05-04-2020, 10:12 AM | #1 |
109
Rep 411
I'm thinking of ways to drop weight
Questions 1. Does anyone know what the lightest aftermarket exhaust system is that is available? Cat back ? Looking for largest weight reduction 2. Ceramic brakes? Anyone aware of a non-OEM (or cheaper option than OEM) to reduce the brake weight. I don't have the ceramics, and was thinking I could switch to cut pounds 3. Wheel options? What do the OEM wheels weigh and any recommendations for some of the lightest wheel weight options ? Just curious 4. Other ways to shed pounds (without removing seats)? Any ideas ? |
05-04-2020, 10:50 AM | #2 | |
383
Rep 161
05-05-2020, 01:18 PM | #4 | |
275
Rep 526
Realistically, the M5 is a 4300 lb car give or take depending on spec. To really make a difference, you’d prob need wheels, ceramics, removing the rear seat, replacing the front seats with light carbon buckets (both of which you don’t want to do) and there you might end up around 4000 lbs. In doing all that, you’ve not only completely done away with the purpose of the M5, but likely spent 30-40k in the process which could have been used for a car (or significant portion of one) that could out of the box be a really good weapon for handling and speed - something like a 911 turbo or AMG GTR. Last edited by Funf6cyl; 05-05-2020 at 01:23 PM.. |
VeNoM__M5383.00 |
05-05-2020, 01:26 PM | #5 | |
19701
Rep 10,224
706F- 35.3 lbs 706R -36.4 lbs 789F- 28 lbs 789R- 29.5 lbs Check here https://f90.bimmerpost.com/forums/sh...ght=789+weight
2024 BMW M3 CS Frozen Solid White
2023 BMW M8 Coupe Competition Alpine White 2022 Porsche Carrera GTS Coupe Shark Blue 2020 Audi R8 V10 Performance Suzuka Gray 2012 Mercedes Benz C63 AMG Black Series Obsidian Black |
05-05-2020, 02:42 PM | #6 |
109
Rep 411
Glad I have the 789s
How much lighted do you think an here wheel is? |
r33_RGSport13059.00 |
05-05-2020, 02:48 PM | #7 | |
19701
Rep 10,224
But you can get HRE's sub 20 lbs (proper widths) for all the payola!!
05-06-2020, 09:33 AM | #8 |
13059
Rep 18,765
They can engineer it for you.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
05-06-2020, 11:21 AM | #10 | |
3619
Rep 4,532
05-08-2020, 09:22 AM | #12 |
240
Rep 978
You could just keep 5 gallons of fuel and fuel up to this point every day. Weight of the fuel is quite a bit of weight.
2021 M340i
2020 X3 M40i - her car 2019 M5, AW, DP's, MSR CAI, BM3, SOLD 2020 Chev. ZR2 Bison truck, Daily Driver |
05-08-2020, 02:19 PM | #15 |
240
Rep 978
Why don't you try the opposite. A lot power sure makes your M feel much lighter.
2021 M340i
05-09-2020, 09:31 PM | #17 |
3323
Rep 8,083
05-18-2020, 01:44 PM | #18 |
85
Rep 182
340 xdrive 6MT - HJS catted DP - MPPSK - TU HPFP - 550i clutch - VAC monoball control arms - Eibach springs - H&R antiroll bars - AutoSolutions SSK - Brembo HP2000 pads
Corvette C6 Z06 Z07 |
