02-01-2024, 02:09 PM | #133 |
547
Rep 513
Car went to the local BMW dealer today and I asked them to update the Service history on the new ID6 unit. With the retrofit the service history was for the donne vehicle.
They did struggle a bit with this and called. I mentioned that I read that all they needed to do was was create an entry. The dealer did that and when my partner picked up they apologised as the car only showed the latest history entry. I checked later that night and full service history was there and assume the rest must have downloaded over the air via the 4g ATM module. I don’t have “connected services” as not able to get it as car was imported to different country ( UK to NZ) as BMW NZ saying not allowed to do so. But the car is obviously still connected via 4g country roaming for functions like BMW service history. |
02-17-2024, 04:33 AM | #134 |
547
Rep 513
Sound treated the trunk. Did the trunk lid a while back which made quite a difference. Also wanted to cover trunk floor and storage area. Without treatment the area has a high resonance when tapped or knocked. Used Dynamat extreme squared which is a new product that comes in flat sheets so it’s not folded over itself. Originally was going to use soundskins which is a three layer product and closer to 4mm thick. But couldn’t get locally. I think if I was in the USA I’d use Resonix.
However, with Dynamat at 2mm think it means carpet and carpet trim will go back into place. I didn’t cover the area where the fuse box and ATM module sits. The panel is quite strong and I wanted the area to look OE so no sound treatment. I also treated the area around the amplifier location and part of the panels around that area. I decided not to do the fendares. Didn’t want any chance of the roller process distorting those panels. Played a few tracks with high energy bass and this has improved the low end further with less rattles at high volume. Goytee “ Why Worry” is great for Sub bass / Mid bass. Bass has become tighter. |
Andrew_za9.00 |
03-26-2024, 03:03 AM | #136 |
547
Rep 513
Thought I’d put together a cost summary of this system in $NZD for a rough guide. Not sure if I could done this cheaper to get the system to current level, but could have certainly spent more on higher end door components. This is my hobby so get enjoyment from putting systems together and tuning.
Retrofit of idrive 6 added cost and gained nothing in sound quality over ID4 , but needed MS teams calling and CarPlay app ecosystem to do this in a safe manner. Best audio results are via usb / cd /dvd inputs over BMWs Most digital audio. Speakers 2 sets of Focal es100k $1500 MOBRIDGE 8.1.1 amp $2000 Morel 8 inch BMW subs. $1050 Sub Boston Acoustic ( from old system ) $0 But about $700 in 2010 Sub Box / Penn HD speaker carpet, Speakon $150 HK 8 inch speakers and enclosures $240 ( will sell hk 8s) Sound treatment Dynamat sound deadening $430 Wiring Silver tinned speaker cable for new looms $320 4gauge power / fuse holder / lugs $80 Trim Front HK door trims $190 Rear HK door tweeter brackets $90 HK speaker covers $120 Misc BMW. Pins and connectors $120 Trim removal tools , crimp and pin tools $140 Coding tools Bimmercode ( limited use needed BU ) $175 Mhd wifi dongle $190 Bimmer Utility, should have brought instead. $140 Enet cable $40 Idrive 6 / touch screen/ controller. $2000 So roughly $8800 NZD / $5300 usd to build without selling off iD4 unit / screen / hk woofers worth about $2000 on nz market. Was it worth it ? Hell yes ! So what’s next ? I continue to refine my DSP maps for single and multiseat. At some stage will come back and post refined settings and some RTA graphs. But also onto next project , a 60s English Mini restomod / cafe racer and associated period looking audio system. |
04-17-2024, 12:28 AM | #137 |
Rep 15
Read through the entire thread, amazing work!
Did the road noise cancellation somewhat worked out in the end? |
NealfromNZ546.50 |
04-17-2024, 02:22 AM | #138 | |
547
Rep 513
The sound damping did help a bit with road noise. Must go for another drive and measure. But biggest gain was in sub bass. The trunk doesn’t create rattles like it did so cleaned up the audio nicely. Was also able to reduce bass gain by 3 db and still hit the audio target curve so effectively it’s doubled the power available on the sub bass. The mid bass drivers in the doors can be run to near power limits with no apparent rattles , buzzing or resonances. I think to cut road noise further would require additional products like Resonix but what is done is a good compromise between good audio without killing off the sound of an M3. |
m4shifter3.00 |
04-29-2024, 05:32 AM | #139 |
547
Rep 513
Was investigating a rattle and a null around 160hz ( upper bass ) . Found one of the underseat woofer the speaker grill mounting tabs had broken. Bit of glue and plastic welded a cable tie around it.
Took the opportunity to add some sound deadening under the woofer enclosure and in the enclosure. It did dampen the knuckle tap test on enclosure. But testing after with music I couldn’t decern any difference. But that curved area under the woofer enclosure is quite strong compared to flat panels so doesn’t resonate I popped the Harman Kardon 8 inch woofers for a back to back comparison with the Morels. Here’s the results with no EQ an and run from 20-110hz like the factory setup. ( eg , no trunk sub) . Volume was around half way on idrive. The Morels have greater sub bass output below 60hz than the Harman Kardons. But that was to be expected. The Morels have nice articulation on bass notes and hold together well at high volumes. |
