09-20-2021, 03:27 PM | #133 | |
87
Rep 315
2020 BMW m5 with some bmc filters, charcoal filter delete, and Dinan turbo inlets.
Previous BMW model 2018 bmw 340i FBO custom e50 tune 500 wheel |
09-20-2021, 04:38 PM | #134 |
87
Rep 315
for the bm3 off the shelf map can you use e30 stage 1 without replacing the stock downpipes no primary or secondary just the stock ones or even on stage 1 you have to ?
09-20-2021, 04:39 PM | #135 | |
257
Rep 764
Stage 1 91 octane: up to 11%HP / 18%TQ Stage 1 93 octane: up to 13%HP / 19%TQ Stage 1 E30 octane: up to 19%HP / 26%TQ Stage 2 91 octane: up to 15%HP / 22%TQ Stage 2 93 octane: up to 18%HP / 24%TQ Stage 2 E30 octane: up to 24%HP / 34%TQ |
09-20-2021, 05:11 PM | #136 |
87
Rep 315
i was talking to a custom tuner he was saying don't get e30 stage 1 and advised me to replace all 4 downpipes and e30 pushes a lot of boost so I don't know
09-20-2021, 05:15 PM | #137 |
257
Rep 764
Not sure honestly, though its been done many times over before. Its said the stock DP's quality of cores are strong and can take a lot of abuse. But most likely better for the engine to breathe especially on more timing/boost/ethanol etc.. For what its worth I'm a little nervous to run the E30 stage 2 lol
09-20-2021, 05:22 PM | #138 | |
87
Rep 315
09-20-2021, 06:07 PM | #140 |
87
Rep 315
e30 stage 1 without downpipes?
09-20-2021, 06:44 PM | #142 |
87
Rep 315
if its similar to stage 2 93 that is pretty impressive
09-20-2021, 08:01 PM | #143 |
71
Rep 185
Drives: 2022 X6M
Sooo, did some detective work, comparing logs, here is my pull on Stage 2 93 Octane of OTS.
Looks like your car is shifting a little sooner than mine, also for ignition timing mines goes into negative value, im not sure if thats bad... any Log experts? https://www.bootmod3.net/log?id=6149...0b4355c23116aa |
09-20-2021, 08:05 PM | #144 |
257
Rep 764
Thank you for sharing, starting to look at it now. Its nice to see that mine isn't the only one that has different ignition timing 1-4 values which seemed odd to me.
Looking at them between one another you are correct mine is shifting earlier, when in auto its like 7200 which I hate. I'd write xHP on this, also drop this info in the xHP thread. I'm all for keeping information in the correct thread even though this is the some tuning thread, it may be xHP tune related? Also mine goes negative to when shifting. I laid out the difference between them, seems mine is smoother. How many miles on your car? If anything I'm wondering why my actual boost in the upper gears are lower then higher, might be the norm not sure. Last edited by brad65ford; 09-20-2021 at 08:38 PM.. |
09-20-2021, 10:50 PM | #145 | |
213
Rep 548
Your timing is decent around 13-15 degrees, boost 21-22, seems like a conservative tune for 93 octane. |
09-20-2021, 11:30 PM | #146 | |
71
Rep 185
Drives: 2022 X6M
09-21-2021, 12:03 AM | #147 | |
213
Rep 548
09-21-2021, 06:28 AM | #148 |
257
Rep 764
Hence the reason I posted that plug thread and the plug condition at 18k . Nuts how bad mine were. I’d do them soon before doing any more dragy runs. Crazy if it smooths all those peaks out. If and when you do plugs, please post pictures of them on that page, would like to see others change there too especially at that mileage or sooner.
09-21-2021, 09:52 AM | #149 |
5269
Rep 10,664
When I changed plugs on my 18 with 30k miles a couple of weeks ago, I noticed that several plugs were loose - barely hand tight. I think I read of one other person finding a loose plug. Not sure how loose they have to be before the cylinder loses pressure.
09-21-2021, 01:13 PM | #151 |
5269
Rep 10,664
I tossed them already. But they looked like yours. I did check gap on a few and they had opened up from 0.026 to 0.027-0.028. Yours looked OK to me — color was good, a little crusty but that sound clean up with a wire brush, they were firing fine since the car was performing well, and the gap had not opened up. I doubt they were causing any trouble but I do agree with closing the gap a bit on the new plugs and using a colder plug if adding boost. I went to 0.022 and 2 step colder with no noticeable side effects such as poor idle. My car has only JB4, carbon filter delete and 70/30 meth/water controlled by the JB4 with 93 pump. Need to take the time to log and dragy but have not yet.
DrivenAgain120.00 |
09-21-2021, 01:30 PM | #152 | |
213
Rep 548
09-22-2021, 05:38 PM | #153 |
257
Rep 764
Anyone attempt to alter there burbles with the BM3 software? Recently removed all burbles after doing DP's since it was just to nasty imho. Anyway going to attempt to add some subtle ones in. Not sure if there is a happy in-between.
09-22-2021, 07:21 PM | #154 |
257
Rep 764
So much for having that functionality on the BM3 with the F90 platform. Just will not allow fine tuning, even at lowest settings its either snap crackle and snap/bang or off unfortunately. Attempted many different settings but can't get it to just do a rumble for a short period of time. Shame since I was able to tweak the F80's like butter to what I wanted. Off it is.
