12-08-2018, 05:48 PM | #1 |
142
Rep 897
Drives: F90 M5
Redline moves to 1250rpm in Drive
Does anyone else's tachometer change the redline to 1250rpm when shifting from Neutral to Drive when cold? If you move off it resets back to normal.
F90 M5 (Marina Bay Blue, M Performance Parts)
Previous: F82 M4 / F20 125d M / E92 335i M Ind / E90 325i SE / E46 318i SE / E36 316i |
12-17-2018, 05:12 PM | #2 |
142
Rep 897
Drives: F90 M5
Just me then?
12-28-2018, 02:42 PM | #4 |
142
Rep 897
Drives: F90 M5
Finally found a way to upload a video of it - look at the redline move on the tach when I select Drive:
https://www.dropbox.com/s/vse4v192qt...%2054.mov?dl=0
12-28-2018, 02:57 PM | #5 | |
///M
6651
Rep 3,683
Something wrong bro! What happens when you start driving?
Life is too short...enjoy your life
///M |
12-28-2018, 03:19 PM | #7 | |
Plenipotentiary
2614
Rep 3,046
It's indicating the unloaded cold rev limit in N, and when in D, indicating the drivetrain is not warmed enough for LC activation. If you stop every mile for the first 6 miles, the range displayed in D while stationary will progress higher each time. |
jhbodle141.50 |
12-28-2018, 03:31 PM | #8 | ||
///M
6651
Rep 3,683
All he did shift from N to D Mine doesn't do that, it shows yellow part/red but it never goes down that low. Lowers I have seen is 3.5K at -15deg
///M |
12-28-2018, 03:37 PM | #9 | |||
Plenipotentiary
2614
Rep 3,046
12-28-2018, 03:52 PM | #10 | ||||
///M
6651
Rep 3,683
I guess lean warm up cycle is not what we have as cold start where it idle's higher at the start?
///M |
12-28-2018, 04:05 PM | #11 |
142
Rep 897
Drives: F90 M5
Interesting - does the rev limit in N increase as the engine warms up or is it a hard limit at 1250rpm to protect the engine from unloaded revs? I've heard that revving an engine with no load is bad for it.
12-28-2018, 04:57 PM | #12 | ||
Plenipotentiary
2614
Rep 3,046
I used LC for simplicity sake since it's a combination brake stand/clutch drop. What's being displayed is the stationary in-gear brake stand redline which will increase with time and distance. The intentional changes from D to N and back show it swinging from one end to the other. Quote:
Miko M6650.50 |
12-28-2018, 05:01 PM | #13 |
142
Rep 897
Drives: F90 M5
Oh OK I think I get it, so it's like a progress bar to tell you how long you've got left before LC can be activated?
12-28-2018, 05:04 PM | #14 | |||
///M
6651
Rep 3,683
I lived there and I know Thanks for education!
///M |
12-28-2018, 05:19 PM | #15 |
Plenipotentiary
2614
Rep 3,046
In simple terms, yes. Not sure what area you're in, but if within Central London or T-Charge Zone, it's possible the arc range will remain low since there's so much geo-fencing incorporated now.
12-29-2018, 03:43 AM | #16 |
407
Rep 2,704
the key point here is - does your redline drop to the say approx 7,000 rpm after 15-20mins of driving - if yes then it is fine.
Quickburn7955.00 |
12-29-2018, 02:08 PM | #19 | |
325
Rep 519
