BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > Blinking Brake Force Display??
      04-10-2012, 03:32 PM   #45
Dziqsek_
Poland
37
Drives: e91 320d
When you release brakes it stops blinking he just keep pressed pedal to show the effect
And yes the blink frequence can be different
      04-13-2012, 05:59 AM   #46
taranonline
28
Drives: Man
bump
      04-13-2012, 04:00 PM   #47
strams
Hi there
Drives: BMW
Possible in FRM3?
      04-13-2012, 04:46 PM   #48
Dziqsek_
Poland
37
Drives: e91 320d
Hard to tell, it works on some cars on some not, dont know why BMW goes this way, Worked on my friend e93 m3, and on his friend e90 M3 didnt work, both cars are same year model , my car didnt work aslso, and on couple of my clients cars it work.
Post your nfrm number ( but not the long one ) just the name you can read after reading it in NCS ex. frm3.c31 then i can try to modyfi it for you
      04-13-2012, 05:59 PM   #49
rmw04c
Jewbacca
rmw04c's Avatar
10
Drives: 2011 SGM 335is
Is this related at all to what you see under activations in BT Scan that says "two stage brake light" or something along those lines?
      04-13-2012, 10:38 PM   #50
taranonline
28
Drives: Man
what code should I try in my 2010 e90 sedan?
      06-17-2012, 02:00 PM   #51
e90m3japan
e90m3japan's Avatar
Japan
17
Drives: e90 m3 melbourne Red Metallic
okay so I searched and did some coding but still no luck. where I found this coding said it supposed to work but....
BFD_1_ALGORITHMUS
nicht_aktiv
BFD2_AKTIV
aktiv
BFD2_BFD
blinkend
BFD2_BL
blinkend
BFD2_BL_M
blinkend
BFD2_ESS_ANZEIGE
aktiv
BFD2_ESS_ENABLE
aktiv
BFD2_NSL
blinkend
BFD2_SL_BL_1
blinkend
BFD2_SL_BL_2
blinkend
WBLG_WBL_ENABLE
aktiv
This coding above have not worked for me..
are they right?
any tips? greatly appreciated.
BTW
I want have flashing brakes W/bfd1 and bfd2
so that means 3stage brake lights?
e90 m3 melbourne red metallic, "One and Only" e90 sedan Amuse Ericsson full exhaust(new model)with custom spec, Afe intake with stock box,piano black trim, blackline tail, HRE P40 9x19,10.5x19
      06-18-2012, 01:48 AM   #52
meyergru
No military grade
meyergru's Avatar
Germany
58
Drives: E92 M3 DCT
In my EU-spec FRM3, there are many more similar settings:
Code:
BFD_1_ALGORITHMUS
	nicht_aktiv
BFD_1_BLINK_FREQ_AUS
	wert_01
BFD_1_BLINK_FREQ_EIN
	wert_01
BFD_1_ENTPRELL_ABS
	wert_01
BFD_1_ENTPRELL_AX
	wert_01
BFD_1_MIN_GESCHW
	wert_01
BFD_1_STUFE_DELAY
	wert_01
BFD_1_THERM_TIMEOUT
	wert_02
BFD_1_WEGFALL
	nicht_aktiv
BFD_1_WERT_AX_EIN
	wert_01
BFD_1_WERT_AX_RUCK
	wert_01
BFD_1_MIT_BFD
	wert_01
BFD_1_MIT_BL_M
	wert_01
BFD_1_MIT_NSL
	wert_01
BFD_1_MIT_BL
	wert_01
BFD_1_MIT_SL_1
	wert_00
BFD_1_MIT_SL_2
	wert_00
BFD_ERSETZT_BL
	nicht_aktiv
BFD_ERSETZT_SL_1
	nicht_aktiv
BFD2_SL_1
	nicht_aktiv
BFD2_SL_2
	nicht_aktiv
BFD_1_MIT_FRA_H
	wert_00
BFD2_A_LOE
	wert_02
BFD2_A_MIN
	wert_01
BFD2_AKTIV
	aktiv
BFD2_BFD
	blinkend
BFD2_BL
	blinkend
BFD2_BL_M
	blinkend
BFD2_BLINKEN
	5_hz
BFD2_ESS_ANZEIGE
	aktiv
BFD2_ESS_ENABLE
	aktiv
BFD2_NSL
	nicht_aktiv
BFD2_T_ABS
	wert_01
BFD2_V_MIN
	wert_01
WBLG_A_ABS
	wert_02
WBLG_A_ANF
	wert_02
WBLG_F
	wert_01
WBLG_G_MIN
	wert_01
WBLG_N
	wert_01
WBLG_T_L_MIN
	wert_01
WBLG_V_WBL
	wert_02
WBLG_WBL_ENABLE
	aktiv
      06-18-2012, 09:55 PM   #53
e90m3japan
e90m3japan's Avatar
Japan
17
Code:
BFD_1_ALGORITHMUS
	nicht_aktiv
	wert_01
	wert_01
BFD_1_ENTPRELL_ABS
	wert_01
BFD_1_ENTPRELL_AX
	wert_01
BFD_1_MIN_GESCHW
	wert_01
BFD_1_STUFE_DELAY
	wert_01
BFD_1_THERM_TIMEOUT
	wert_02
BFD_1_WEGFALL
	nicht_aktiv
BFD_1_WERT_AX_EIN
	wert_01
BFD_1_WERT_AX_RUCK
	wert_01
BFD_1_MIT_BFD
	wert_01
BFD_1_MIT_BL_M
	wert_01
BFD_1_MIT_NSL
	wert_01
BFD_1_MIT_BL
	wert_01
BFD_1_MIT_SL_1
	wert_00
BFD_1_MIT_SL_2
	wert_00
BFD_ERSETZT_BL
	nicht_aktiv
BFD_ERSETZT_SL_1
	nicht_aktiv
BFD2_SL_1
	nicht_aktiv
BFD2_SL_2
	nicht_aktiv
BFD_1_MIT_FRA_H
	wert_00
BFD2_A_LOE
	wert_02
BFD2_A_MIN
	wert_01
BFD2_AKTIV
	aktiv
BFD2_BFD
	blinkend
BFD2_BL
	blinkend
BFD2_BL_M
	blinkend
BFD2_BLINKEN
	5_hz
BFD2_ESS_ANZEIGE
	aktiv
BFD2_ESS_ENABLE
	aktiv
BFD2_NSL
	nicht_aktiv
BFD2_T_ABS
	wert_01
BFD2_V_MIN
	wert_01
WBLG_A_ABS
	wert_02
WBLG_A_ANF
	wert_02
WBLG_F
	wert_01
WBLG_G_MIN
	wert_01
WBLG_N
	wert_01
WBLG_T_L_MIN
	wert_01
WBLG_V_WBL
	wert_02
WBLG_WBL_ENABLE
	aktiv
Thanks!
I will try your set up and see if it works!
Thanks!
      06-19-2012, 02:01 AM   #54
E90PAT
SOFLO CODING
Slovenia
199
Drives: Z4M
Originally Posted by e90m3japan View Post
Thanks!
Thanks!
Looking forward to results
      06-20-2012, 09:39 AM   #55
e90m3japan
e90m3japan's Avatar
Japan
17
I tried but I don't think it's working... May because my tail lights are pre lci?
      02-03-2013, 12:41 PM   #56
335DEE
335DEE's Avatar
England
38
Drives: M3 DCT
After coding BFD for me this evening My pre LCI e92 there are 2 Levels of BFD
I am only referring to FRM(1)
I now have 3 levels of braking
Normal less than 4m/s
Heavy Braking but no ABS +5m/s = Level 2
ABS = Level 3
You can definitely code Flashing 3rd light on BFD_1 . Thats the only flashing option you get
You can code flashing 3rd light, fogs and BFD brake lights on level BFD_2
It is worth pointing out that as soon as you take your foot off the brake the flashing stops. It also times out after 30 secs if you keep your foot in.
The top video below is a Level 2 stop, the foot was kept on the brake for demonstration purposes .
You can't appear to change the frequency of the flashing on the FRM1 . You may be able to change some PWM setting somewhere. FRM 2&3 modules i think have a dedicated frequency setting.
Video 2 was ABS Flashing 3rd light , fog light and flashing BFD light ( small light situated just above brake light) and was activated by the ABS
The only thing I will add is that on Level 2&3 braking my front sidelights ( angel eyes) pulse too. Not had time to figure that one out yet
      02-03-2013, 02:36 PM   #57
cn555ic
cn555ic's Avatar
Drives: 335i
This seems to work only for EURO spec cars...I have not seen anyone in the US be able to code this in...
      02-03-2013, 04:51 PM   #58
cyrano
Poland
16
Drives: E61 530XD chipped
Really ?? Im pretty sure its available for US also, cn555ic send me your trc i will send it to You Know Who, maybe he will be able to make it work
      02-03-2013, 04:55 PM   #59
335DEE
335DEE's Avatar
England
38
Drives: M3 DCT
It appears all the people who have tried to get the code to work have not changed 'BFD_1_ALGORITHMUS
nicht_aktiv'
to aktiv !
Same for 'BFD_2_ALGORITHMUS'
      02-03-2013, 08:36 PM   #60
Modded328FTW
Drives: 328
ABS = Level 3
Nicely Done. Here is my NFRM trc file. Wonder if the setting are different between euro and us trc.
Thanks
      03-25-2013, 07:16 PM   #61
I M LEGEND
Drives: M
Can you make it flash faster?
      03-26-2013, 04:25 AM   #62
335DEE
335DEE's Avatar
England
38
Drives: M3 DCT
not so sure on NFRM , FRM2 & 3 yes (BFD2_BLINKEN) value 3Hz
      04-05-2013, 01:18 AM   #63
Morrisadam
Drives: BMW Z4 sDrive35i
Anybody please help me!
I bought my car from the US and I'm using it in Europe. I bought two new rear lights which has yellow turn signal.
The problem is that when I press the brake pedal the (yellow) turn signal comes on continuesly.
How can I program it not to come on when I brake.
Thx.
      04-22-2013, 11:48 PM   #64
SharkBait
14
Drives: 2010 E92 335i
Bumping this. Has anyone got this to work on FRM2 in the US?
      04-23-2013, 02:11 AM   #65
335DEE
335DEE's Avatar
England
38
Drives: M3 DCT
Post your trace file but I'm guessing you haven't read post 59
      04-23-2013, 11:19 AM   #66
pweber84
pweber84's Avatar
Germany
49
Drives: BMW 330d e91
This should work for FRM2, even on US cars:
BFD_1_ALGORITHMUS
nicht_aktiv
BFD2_AKTIV
aktiv
BFD2_BFD
blinkend
BFD2_BL
blinkend
BFD2_BL_M
blinkend
BFD2_ESS_ANZEIGE
aktiv
BFD2_ESS_ENABLE
aktiv
BFD2_NSL
blinkend
BFD2_SL_BL_1
blinkend
BFD2_SL_BL_2
blinkend
WBLG_WBL_ENABLE
aktiv
Tags
bfd, brake force display
