11-17-2019, 05:19 AM | #45 | |
1571
Rep 29,202
16x6.5 ET22 17x7.5 ET30 18x7.5 ET25 19x8 ET27 20x8 ET27 And all staggered rears are 8.5" wide with ET40. This is the complete list of wheels for all G20, not just the 330 and M340 in NA.
Auditobimmer4250.50 |
11-22-2019, 09:24 PM | #46 | |
1071
Rep 4,856
12-16-2019, 01:22 PM | #47 |
43
Rep 95
06-03-2020, 06:22 PM | #51 |
Rep 30
Installed 15mm in the front and 12.5mm in the rear from ECS tuning a couple weeks back, but didn't get around to taking pictures until last weekend.
Staggered setup, 225/45/18 front, 255/40/18 rear. Goodyear eagle F1 tires. I like the way it turned out. |
06-04-2020, 01:07 AM | #52 |
11
Rep 36
Thanks for posting these awesome pics but it would really help if you put what wheel setup you have. Are they square or staggered? I have the 19" square setup with 225's. 👍
06-04-2020, 09:10 AM | #53 |
Rep 30
06-24-2020, 05:12 PM | #54 |
24
Rep 71
If I'm running the square 19" wheel set-up (225/40/19) all around, would 15mm spacers front/back look too aggressive? Or just right? I'm lowered on DINAN Springs and looking to be as flush as possible. Thanks!
Current: BMW ///M340i
Previous: BMW 335i, Audi A4, Honda Civic |
Dravit Goose1.50 |
07-01-2020, 05:56 PM | #55 |
19
Rep 80
KW Coils V1 & Spacers
For anyone doing coils I'm running
Kw coils v1 Front: 10mm spacers 235/35/19 Back: 13mm spacers 265/30/19 Tires: Michelin Pilot 4S Here's what it looks like! I could have definitely went a bit wider but this felt safer |
///Mobbin1478.00 |
10-14-2020, 01:25 PM | #56 |
57
Rep 215
I've been using 15mm rears from dsx-customs (https://www.ebay.com/str/dsxcustoms) for the past 10 years with no issues...I just ordered a new pair as the F90 ones (5x120) don't work on the new G20 (5x112)...they stick to the hub ( I like they only have 5 holes) and stay secure on the lip...very good quality and as a bonus a bit cheaper the others...
Also, as a personal choice I use 15mm on the rears with no spacers up front...I find it gives the car a more aggressive look and also eliminates (potential) vibration issues...on my wife's Audi I had no choice but to put F/R as it's 4x4 - but then she doesn't abuse the car as much Last edited by rockblock; 10-14-2020 at 02:10 PM.. |
10-15-2020, 08:20 AM | #57 |
Rep 3
Hello,
I am Hajo from Germany and have registered here today. Unfortunately I am not allowed to attach pictures yet, but I will post my G21 with Eibach springs and spacer plates 13 / 15mm soon. See you soon, Hajo |
11-25-2020, 11:22 AM | #58 |
65
Rep 82
Here's some 13mm on 8 inch rims with 245/40/19. No lowering.
WolfpackCO163.00 |
12-06-2020, 12:20 PM | #59 |
243
Rep 287
Drives: 2023 bmw m3 comp xdrive
I have 15mm burger spacers front and rear ...Absolutely no issue
01-08-2021, 05:06 PM | #60 |
Eyeball
32
Rep 34
What is the other sizes when looking for spaces not the thickness ?
Why look back, that?s done !!!
01-11-2021, 08:56 AM | #61 |
Rep 1
EngineDriver, Been following your tire and now spacer journey. I also have an 8'' square setup on my M340 and looking to do the exact thing you did with 245/40/19 tires all around and 13mm spacers, I just wanted to ask... how does it drive? any issues so far at all?
02-01-2021, 09:05 AM | #62 | |
768
Rep 430
Staggered setup - 225 front (19x8.0) and 255 rear (19x8.5) or 225 square? |
02-21-2021, 10:16 AM | #63 |
Rep 1
Wheel Spacers Help
hi all,
im currently on 19x8.5 ET35 19x9.5 ET 45 Staggered set up tires profile 245/35/19 275/30/19 lowered with eibach can anyone advice me on how thick the spacers i should get for my wheels? Last edited by vtt30; 02-21-2021 at 11:08 AM.. |
02-21-2021, 11:11 AM | #64 | |
2360
Rep 2,964
Use a yard stick or something similar to establish a straight point from your wheel arch/fender to the ground. You can then use a ruler or similar to measure the distance from the yard stick to your tire to establish how many MM you need to obtain a 100% flush fitment. From there you can decide if you want to add or subtract a couple MM to establish the look you are after and then order spacers accordingly. BMS, Macht Schnell and Dinan are popular spacers here on the forum and all three come with extended bolts Hope this helps...looking forward to pics |
02-21-2021, 04:52 PM | #65 |
Jewel Runner
332
Rep 911
245's on 8" rim? What brand/model of tire?
02-21-2021, 04:58 PM | #66 |
291
Rep 441
