10-28-2013, 10:07 PM | #67 |
44
Rep 349
+1 for the mapping. On the manual if you hit the sport button the car will accelerate. When going back to Comfort the opposite is true.
2013 EBII 328i M-Sport 6MT, M-Performance Brakes, M-Performance Suspension, APEX Arc-8 18 x 8.5 square, Pilot SS
1999 EB1 M3 - Bilstein PSS9, Vorshlag Camber Plates, Kosei K1, ZII Star Spec, PFC, gallon of distilled water. |
10-31-2013, 10:14 AM | #68 |
Diligentia Vis Celeritas
558
Rep 1,477
Drives: 335i
I just updated the chart in a few areas... after testing some more over the last couple of days, there are definitely some minor variances in transmission characteristics depending on the mode. Also, in addition to the obvious throttle mapping differences in Sport mode, I definitely feel like the throttle response is a bit more sensitive in Sport as well.
Ahead of the curve for specF30
10-31-2013, 10:49 AM | #69 | |
162
Rep 573
Drives: 2013 F30 335i 8SA M-Adaptive
10-31-2013, 12:34 PM | #70 | |
558
Rep 1,477
Drives: 335i
For the normal vs sport throttle comparison, I evaluated Sport-with-drivetrain-set-to-normal vs Sport+ so the suspension settings were the same.
10-31-2013, 04:44 PM | #71 |
44
Rep 349
I nominate this thread for sticky. DVC you are doing us all a great service.
10-31-2013, 09:57 PM | #72 |
558
Rep 1,477
Drives: 335i
Thanks! utenigma started off a good thread with lots of great info and tests, so I'm happy to add some value to it.
10-31-2013, 10:38 PM | #73 |
44
Rep 349
Indeed!
11-09-2013, 07:55 PM | #74 |
198
Rep 883
First AutoX event today with the new car, EB II M-Sport with DHP - handled great.
Seems DSC off with eLSD active is the way to go. Very easy to modulate throttle, as some of you have suggested. Now I just wish I can set "normal" throttle in Sport mode (firm suspension) but still have the safety nannies on. DVC I referred to you chart today, very handy to reference on the fly so thanks for creating that. Now that I've got the RE-11's scrubbed in I think I'm ready to get some good times in next weekend. I think we should all start bugging Dinan for their Shockware software to be released. Now the question is to go H&R, Eibach or stay with stock springs in the interim.
01-04-2014, 07:53 PM | #75 | |
558
Rep 1,477
Drives: 335i
If you configure Sport mode to chassis-only, you will have "normal" throttle, and DSC will still be fully active. Is that what you were looking for?
01-04-2014, 08:38 PM | #76 | |
558
Rep 1,477
Drives: 335i
There's lots of ambiguous information out there about what's actually happening in DTC mode... the consensus seems to be what JMK mentions above: that DTC still incorporates some stability control, but will allow some significant slip angles before cutting in (as DSC would). Based on my experience, I can pretty confidently say that DTC is purely traction control, and does absolutely nothing in terms of DSC-type stability control. Basically, it allows a bit of wheel slip, and then starts to cut power to the slipping wheel(s). This is good news for those of us who like to track the car with heavy steering, ultra-responsive throttle, and no DSC. (rev1.2 of my settings chart coming soon ; ) ... For those curious on how I determined this... read on: On the track back in October (Lightning circuit at NJ Motorsports Park), in my last session of the day, my tires were a bit slick after picking up a bunch of marbles during an off-line pass, and exiting turn 9 at about 100 my back end started to come around. I felt it happening, and started to gently counter-steer and back off the throttle a little... and the back end came back into check nicely without any drama. My instructor smiled and said, aren't you glad you had the stability control on for that? I told him I was pretty sure that it was me that saved it, as I didn't feel the car do anything whatsoever... (I was in Sport+ all day, so DSC was set to only "DTC") But afterwards, I re-thought it and wondered if maybe the car saved it rather than me. Now flash forward to today... Out in the snow-covered parking lot, I was kicking the back end around under acceleration in DSC, DTC, and DSC-off to evaluate how things reacted in each scenario:
So Sport+ mode seems pretty well-suited for the track after all... Just the effect of cutting excessive wheel spin under acceleration shouldn't be too invasive (wasn't problematic for me at any point), and may be just enough to help avoid a spin that isn't easily corrected if the driver severely overcooks it.
01-05-2014, 09:22 AM | #78 |
558
Rep 1,477
Drives: 335i
Yep
01-05-2014, 02:27 PM | #80 |
558
Rep 1,477
Drives: 335i
Not much difference between the effect of eLSD and DTC from what I could tell... in the snow at least. But Sport+ retains the sharper throttle mapping/response.
01-06-2014, 08:51 AM | #81 |
162
Rep 573
Sport+ pulls your throttle when the rear slips
If you're at the tractive limit of the tires mid corner and apply throttle coming out of the apex, you don't want the ecu pulling throttle when the rear tires lose traction (which they should a little), nor do you want a touchy throttle IMO I still think DSC OFF is the best way to go |
01-06-2014, 01:23 PM | #82 |
209
Rep 1,201
I'm going to say that if you're tracking with large wide turns, then sport+ might be the better option, but for autocrossing (which I've done) sport+ pulls the throttle too much and DSC OFF/Sport is the better option.
01-06-2014, 01:26 PM | #83 | ||
558
Rep 1,477
Drives: 335i
But if you're at the limit of grip mid-corner, and you apply power, then either eLSD or DTC would intervene to mitigate excessive wheel spin. I'd be curious to hear feedback from others on how well (or poorly) each function in this regard. As I indicated above, I had no issues with DTC on the track... even as my back end started to come around, it didn't intervene. Maybe in other situations or for others, it has been more invasive (?) I haven't spent much time in eLSD mode on dry pavement... but prior to the snow testing, I did also test it out on a slicked-up figure 8 skid pad at the track...I found it to be pretty invasive, and all the rear ABS activity was a little freaky. I personally don't mind the sharp throttle mapping, and find it to be a fair trade for the improved responsiveness that comes along with it. It requires a more nuanced touch, but the slightly increased lag in comfort throttle bugs me. Quote:
Can you share some details on your experience with the effects of DTC vs. eLSD on dry asphalt? (On snow, the effect felt pretty much the same)
01-06-2014, 01:45 PM | #84 | |
209
Rep 1,201
DVC...I'm not sure how fast you were going in the parking lot, but I feel like you need 30+mph to really feel the difference. |
01-06-2014, 02:10 PM | #85 | |
558
Rep 1,477
Drives: 335i
Regarding your DTC experience, it will certainly cut power when the wheels are spinning a bit - but slip angles don't affect it. So regarding the issue you mention above with applying power coming out of the turn, DTC was cutting power due to wheel spin, not (directly) due to the slip angle. In theory, the eLSD would have intervened also, don't you think? Maybe the effect of the eLSD is just more mild on dry asphalt... (?)
01-06-2014, 05:44 PM | #86 | |
209
Rep 1,201
Someone correct me if I'm wrong, but traction control doesn't use the brakes right? It just cuts power to the engine. eLSD in most cars works by applying brakes to one wheel to bring it's speed down to that of the other wheel. |
01-07-2014, 12:17 PM | #88 | |
558
Rep 1,477
Drives: 335i
I'm curious about exactly how thorough eLSD effects actually are... like, does it just slow the spinning of the wheel a little so that the loss of grip isn't as impactful, or does is clamp down hard enough so that the open diff actually switches torque over to the other wheel? I've heard that an eLSD is no substitute from a performance standpoint for a mechanical LSD, but it sounds like it's still pretty good at putting a little power down while still mitigating over steer. I've also heard that eLSDs can be hard on brake pads... have you noticed any additional rear brake wear after autocrossing in eLSD mode vs DTC? Launch control is new on the 2014 8ATs. Being a torque-converter auto, there's not as much going on as there is with LC on a DTC-equipped M car, but apparently it does work well at integrating all the systems automatically to yield the fastest launch.
