03-19-2021, 07:10 PM | #23 | |
2273
Rep 3,299
Mike
03-19-2021, 07:33 PM | #24 | ||
4061
Rep 4,983
What's concerning is just being careful isn't always enough. I don't think an impact that's capable of piercing the oil pan would necessarily be noticeable at highway speeds, listening to the radio, talking on the phone, etc. I think in most cases it would be, and would prompt most of us to pull over and examine everything, but I don't think that would always be the case. Peace of mind would be nice. I don't see how the extra mesh would in any way restrict air flow/cooling
<b>2023 M5C SRG|Aragon || 2018 Macan GTS</b>
2019 F90 Comp MBB|Black (sold) 2018 F80 ZCP TB|SS (sold) 2015 F30 335 AW|CR (sold) 2015 F31 MG|CR (sold) 2011 E90 JB|Oyster (sold) |
03-19-2021, 11:02 PM | #25 | |||
4140
Rep 7,160
Drives: F90 M5 / F15 50i
'07 Yamaha R1 (sold)
03-21-2021, 10:05 AM | #26 |
2273
Rep 3,299
Hold on, if you add the mesh it will restrict air flow, that's not arguable. The question is how much of a change in flow and will it have any true, daily-normal-car-use, measurable effect on the actual oil temp? Again it would be truly nice if BMW engineers participated in such online forums.
Back in the 90's my dad had a new clutch put in his manual transmission M5 and the clutch felt way too light. He called the factory and actually spoke to the engineer who designed the new lighter clutch (for light weight drivers, read into that what you want, same group who wanted automatic transmission M3 at the same time period). The engineer spoke with him with great enthusiasm for an hour. Today, you can't get any input from the Fatherland. The marketing department has taken over BMW. Just look at the horrible grill no the 2021's. who posted here that they like that grill???? Or the new virtual cock pit display, Meh!!! Mike
03-21-2021, 07:08 PM | #27 |
292
Rep 605
I've been running my modified version of the Fall Line Motorsports model for a while now, and even when pushing it hard the oil temp never climbs above pre-guard numbers. That guard is seriously heavy gauge steel, and with the thick perforated stainless plate I had welded onto it by my local machine shop, any road debris with substantial mass is going to have a really hard time perforating it and getting to the oil cooler.
Dealership had no complaints when I had it serviced recently, and I know they saw it. Per my request, they also swapped out my plastic oil filter cap for the Weistec aluminum model with a drain plug that I brought with me. |
03-22-2021, 07:35 AM | #28 | |
4140
Rep 7,160
CanadianF90M5125.00 warpeacelove134.00 |
03-22-2021, 01:31 PM | #29 |
2273
Rep 3,299
Um, does your muffler restrict air flow? It's downstream from your intake. Of course it does.
This is fluid dynamics. Each stage of flow has an influence. If not then WHY THE HELL WOULD THE BOTTEM BE WIDE OPEN? The question remains.....how much difference in cooling would one see if that space was closed over 1. with the grids being used or 2. with a sheet of plywood. Mike
GTTC55.00 |
03-22-2021, 10:47 PM | #30 |
292
Rep 605
No doubt it restricts airflow to some degree. The added resistance from the guard + perforated metal grating due to loss of cross sectional area is real, and around 10% from rough calculation since it's already non-laminar flow. I wager that over time, unguarded, the metal fins of the oil cooler radiator, being so exposed, will likely bend and restrict airflow at least as much. Ever looked at a several year old coolant radiator and wonder how much less efficiently air passes through it? It seems reasonable that most of the damage to the oil cooler over time would be from debris bouncing upward from the road, to which it is parallel.
03-28-2021, 03:46 PM | #31 | |
268
Rep 380
19M541.00 |
12-10-2023, 07:19 AM | #32 |
229
Rep 425
Has anyone looked at or purchased the CR Racing oil cooler guard from Autotecknic? Any thoughts on that one, now that I’m freaked out about running over road debris and destroying my engine lol
