      05-07-2009, 10:40 AM   #67
arok
46
Drives: BMW F30 335i M-Sport
^ lower your car and it will be SOOO sick.
2013 BMW 335i M-Sport
      05-07-2009, 01:46 PM   #68
Justabanana
Justabanana's Avatar
Finland
Drives: 123d ///M-Sport
Wheels: Dotz Mugello
Front: 18x8" (can't remember offset...)
Spacer: none
Rear: 18x9" offset 35
Spacer: none
Tires:
Front Bridgestone Potenza RE050 225/40
Rear Bridgestone Potenza RE050 225/40
Suspension/Fender Mods/Camber:
none
Notes:
Tried with 255's at back and they rubbed. Heard even 245's rub with these rims so I changed to 225's at back too. Result: much less noise, and ride feels great now. Very agile and neutral handling, I can recommend all 225 setup except maybe for the 135i which might smoke them .
Lookswise I like the form of the spokes a lot but the chrome/black contrast is a bit too harsh for my liking (can't see it well from the pic but the inside of the rim and the sides of the spokes are black) ... maybe paint the center with body color and leave the lip shiny. Any suggestions?
Also, the BMW-centercaps make a huge difference I think
123d ///M-Sport Coupé (& e21 318)
Alpine White: Because originality is overrated.
      05-16-2009, 05:24 PM   #69
YvetteJ
Drives: Jet e82
keep them coming
      05-19-2009, 09:33 PM   #70
MrRoboto
1848
Drives: VO 1M
So what's the consensus for slight size upgrade using stock 18s.
Front: 225/40/18
Rear: 255/35/18
      05-21-2009, 07:21 PM   #71
spernesn
Drives: E87 118d 3door
PROJEC1. Wich ET do you have on your VMR V710 wheels?
      05-26-2009, 06:32 PM   #72
trboboost91
20
Drives: 07 e90
Front: 225/40/18
Rear: 255/35/18
consensus is that it works.
DO IT!
      05-27-2009, 03:45 AM   #73
Olivier_TFE
sport pilot
Spain
Drives: BMW 135i Alpine White
Hi,
I just mounted OZ in my 135i:
Wheels: OZ Ultraleggera
Front: 18x8 +40
Spacer: none
Rear: 18x9 +40
Spacer: none
Tires:
Front Bridgestone Potenza RE-11 225/40 R18
Rear Bridgestone Potenza RE-11 255/35 R18
Suspension:
- Bilstein PSS10 kit + sway bar rear H&R 20mm
- Camber plates Vorshlag: 2 deg neg camber front and rear
Without modify the fender, rubbed too much rear. It's Ok front.
I have to modify rear fender...
      06-01-2009, 10:37 PM   #74
amigo
Drives: 135i AW,Coral red,Msport,09
OZ Alleggerita
Here is a link to photos of OZ Alleggerita, Anthracite on AW 135i
http://picasaweb.google.co.uk/blairp...64528201009058
All 4 corners the same. 17" x 8.5" ET 40, Nitto NT01 235/40/17
I am going to the Track Thursday. Hoping this will get rid of the EVIL, PUSH.
      06-03-2009, 12:45 PM   #75
scorcherjf
scorcherjf's Avatar
29
Drives: 2008 135i
2008 135i  [0.00]
Front: 18x8 +40
Spacer: none
Rear: 18x9 +40
Spacer: none
Tires:
Front: Michelin Pilot Sport PS2 225/40/18
Rear: Michelin Pilot Sport PS2 255/35/18
Car is running KW Variant 3's at the lowest setting in the rears, almost lowest setting at front (level on the street)
Had the rear fenders rolled a little when I got the wheels put on, no rolling on the front
Notes:
Rears rub on medium to large bumps at speed, also while in sweeping corners at high speed the rears rub. I can get the fronts to rub a tad if I brake hard while turning (stupid idea but I did it to test).
Going to try raising my KW's a little. If that doesn't stop the rubbing, I'm going to have to roll the rears out more, and roll the fronts as well.
      06-03-2009, 12:47 PM   #76
yandy
yandy's Avatar
Drives: 2009 e92 MR "Civic" ///M3
2009 BMW M3  [0.00]
Front: 18x8 +40
Spacer: none
Rear: 18x9 +40
Spacer: none
Tires:
Notes:
SICK!!! gotta check this out in person... congrats! looks awesome
|| DCT | ESS Tune | ACM Test-pipes | AA Green Filter | Swift Spec-R Springs | Stoptech ST-40 F || || My Youtube Channel ||
      06-18-2009, 12:40 AM   #77
amsfoto
photographer
amsfoto's Avatar
Ireland
57
Drives: AW e92 335i, JB 135i
Wheels: Work VS-XX
Front: 19x8 +38
Spacer: none
Rear: 19x9 +36
Spacer: none
Tires:
Front: Toyo Proxes T1R 225/40/19
Rear: Toyo Proxes T1R 245/35/19
KW V2, rolled and shaved rears....LOTS OF WORK, I don't recommend going with this aggressive of a rear unless you are willing to do lots of work and still rub. I'm running about 2.5 degrees of camber on the rears...
Notes:
Still rubs in the rear over certain bumps, fronts rub slightly because of height.
Jet Black 135i Coupe - 19" Work VS-XX - KW V2 - BMW Performance - Riss Racing - Burger Motorsports - Active Autowerke - 3DDesign
      06-18-2009, 12:48 AM   #78
e82vette
Drives: 128i
^ best loooking wheels on 1 so far IMO
      06-18-2009, 01:44 AM   #79
ALLMuRdErEdOut
Wanna Get MURDERED???
Drives: BMW E82 M1
bravobravobravobravo
So crisp n so cleannnnnnn
Originally Posted by uwannago View Post
Wheels: DPE S20
Front 19x8.5
Rear 19x9.5
Tires: Toyo T1R 235/265
Suspension: KW V2
Fenders rolled
No rubbing
      06-19-2009, 08:05 PM   #80
sonnenjunge
Germany
Drives: M135i
Wheels: O.Z. Ultraleggera
Front: 19x8,5 +40
Rear: 19x8,% +40
Tires: Michelin PS2 225/35 19
Suspension: Bilstein PSS9
      06-19-2009, 08:07 PM   #81
sonnenjunge
Germany
Drives: M135i
      06-21-2009, 08:33 AM   #82
onehungevo
64
Drives:
Originally Posted by sonnenjunge View Post
Looks good but do they rub and did you roll the fender
      06-21-2009, 07:19 PM   #83
sonnenjunge
Germany
Drives: M135i
Slight rubbing in front over hard bumps.
fender is oem.
      06-26-2009, 10:54 PM   #84
Justin(OKC)
Justin(OKC)'s Avatar
Drives: 1988 M3, 1990 M3, 1998 M3/4
1998 BMW M3/4  [10.00]
2011 BMW M3 Sedan  [9.28]
1988 BMW M3  [9.40]
1990 BMW M3  [10.00]
2008 BMW 135i - sold  [0.00]
2003 BMW M3 - sold  [0.00]
Forgeline ZX3P wheels (white outer lip, satin black center)
-19x8.5 +45mm offset - 225/35/19 Goodyear F1 Asymmetric
-19x9.5 +50mm offset - 255/30/19 Goodyear F1 Asymmetric
Stock springs --- no rubbing anywhere. I'll update when I get the suspension on, but I'm crossing my fingers that I won't have to roll the fenders. I should note that these offsets are a bit different than what is on Turner's 128i.
1988 BMW M3 - Hennarot/Black
1990 BMW M3 racecar - Diamond Schwarz/Black
1998 BMW M3 - Alpine White/Mulberry
2011 BMW 328i racecar - LeMans Blue/Black
      06-26-2009, 11:04 PM   #85
Eyeman
Eyeman's Avatar
122
Drives: 2008 135 blk, blk, step
Nice Justin! I'm pretty sure you'll have to do a little fender work if you lower, even with good offsets like that, but maybe I'll be wrong.
      07-02-2009, 01:50 AM   #86
Motorsports_3
E30 Addict
Drives: 2008 135, 1988 325
His fronts should be fine, but I agree with you. I imagine the rear would need a bit of work. et+55 would of been awesome
      07-04-2009, 07:19 AM   #87
135iPSU
Enthusiast
11
Drives:
2008 135i  [0.00]
Wheels: BMW 18" Performance
Front: 18 x 7.5
Spacer: none
Rear: 18 x 8.5
Spacer: none
Tires: Bridgestone RE-11
Front: 225/40/18
Rear 255/35/18
Stock
Notes:
No Rubbing
Titanium Silver, Coral Red, Aluminum
      07-06-2009, 10:33 AM   #88
WonWunONE
UMADBRO?
WonWunONE's Avatar
11
Drives: AW 135i
Front: 18 x 7.5
Spacer: none
Rear: 18 x 8.5
Spacer: none
Front: 225/40/18
Rear 255/35/18
Stock
Notes:
No Rubbing
Post pics
