Next Level Auto Brokers
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics
      03-08-2024, 06:15 AM   #89
tgb1974
Drives: 2016 F83 M4 (DCT)
Originally Posted by NORAGRETS View Post
TBH this overly complicates the installation…it’s really straightforward. If you’re on this forum, you probably already know a bit about your car, don’t overthink it lol. It’s literally 2 connections, back of the stereo/media unit/head unit has the big square shaped male connector and the physical screen has another. That’s pretty much it.
Appreciate your post. However, WhiteFox and I are not using an aftermarket Android display. We are using a larger OEM display that BMW used in the G30/G32 and F90. So we only have to make the video connection. Thanks.
2016 BMW F83 ///M4 Tanzanite Blue Metallic/Silverstone Full Merino // NBTevo ID 6 retrofit // G3x/F90 10.25" MGU display retrofit // GTS flash // SmartTOP // 437M + Pilot Alpin PA4 (winter) // 359M + ContiSportContact 5P (summer)
Retired: 2013 E93 M3 | 2015 F22 M235i xDrive | 2012 E70 X5 xDrive 35d | 2010 E90 328i xDrive
      03-08-2024, 02:34 PM   #90
tgb1974
Originally Posted by WhiteFox View Post
No perfect fit no issues there but would state to be careful when fitting as can scratch the leather.
I just installed the 10.25" display with the Bimmer Tech adapter. Like you WhiteFox, I have full leather, and I have to say the fitment was difficult. I had a hard time getting the adapter to seat so that the mounting screws lined up. It seemed like the left side of the leather dash was interfering ever so slightly, so I had to press and hold it down to get the screw holes to line up. Seems fine now, though. Did you have a similar experience? Thanks.
      03-08-2024, 05:52 PM   #91
tgb1974
Yes you have to cut this off as not needed as was a locator pin for the G series.
I was able to fit the adapter to the display without cutting off the post. It will, however, get in the way if I ever disconnect the video cable, but the post does not interfere with the adapter fitment. Just an FYI.
      03-09-2024, 02:06 AM   #92
WhiteFox
WhiteFox's Avatar
United Kingdom
127
Drives: BMW M4 F83
I didn’t have any issues just slotted in. It’s best to fit the adaptor first to the screen and then install. As for the locator pin in the bimmertech instructions it says to cut off and I did this so easy to reach cable.
      03-09-2024, 06:50 AM   #93
tgb1974
Thank you. Okay, so I installed it and had it coded (not by Bimmertech). Display works, but the BMW navigation map does not display correctly. It only uses a portion of the display—it won't scale up to the larger display. The rest of the iDrive interface and CarPlay maps takes up the whole screen, but only the OEM navigation does not. Is this the case for you as well?
The guy who did the coding told me that this is an MGU screen that was never intended for the NBT Evo system like we have, and so the BMW maps will never display correctly. If that is right I feel like Bimmertech should have disclosed that somewhere. I would not have done the upgrade had I known that.
I wonder if I should have bought the older version of this display made by Kyocera? The key question is whether the G30/F90 ever had the 10.25" display with NBT Evo 6 as opposed to MGU.
      03-09-2024, 03:29 PM   #94
WhiteFox
WhiteFox's Avatar
United Kingdom
127
Drives: BMW M4 F83
Sounds like he does not know what he is talking about as scales perfectly no issues. What NBT are you running and also what was the coding parameters. See attached image with scaling.
      03-09-2024, 03:47 PM   #95
tgb1974
I am running NBT Evo 6, like you. Thank you for posting this picture. It confirms that the coding was not done correctly and that the the map should scale to the larger display.
      03-09-2024, 03:54 PM   #96
WhiteFox
WhiteFox's Avatar
United Kingdom
127
Drives: BMW M4 F83
No problem at all - I do get frustrated when coders make things up. What I would check is you don’t have split screen on as this will block a portion out.
      03-09-2024, 03:54 PM   #97
tgb1974
Could you put me in touch with the person who did your coding?
      03-09-2024, 03:56 PM   #98
WhiteFox
WhiteFox's Avatar
United Kingdom
127
Drives: BMW M4 F83
That’s me 😂
      03-09-2024, 03:58 PM   #99
tgb1974
That’s me 😂
Could you post the parameters you coded to make it work? Thanks!
      03-09-2024, 04:22 PM   #100
WhiteFox
WhiteFox's Avatar
United Kingdom
127
Drives: BMW M4 F83
Attached hope this helps
tgb1974154.00
      03-09-2024, 04:41 PM   #101
tgb1974
I sent these parameters to my coding guy. He insists he tried them and they didn’t work. I have the exact same display as you. So frustrating. I guess I have to find someone else to try and fix it.
      03-09-2024, 05:08 PM   #102
tgb1974
Did you code your car with BimmerCode (etc.) or e-sys?
      03-09-2024, 06:27 PM   #103
tgb1974
I probably should have asked this before. What version NBTEvo do you have? If you are on the map screen, hit the option button on the iDrive controller, select software version and there will be a line that says
NBTevo_ followed by a letter and some numbers. Would you tell me what yours says?
I’m wondering if I need a later version of iDrive 6 to get this display to work properly. Sorry for all the questions. Thanks again!!
      03-09-2024, 11:16 PM   #104
WhiteFox
WhiteFox's Avatar
United Kingdom
127
Drives: BMW M4 F83
Post a picture of what you are getting.
      03-10-2024, 07:26 AM   #105
tgb1974
The map looks like this.
      03-10-2024, 07:54 AM   #106
tgb1974
Anyway as part of my troubleshooting this problem it would be very helpful to know what version of ID 6 firmware you have. I suspect you have a version later than NBTEvo_O, which is what I have. There really can't be any other reason why you coded these parameters and they completely worked but for my (my coding guy says he tried them) and they did not (the display would not turn on).
So if you would let me know what firmware version you have I would very much appreciate it!
      03-10-2024, 09:35 AM   #107
jaylazy2020
jaylazy2020's Avatar
Ireland
266
Drives: BMW F82 Comp
Sorry to hijack this thread but I’m about to pull the trigger on a G30 LG screen
Is my firmware suitable?
      03-10-2024, 10:04 AM   #108
tgb1974
I am working with my coding guy (who is going above and beyond the call of duty) right now to answer that question. The only way he has been able to get my 10.25” MGU display to turn on at all was by selecting the 1900x720 resolution, which is supposed to be for the 12.3” display. The 10.25” is supposed to use 1440x540 resolution, but selecting that results in my display not turning on at all.
But WhiteFox got his to work no problem with the 1440x540 resolution. This leaves me with two possibilities: his NBTEvo firmware is newer and enables the display to work properly OR the display I bought is too new.
Thoughts? Thanks!
      03-10-2024, 04:18 PM   #109
WhiteFox
WhiteFox's Avatar
United Kingdom
127
Drives: BMW M4 F83
I have the latest version X guys. That might fix the issue. I would buy the screen model I showed you on the thread.
NORAGRETS459.50
      03-10-2024, 04:21 PM   #110
WhiteFox
WhiteFox's Avatar
United Kingdom
127
Drives: BMW M4 F83
You have the wrong resolution hence your map is showing smaller than normal. I would upgrade to latest NBT version.
YASBBYM3594.50
f80post
