03-28-2022, 07:07 PM | #1 |
420
Rep 862
Real Talk- RC Black or JB4 or..?
Hey all. I want to spice up my 2019 M5C and would like to hear thoughts on which way to go. I will run 93 with probably no other mods. There's so much info out there it's tough to digest, especially with new Dinan and Carbahn stuff out there.
What should I do? Would love as much power as possible without really going to Stage 2. Thanks for sharing any experience and info!
Retired 2016 BMW 550i xDrive MSport | 2013 BMW 550i xDrive MSport | 2012 BMW 535i xDrive | 1988 BMW 325ic | 1984 BMW 318i
03-29-2022, 12:11 AM | #2 | |
4094
Rep 3,673
Drives: 2022 M5C
There are definitely people here way more experienced than me who will give you varying opinions on this. But such a simple mod that gives a lot of power compared to how minimal the required effort is.
Not a BMW guy...but certainly an M5 guy.
03-29-2022, 09:35 AM | #3 |
Joint Chiefs of Staff
24199
Rep 190,807
The JB4 is the most advanced piggyback on the market with the most features, safety failsafes, ability to read and delete codes + datalog.
You can use it as a set and forget its tune as it will default on map one, which works for all stages. Or you can fine-tune it and choose different maps. With that being said, both options will give you more than enough power and are safe to use. You can't be wrong with either one.
03-30-2022, 12:09 AM | #4 |
420
Rep 862
Thanks for the input, guys.
I'm surprised that no one is lauding Dinan or Carbahn? I was thinking that either might be a viable way to go.
03-30-2022, 06:27 AM | #5 | |
Rep 28
03-30-2022, 10:01 AM | #6 |
775
Rep 569
Drives: 2019 M5 Competition
Racechip Black GTS here, no issues thus far, no CEL. Noticeable gains. Never dyno'd, and dont have a draggy. But definitely can tell its pulling harder. For sure more noticeable on rolling/freeway.
Ive been happy with it. I have no to reason to believe a JB4 is worse. I'm sure very similar. I don't recall the reason I went RC vs JB4, but i'm sure I would have been happy with either. I'll add I regularly use a combo of 91 and 95 race fuel, or straight 95 , because there is gas station near me that sells 95 and 100 octane in the pumps. |
03-30-2022, 10:50 AM | #7 |
5234
Rep 10,616
Racechip is easier to install, but for the same reason also has less potential due to the reduced inputs/outputs, compared to JB4. It also does not offer meth integration like the JB4 if you want the added performance that higher octane offers and do not have access to E85 or want to buy race gas. I have used a JB4 with meth but will soon change to a BM3 with the JB4 just controlling meth.
03-30-2022, 03:31 PM | #8 |
Speed Demon
205
Rep 3,690
You can't go flash tune on your CS (right now, unless you wanted to send your ECUs to Russia), so there's that, too.
Current: '21 M5C, '15 X6 50i Previous: '18 M550i, '16 550i, '11 335is, '09 E93 M3 DCT, '10 E90 335d, '07 E90 328i |
03-30-2022, 06:37 PM | #9 | ||
1658
Rep 1,536
If something happens to your motor, and BMW digs in, they will see all the data and know that you were tuned, warranty goodbye…. |
03-30-2022, 07:08 PM | #10 | |
224
Rep 211
03-30-2022, 10:50 PM | #11 | |
775
Rep 569
I have a question in regard to how these piggy backs work, and possible warranty voiding case to fight... Need some input from others... Is something like RaceChip basically tricking the boost pressure sensor? To give it more boost? Im sure there is more to it than that. But my point is this: If I go into service, even oil changes, or minor things, I pull the entire racechip out, unplug and remove completely. So it wont be flagged. But, if BMW were to dig in and see increased boost, and couldn't prove you plugged in racechip, wouldn't it be hard to prove the racechip ever existed? Obviously it would see increase boost pressure, obviously caused by Racechip which we know... but wouldn't a pretty viable defense be, to ask if there is ANY POSSIBILITY AT ALL, that the boost sensor could be failing, or acting up. Could BMW GUARANTEE with out a shadow of a doubt, that the boost sensor didn't fail? Or intermittently fail? Or some other sensor or aspect of the car cause the discrepancy? Wouldn't they have to prove with out a shadow of a doubt you altered the car, and that there was NO way it was a system malfunction causing the increased boost? With a flash tune, I imagine this could be easier to prove. With a piggy back, its just tricking sensors correct? ECU stores the data, but what caused the data to read that way, is what would be in question right? Malfunction? Racechip? They'd have to prove it was a Race Chip causing the increased boost, I would have to think. One more thought.... On cars like the CS where is the extra power coming from CS from Comp, and Comp from Base? Is there added boost? Would be interested to know what the difference between the models is. Engine tuning , Engine internals? Other items? Only wondering because, if all the internals, engine, everything is the same, and it's simply tuned differently. A good lawyer could argue that BMW basically increased power on those cars with guess what... a TUNE, but those warranties arent affected? LOL. Im not a lawyer, but could be a good argument and food for thought. Asking for a friend of course and it's very possible there is a lot more to the racechip than tricking a boost pressure sensor. I legitimately don't know how they work. |
03-31-2022, 06:16 AM | #12 | |
Rep 28
03-31-2022, 09:59 AM | #13 | |
1718
Rep 1,639
DM me when you're going to run at the track. I want to see this ! |
04-01-2022, 10:51 AM | #14 | |
30
Rep 156
True but they send it to Russia, not sure it will ever come back with what's going on over there right now. I considered it for my new m8 and was told they are not sending any new one's and are "hoping" eventually it will calm down. Mission in cali says they are beta testing an in house flash, so fingers crossed for those willing to go flash vs piggy. |
04-01-2022, 04:02 PM | #15 | ||
366
Rep 436
You'll get caught either way. When you mod your car, you just pray that nothing fails. If it does, they will dig in and see. |
euro*1657.50 |
04-01-2022, 04:10 PM | #16 | |||
Rep 28
04-01-2022, 04:15 PM | #17 | ||||
366
Rep 436
I have tuned every car I have ever had and never had my warranty blown. I have also been fortunate that I never had a major issue. Removing the jb4 or bm3 or Rc won't do anything. When they get to digging, they will find what they need. This topic has been covered many times on this forum. Don't be misinformed. |
04-01-2022, 04:18 PM | #18 | |||||
Rep 28
04-01-2022, 04:21 PM | #19 | ||||||
366
Rep 436
CarEnthusiast2932.00 |
04-01-2022, 04:22 PM | #20 | |||||||
Rep 28
GranitM5366.00 |
04-01-2022, 09:53 PM | #21 |
420
Rep 862
I was checking out tunes and now can't remember...which one has a valet mode?
Very appealing to me, I hate handing my car over to valets...
04-02-2022, 02:02 AM | #22 | ||||
119
Rep 96
