07-02-2006, 01:24 PM | #1 |
Guest
Rep n/a
Drives:
This is cool, I wonder how it works?
07-02-2006, 03:01 PM | #2 |
***** noob
1375
Rep 10,479
Drives: 325xi>M235i>428GCx Mspor
simple...the math will always = to multiples of 9 (notice all multi-9 symbols are the same)
comon now.....this is elementary school stuff
2006 325xi (Sold)
2014 M235I (Current) 2015 428xi Gran Coupe (STB) Last edited by ska///235i; 07-02-2006 at 08:55 PM.. |
07-03-2006, 11:38 AM | #3 |
Myrmidon
17
Rep 236
Drives: Entwicklung 90 - 325 Xi
The algorithm is missing something. I ran it a few times and got the wrong symbol 3/4 times. Most of these "games" work on one of two principles. Either you do things to your original number that cancels itself out and you end up with the same thing, or you do things to your number which render your original choice insignificant, and so the answer is always the same.
Many of the algorithma use concepts like those in calculus that have to do with limits. Your original choice ends up being insignificant because of the magnitude of other manipulations. Others simply ignore lower order digits. eg. Choose a one digit number, multiply it by 1000, add the age of your cat, now add your age when you could first talk. Now Multiply the whole thing by two. Add the number of gallons of gas currently in your e90's tank. (IMPORTANT--> Round down!) Take the first three digits of your new number, and divide it by 20. OMG you got your original number. |
07-03-2006, 07:08 PM | #8 | |
***** noob
1375
Rep 10,479
nah...maybe I'm just a Nerd on math
2006 325xi (Sold)
2014 M235I (Current) 2015 428xi Gran Coupe (STB) |
07-03-2006, 08:12 PM | #9 |
Commander in Chief
37
Rep 1,034
The whole time I was thinking... "This is stupid, I wonder why it DOESN'T work?"
After the third wrong response, I even tried putting my mouse pointer over the correct number (and symbol) and it still got it wrong!
2008 BMW 535i Space Gray, Black Leather, Dark Bamboo Trim| Sport Automatic with Paddles | Sport Package
2008 BMW M5 (gone, but not forgotten) Space Gray, Silverstone Merino Leather, Madeira Walnut Wood Trim | 7speed SMG | All options Mods: Corsa Exhaust | RPI Ram Air Intake | H&R Sport Springs | Rogue Engineering 12mm spacers |
07-03-2006, 08:56 PM | #10 | |
3580
Rep 9,788
07-03-2006, 09:51 PM | #11 |
Commander in Chief
37
Rep 1,034
Aww man I'm stupid, I just re-read the instructions. I was taking the 2 digit number, subtracting the sum of the 2 digits, then subtracting 10 (I was combining the real instructions with the example instructions into one final set of WRONG instructions).
Yeah, the answer will always be a multiple of 9 and each of these will have the same symbol. Each time you do the trick, the symbol for the multiples of 9 will change to make it seem as if some sort of mind reading trick is happening.
