European Auto Source (EAS)
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Suspension | Brakes | Chassis
      09-06-2017, 08:31 AM   #1
danniexi
danniexi's Avatar
3096
Drives: 2022 F97 X3M Comp LCI
F80 Steering/Suspension Noise (Creaking)
So this issue developed two weeks ago when going on a small road trip. After about 3 hours on a fairly hot day, the steering wheel started to develop a creaking/squeaking noise (like two pieces of rubber). The sensation can be felt through the steering wheel and the noise is isolated towards the front driver side. It sometimes happens over bumps but usually when turning the wheels. Video below to demonstrate the issue.
The issue went away the next morning. For the next week the noise didn't appear, though I haven't driven the car very long and the weather was pretty mild. The noise returned yesterday after driving for an hour or so, again in hotter weather. It's more apparent now than before.
I drove the car for a little bit this morning to drop the kid off at daycare and the noise wasn't there.
so... wtf mate. any ideas? I've had the car for two years, was on springs for at least over a year and never had any issues until now.
BMW MY22 F97 X3MC LCI - CURRENT BUILD THREAD| Instagram: @danniexi
BMW MY16 F80 M3 - GONE
BMW MY08 E92 335XI - GONE
BMW MY06 E46 325XI - GONE
      09-06-2017, 08:46 PM   #2
darkbluemn
darkbluemn's Avatar
Drives: 2017 BMW M4 F82
I had the same issue before and brought it to dealer. They fixed it under warranty and my SA told me they replace the front suspension struts to fix it.
      09-10-2017, 09:28 PM   #3
danniexi
danniexi's Avatar
3096
bump. any one else? not sure if dealer would cover under warranty considering I have aftermarket springs.
      09-11-2017, 09:01 PM   #4
M3Tooner
M3Tooner's Avatar
Drives: 2016 M3 DCT ZCP
Are you handy to swap the springs yourself? I would put the stock springs back and see if noise goes away. If still noisy, it's time to visit the dealership for warranty work. Don't take the risk of letting them have the excuse to not warranty to fix this noise because you have aftermarket springs.
      09-15-2017, 09:56 AM   #5
SCRPN
SCRPN's Avatar
Drives: '18 MR 340i xDrive 6MT
I have had the same exact sound coming from my '15 F82 but only after installing swift lowering springs...smh... The sound comes from front passenger side.
      10-31-2021, 12:51 AM   #6
Mpow
Drives: N54
Has anyone else had success in resolving this? Mine is making a very similar noise after swapping from lowering springs back to stock. Seems to be worse when warm.
https://youtube.com/shorts/i1JPjtXZyDI?feature=share
      12-04-2021, 02:38 AM   #7
senbei
Boosted
Drives: 2015 F80 M3
Figured out the issue. The shop I took my car to said it was the strut mount bearing. I went from aftermarket springs back to OEM and had creaking on my right side strut mount. Bought the parts myself for ~$200 and had the shop replace it for $400. It sounded EXACTLY like that.
      12-06-2021, 08:45 AM   #8
M 4 FUN
608
Drives: 320 Si, M4 comp. M3 E46
Loosen up the strut bolt, put a jack under the front suspension and put pressure on it, then retighten the strut bolt to spec.
      03-14-2022, 06:29 PM   #9
rosemont83
120
Drives: 911 turbo, E39 M5,
This happened to my car, it's a 2020 M4 zcp with 9700 miles, and they're replacing only the driver side strut mount. Looks like this is a recurring issue for a few people.
Hope if you get this issue you don't get the crankhub problem instead....
      04-21-2024, 10:14 PM   #10
Mpow
Drives: N54
Thanks for the reply! Do you happen to have a part number? You just replaced the bearing, not the whole strut mount?
csboi381.00
f80post
