06-30-2016, 11:56 AM | #265 |
10513
Rep 41,031
Drives: 2018 Alpina B6 650ix GC
PM sent.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
07-07-2016, 01:57 AM | #267 |
10513
Rep 41,031
PM sent.
07-07-2016, 04:24 PM | #269 |
10513
Rep 41,031
07-15-2016, 05:03 PM | #270 |
Rep 14
CEL
Can someone read this results file (or point me in the right direction so I can read it myself) from Tool32 and tell me what the CEL is on for?
I had to remove the 2TB a few weeks ago so the dealership could update my car for a AC freezing issue. The update went fine and removed all of the other coding, but now my CEL is coming on. I used esys to remove it about a week ago, but it came back the same day. I just don't want to recode it if I have to take it back to the dealership so soon. Thanks!!!! |
08-06-2016, 02:57 PM | #272 |
10513
Rep 41,031
PM sent.
08-13-2016, 06:22 PM | #274 |
10513
Rep 41,031
You cannot send or receive PM's yet. Send me one when you can.
08-13-2016, 06:39 PM | #275 |
63
Rep 178
Ahh thanks. SHAWN. is there a way to use esys to read the code and figure out what the problem is? I followed your instructions to clear it using external apps and transmit. I see theres an option to read codes but don't understand what comes up when I connect and send.
08-13-2016, 06:40 PM | #276 | |
10513
Rep 41,031
stroker1562.50 |
08-15-2016, 08:43 AM | #278 |
Rep 11
FWIW, I got ISTA/D (BMW NEXT ISTA/D 3.48.20 + ISTA/P 55.0.300).. what a huge difference and I recommend most people jump right to ISTA if they are troubleshooting, it not only gave me the fault codes in a nice tree diagram for each ecu, but it took me right into the problem, calculated a test plan with linked trouble shooting images and wiring schematics. Traced it back to a loose harness and blown fuse a few minutes later. The tests are all labelled in english and you can toggle indicator lights, switches, read off sensor values real-time, etc. After software like e-sys and tool32, I didn't expect BMW had something almost apple-like to use
Only thing is the installation takes over an hour with over 20+ steps, but it was definitely worth it. |
stroker1562.50 |
08-17-2016, 03:32 PM | #280 |
10513
Rep 41,031
PM sent.
Blacktan49.00 |
08-18-2016, 07:09 AM | #281 | |
233
Rep 241
Drives: '19 330i xDrive M Sport
1. Shawn I owe you 2. Any idea if I messed up any thing else or re wrote something I wasn't ?
Current: MY2019 330i xDrive M-Sport w/Lasers - Portimao Blue
Previous: MY2013 328i xDrive Sport Line - Sapphire Black | MY2016 428i xDrive M-Sport - Mineral Grey BMW CCA #522637 use me as a referral for BMW CCA |
08-24-2016, 09:20 AM | #282 | |
63
Rep 178
update on check engine light.
Turns out it was the thermostat that failed, and I know there's another thread for that common issue. Went to BMW they scanned my key and told me there is no recall or service bulletin for the thermostat, but they replaced it under my extended warranty. My gas mileage has improved and the car runs better now. Good thing I had it checked because my temp gauge was showing normal temp, but the thermostat was sending a false signal, who knows what temp the engine was really running at. I gained about 5 to 8 mpg after having the thermostat replaced. |
08-24-2016, 10:05 AM | #283 |
10513
Rep 41,031
Car is fine now. Back to normal. No concern.
08-25-2016, 06:02 PM | #284 |
233
Rep 241
Thanks boss
09-01-2016, 02:05 PM | #285 |
Rep 1
Hi Shawn,
Could you pm me the EDIABAS / E-Sys / Tool32? I would like to know which program is better to correct the airbag, ABS and so one error after the accident - ISTA/D (Rheingold) or IMPA? Which version is best for F31 2016 rheingold 3.52.32 or 3.42.10 Thanks a lot |
09-01-2016, 02:16 PM | #286 | |
10513
Rep 41,031
