07-26-2023, 01:12 AM | #1 |
Rep 28
Recently bought a non-comp, pre-LCI F90 M5 and did some draggy runs. It’s been pretty hot and humid lately but I don’t know if the car should be this slow. 60-130 time was during the day with tailwind @13mph with one passenger and full tank of gas. 0-60 was with a 2.5k rpm brake boost launch later that night but with no passenger and still nearly full tank. Temps are on the draggy as well as elevation and DA. Humidity was 60% for both runs. Car used to be driven in California so it’s mainly used 91 it’s whole life but I filled it up with 93 before these runs. Another thing I noticed is the lack of soot on the tailpipes. Most BMWs I’ve seen always have a little amount of soot but the tailpipes are clean on this one, unless someone can send photos for comparison?
Thoughts? |
07-26-2023, 07:02 AM | #2 |
5234
Rep 10,616
The ECUs may have adapted to the 91 octane, the humidity hurt, and brake boosting is not as effective as launch control. The times look slow to me even for a 5 year old stock car. I don’t think comp vs noncomp makes a difference, but the level of factory equipment makes a slight weight difference — sunroof and 706M wheels probably cost 100 lbs and a full tank of gas could add 100 lbs compared to what most carry when recording numbers. That is like carrying a passenger. Not sure whether you are light or heavy but weight affects acceleration.
I would service the car, install engine and trans tunes, and add water/meth injection. If charcoal filters are still in place, remove them. If you can do catless secondaries and pass inspection in your area, consider them. |
07-26-2023, 10:14 AM | #3 | |
Rep 28
Thanks |
07-26-2023, 12:17 PM | #4 |
222
Rep 320
I wonder if your coolant for the intercooler is low. This will cause your call to pull timing due to the hot air from the turbos. It may not have hit a point to throw a code.
07-26-2023, 01:27 PM | #6 |
Rep 28
07-26-2023, 01:30 PM | #7 |
Rep 28
Already got the 93 in there, what’s the best way to reset adaptions? I have the WiFi MHD adapter but have yet to buy a BM3 license or MHD license, but I think MHD let’s you reset adaptions for free? Thinking of buying the BM3 for data logging anyway. I guess my concern is if the power loss is excessive.
07-26-2023, 02:30 PM | #8 |
5234
Rep 10,616
Datalogs are great for trouble shooting. Most bidirectional scan tools with bmw specific software will reset adaptions. I don’t know what is causing your results, but I would be doing everything I could to rule out problems and to improve the results.
FloridaM5461.00 |
07-26-2023, 10:59 PM | #9 |
Rep 28
07-28-2023, 01:31 PM | #11 |
1922
Rep 4,922
Is this your only draggy run or do you have others to compare?
07-28-2023, 05:41 PM | #13 |
Rep 28
07-28-2023, 05:47 PM | #14 |
Rep 28
07-28-2023, 09:33 PM | #15 | |
114
Rep 282
Let me see if I can find some draggys |
07-28-2023, 09:41 PM | #17 |
114
Rep 282
All brake boosted, didn't see the need to waste my launches in this weather especially when it was just to test the effects of the turbo blanket
https://www.ptpturboblankets.com/pro...5-m-x6-m-m5-m6 |
07-28-2023, 10:21 PM | #18 |
5234
Rep 10,616
A top end 60-130 pull difference would be much more convincing. Right now you are showing a bad launch and a vac but not quite as bad launch. You need more than 3 seconds to show significant power loss.
Info@mad-us.com1921.50 afo818254.50 |
07-29-2023, 02:59 PM | #19 |
114
Rep 282
Lol did you just say 3 seconds?? You just be trolling right?
07-29-2023, 06:54 PM | #21 |
5234
Rep 10,616
07-30-2023, 02:40 PM | #22 |
Rep 28
Do you have any 60-130 runs in conditions similar to mine? @pbonsalb had a point about the 60-130 as a better comparison for power loss between mine and yours
