03-01-2021, 10:55 AM | #1 |
///M Powered for Life
11500
Rep 10,333
11" ET44 vs GT4 11" ET30
There's something I struggle to understand and I'm hoping someone can set me straight.
Apex did a lot of testing back in the day and came up with the perfect rear fitment for F8X cars: 11" ET44 Meanwhile, the OEM GT4 wheel fits the rear F8X cars and is 11" ET30 What gives? 14mm offset difference is massive. I don't see how 11" ET44 is the max wheel width on inner and outer clearance yet people are fitting the 11" ET30 wheel. |
03-01-2021, 11:13 AM | #2 | |
707
Rep 886
Apex's fitment was also fairly conservative. I'm a 11.5 +44 rear and have never rubbed once in 5yrs, under any circumstance (i.e. with a fully loaded car, on track, etc.)
2015 M3 - AW 6Spd w/ CCB
MCS 2WR Dampers, Spec Twin Disk Clutch, MaxPSI CH, F80Paul Ethanol Tune, 3.5in DPs |
SYT_Shadow11500.00 |
03-01-2021, 08:39 PM | #4 |
1019
Rep 859
Lowered on MCS coils and running -2.7°, with 18x11 ET44 and this was the result. Partially due to running oversize Perelli DH, but seriously considering those 18x11 ET30s. Friend is running similar ride height and camber and ET30s are working well for him.
Not real excited about the front spacer required to rotate, but can’t image the front spacer required for ET44. My take away, ET44 is best for stock suspension/alignment settings |
SYT_Shadow11500.00 BetrayMyWord62.50 |
03-01-2021, 09:13 PM | #5 | |
11500
Rep 10,333
03-01-2021, 10:56 PM | #6 |
1019
Rep 859
Was thinking the same thing, a 10mm rear spacer would’ve likely cleared the inside and probably been good on the outside as well. I guess that would be effective ET34, close enough to a ET30 for me to give it a go and ET30 = less spacer up front - rotatable is must for me
03-02-2021, 08:21 AM | #7 | |
11500
Rep 10,333
03-02-2021, 08:58 AM | #8 |
1019
Rep 859
03-02-2021, 09:26 AM | #9 |
11500
Rep 10,333
thank you
03-03-2021, 02:42 PM | #10 |
1019
Rep 859
Suspense builds for Saturday, will see if Porsche club event last weekend makes a difference. Starting to like this track as seat time here increases. Can’t say I’m new to SoCal tracks any longer.
03-03-2021, 03:03 PM | #11 |
11500
Rep 10,333
Do you have that spacer in the rear?
03-03-2021, 04:01 PM | #12 | |
707
Rep 886
Also of note, the 18x11 +30 gt4 wheel works in the rear because bmw was forced to compensate for crap fitment by reducing all suspension arm length by around an inch. My f80 friend with Ohlins ttx shared his original gt4 wheel fitment (315/30/18 r888r) pics with me and it literally pokes out by an inch or so...he had to get the e90 version of his SPL arms to allow fitment.
03-04-2021, 12:45 AM | #13 | |
1019
Rep 859
03-04-2021, 12:53 AM | #14 |
1019
Rep 859
03-06-2021, 09:07 PM | #15 |
1019
Rep 859
18x11 ET30 with Yoko 295/30/18
It does fit, but it will rub under full compression on this F80 - which has similar alignment specs to mine in the rear |
03-06-2021, 09:16 PM | #16 |
11500
Rep 10,333
So you'd be better served with ET44 it seems
03-06-2021, 09:19 PM | #17 | |
1019
Rep 859
Probably ideal would be something approximately ET35 as ET30 barely rubs |
03-06-2021, 09:31 PM | #18 |
500
Rep 411
What are your concerns over the spacer? Only ask as I've got like 10 hours on the track with a 25mm spacer up front. Besides the aforementioned front scrub radius and the expectation that there might be a little more tire wear up front, the car seems to handle quite nicely with the benefit of tire rotations being an option.
I do notice that my fronts wear slightly faster than the rears, but I wasn't too surprised by this. 3600lb car and two heavy braking zones is asking a lot of the fronts, in addition to normal cornering duty. |
03-06-2021, 10:17 PM | #19 | |
11500
Rep 10,333
Remember the GT4 runs 25mm spacer up front without issues |
03-10-2021, 11:28 AM | #20 | |
1019
Rep 859
03-10-2021, 12:43 PM | #21 |
277
Rep 419
03-10-2021, 01:16 PM | #22 |
11500
Rep 10,333
I thought it was the other way around, 3mm more on the M3
