling with the same issue and unfortunately I don't have good news. While my dealership happily replaced the panel, three months later I was back to square one, with new cracks starting to appear. I'm currently on my third panel, which also started to crack after a while. At this point I just stopped caring and saved myself the hassle of going to the dealership and getting it replaced. I think it's only a matter of time before it would crack again anyway, so why bother. Pretty bummed about it, so I just try not to look in that general direction. |
01-21-2020, 11:10 AM | #13 |
29
Rep 41
Cześć
I have bought extended warranty. If it is your third panel the question is how many panels they will replace in 5 years for me It would be cheaper for BMW to improve the panel construction, as probably it is the matter of used to soft glass or something like this. Even the cheapest smartfones screens do not crack like this. Interesting thing is that in new X5, X6 and 3 and 8 series they resigned from A/C touch pannels. Maybe that was one of the reasons. |
01-21-2020, 11:48 AM | #14 |
153
Rep 130
I'm not entirely convinced it's the panel itself that's at fault here.
I've been told by my service assistant that they've repeatedly replaced the panel in certain cars. I would assume that if it indeed was the panel's poor quality at fault, BMW's QA department would pick up the slack and introduce a more durable alternative. My wild guess is that's an assembly issue, perhaps of the fixture or something surrounding the panel that impacts, perhaps by inducing vibrations? No idea, but it seems odd to me, that you either don't get that issue at all, or struggle with it repeatedly. |
DNGRTOM122.50 |
01-21-2020, 12:08 PM | #15 |
29
Rep 41
Yes however inducing vibrations may be also caused by the surface that you are driving on. Maybe this certain cars are used on a worse quality roads than those without a problem . The day when I have noticed the crack I was passing some pretty high speed bumps and it was below zero celcius. But still it is normal use of the car in the city, not any extreme - I was driving maybe 20 km/h. I think that it is a problem with the panel - they could make it resistant with some material which will absorb vibrations. There are no such problems with smartfones which you treat less gentle - they fall from your pocket to the pavement and in many cases survive
02-19-2022, 04:12 PM | #17 |
160
Rep 253
Drives: M5 / X5
Just noticed mine is as well. It only shows up with the red backlight right now, but it will get worse. Hopefully it will be replaced under warranty with something that won't crack.
02-20-2022, 10:11 PM | #18 |
39
Rep 46
Has BMW acknowledged this as a construction fault or is it an out of pocket repair if out of warranty?
Incredible that this sort of poor quality/design makes it to production. |
02-25-2022, 11:12 PM | #19 |
Rep 7
Does anyone have a part number for the unit? I can find plenty of used ones for sale for around $200, not very expensive and I'm curious to know what a new one would cost. Would also like to know if the issue has been addressed at all, if it'll just happen again then I'll just consider it a feature of the car.
02-26-2022, 02:06 PM | #20 |
180
Rep 659
Drives: '22 M5CS, '00 M5, '06 Z4M
Garage List 2022 M5CS [0.00]
2001 BMW 740i [0.00] 2006 BMW M Roadster [0.00] 2012 BMW X6 3.5i [0.00] 2006 BMW 325xi [0.00] 2017 BMW 540xi [0.00] 2000 BMW M5 [0.00] 2001 BMW X5 4.4i [0.00] |
New one is north of $1500 I believe
'22 M5CS, '06 Z4M, '01 X5 4.4i, '00 M5, '05 Acura RL, '12 X6 3.5, '01 740, 08 335xi, '17 540xi (yes they all are still with me)
11-17-2022, 10:36 PM | #22 |
ID10T Specialist
90
Rep 269
Drives: F90 | F97
Garage List 2019 BMW M5 (f90) b ... [9.92]
2021 (F97) BMW X3mc [10.00] 2017 Toyota Land Cr ... [9.50] 2000 Toyota Land Cr ... [0.00] |
My hvac screen was replaced today - under warranty. Maybe i'll get lucky and be done.The next one is one me $$$ BMW warranty ends 12/2.
2019 m5 Base Unknown mileage when occurred first noticed at about 24k miles replaced 27,000 mi (warranty) Last edited by RobRed; 03-03-2023 at 02:29 PM.. Reason: added photo and relevant mileage |
