07-17-2010, 02:53 PM | #1 |
125
Rep 778
Heads up display and polarized sunglasses
I recently found out that BMW'S HUD does not work at all with polarized sunglasses. We were trying to figure out why we couldn't see it even though it said it was on. Took off the sunglasses and it popped right into view.
Has anyone else noticed this problem? We asked the BMW Ultimate Driving guys about it and they had no idea that it did not work with polarized glasses. |
07-17-2010, 07:07 PM | #3 |
14
Rep 162
I've had issues with polarized lenses since my E60 550i. There's no issue with any of the displays in the car except for the HUD (which almost disappears). My solution was to buy a new set of frames and have non-polarized lenses made up for them.
Although I prefer polarized lenses I would much rather be able to see the HUD. As an aside this is also an issue with the radio display in the non-nav E9x cars. Every time I get a loaner the radio display is invisible.
'12 Alpina B7 Alpina Blue/Black
'11 1M Coupe Alpine White '11 M3 Coupe Silverstone/Black (sold) '08 M6 Coupe Stratus/Black '03 M5 Sedan Imola Red/Black (sold) |
07-17-2010, 08:48 PM | #5 |
Rep 14
07-19-2010, 09:06 AM | #7 |
26
Rep 865
Drives: 2018 F15 X5 xDrive35d
There was a thread here somewhere about some little piece of adhesive plastic film that you tape over HUD, and then you can see it even with polarized lenses...
07-19-2010, 09:45 AM | #8 | |
Sideways
Rep 46
07-20-2010, 08:59 PM | #9 |
Bimmerpost Resident Marijuana Consultant
448
Rep 3,195
Drives: 320i, 325xi, 335Xi, 335i, M3
Garage List 2010 BMW 335i [0.00]
2011 BMW X335i [0.00] 2006 BMW E90 325xi [0.00] 2011 BMW E90 335xi [4.00] 2011 BMW M3 E90 [7.00] 2006 E90 320i [0.00] |
couldnt you apply the film to your glasses if you wanted?
"AMG What! S-Line Who? If you ain't got that M I got no respect for you!" '06 Alpine Weiss E90 320i | '06 The Green Machine E90 325xi | '11 Alpine Weiss E90 M3 ZCP | '10 Silverstone X5M | '11 Alpine Weiss E90 335xi |
07-25-2010, 10:49 PM | #10 | |
Rep 1
No offense meant to you at all - they're trained not to wear polarized glasses. You aren't. Just get glasses that don't have polarized lenses. Easiest option. :-) |
07-26-2010, 11:19 AM | #11 | |
Rep 20
I know what you mean HUD and pilots dont always go well. but now, I'm used to it and I cant imagine to start a approach without HUD:P. but every professional pliot knows not to use polarized glasses, some airliners just ban then from the cockpit. |
07-27-2010, 06:53 PM | #12 |
437
Rep 2,747
LINK TO 07 IR PHOTO JOURNAL:http://www.zpost.com/forums/showthread.php?t=1303735
LINK TO 06 IB MOD JOURNAL:http://www.zpost.com/forums/showthread.php?t=403119 |
07-30-2010, 07:02 AM | #13 | |
Rep 114
biggles |
07-30-2010, 08:18 AM | #14 |
46
Rep 884
Drives: 2007 BMW 335i
If you think of light as a having two axes, and x-axis and a y-axis, then a polarizing filter (sunglasses) will generally removed most of the light in one of the axes. So after the filter you are left with light in only one of the two dimensions (and typically 50% of the initial light intensity). If you then run the polarized light through another polarizing filter at 90 degree angle to the first, all light will be blocked (if the filter is at the same angle, no light will be blocked).
You can test this by taking two pairs of polarized sunglasses, lining up the lenses of the two, and then rotating the sunglasses relative to each other so you see through one lens of each pair. At some angle, they will block most or all of the light. The first blocks light along one axis, the second blocks it along the other. The reason that polarized sunglasses essentially negate the HUD is because the reflected light is mostly polarized. The reflected light coming from the HUD is polarized orthogonal/opposite to the sunglasses, so that light is completely removed by the sunglasses (unlike most other ambient light which is not polarized, of which only a portion of the light is removed by the polarization and tint). If you tilt your head sideways 90 degrees, I bet the HUD shows back up because now you are aligning the axis of the polarized sunglasses with how the reflected light is already polarized. This is the same with the radio displays, where if you tilt your head you can see it again. The reason that putting something like transparency film (oriented correctly) over the radio display helps is that it changes the angle of polarization so that the sunglasses don't filter all the light anymore. My guess is that all polarized sunglasses are designed with the same axis of polarization because most reflected light (i.e. of the water, etc) is not what we want to see and is usually polarized the same way... so sunglass manufacturers choose the polarization axis to kill those types of light. Anyway, not the most eloquent, and maybe not completely correct, but the general idea should be about right.
Current: 2007 335i sedan
Alpine White | Sports | Premium | Cold | Comfort Access FORMERLY: 128i coupe Alpine White | Sports Package | Black Leather |
