Autotalent
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Suspension | Brakes | Chassis
      05-09-2024, 04:42 PM   #1
RsimmM4
Drives: 2015 M4 Conv.
Rear adjustable camber arms. Which ones?
Hey Guys,
Just put on lowering spring 2015 f83
I am thinking of getting adjustable camber arms for the rear since we blow through tires so fast on these cars with so much neg camber.
The question is would I just need lower arms or just uppers? It is a very mild drop. I was told it is unlikely I would need both.
Eibach springs installed
      05-17-2024, 01:34 PM   #2
csboi
Late Apexer
csboi's Avatar
381
Drives: RS/CS
Camber out back is adjusted via a factory eccentric bolt, which should have enough adjustment for you to correct the geometry.
If you need more, there are upper control arm options from SPL, Fall-line, and Dinan. I've personally used SPL and they are fine. I would suggest pairing a set of upper arms with a camber eccentric adjustment lockout kit.
2018 BMW ///M3 CS • San Marino BlueMPE V2, VRSF SMP, KW HAS, GC CPs, SPL FLCAs + TREs + RUCAs + F&R ELs, Fall-Line RTLs, Team Schirmer offset RDB, Michelin PSC2★, MSI 80mm wheel studs, Core4 FC lug nuts, CSF CC, ESS Tuning CPs, MSR FMCAI, Dinan coils, SLON Workshop tie bar, Endless ME20 + RF650
f80post
