F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > BMW Coding Database
Studio RSR
      02-27-2014, 09:45 PM   #67
sdellutri
Drives: 2014 F32 435xi
Really great tool.... thanks!
I was able to run this on my Windows 8 system and was poking around to see what it could do. I selected File->Offline mode and program immediately crashed. From that point forward , I could not start the application. I uninstalled, and re-installed and still no luck.
I searched around for leftover configuration (in files or registry) and found in folder
C:\Users\USER\AppData\Local\BMW_Coding_Database\** *******Database.exe_Url_btajmppliulum3aji4oez1xsfb wzorpg\1.2.0.0
the file
user.config
which is a text based XML file.
I edited the file and changed
<setting name="OfflineMode" serializeAs="String">
<value>False</value>
from True to False
then I was able to launch the application again.
I am not sure I understand what Offline mode is intended to do, but it doesnt work on my setup. Hope this info is helpful in resolving the problem and for other users who may have got stuck in this unusable condition.
thanks again! great tool!
      03-04-2014, 12:20 AM   #68
Frogman
Drives: 2012 F30 328i
the file
user.config
from True to False
Thanks for this, I ran into the same issue with the current version of the database tool, running on Windows 7.
It seems that off-line mode is broken.
      03-04-2014, 07:50 AM   #69
PandaNL
Netherlands
22
Drives: F30 330e & E92 335i
Can u try to delete the bmw coding database folder under appdata\local, then install using the latest installer from *********database.com. Run the application, and finish the initial setup. Click get data on f-series tab and e-series tab and close the application.
This should create the offline files under C:\Users\USER\AppData\Local\ named Fseries.xml and Eseries.xml
Start the app again and try offline mode.
      03-04-2014, 12:50 PM   #70
Frogman
I uninstalled the app, removed the folder from appdata\local, and re-downloaded the app (version 1.2.1) and installed it. It wanted to update to 1.2.2 beta, which I did (I think the update said something like 1.3...).
Off-line mode is now working, I have pre-loaded E and F series codes.
The file names are a little different: Fserie.xml and Eserie.xml (they are missing the ending 's') and are stored in the root of C:\Users\XXXX\AppData\Local, not in the *********Database directory.
Thanks!
      03-04-2014, 05:31 PM   #71
PandaNL
Netherlands
22
Yeah it is indeed, Fserie and Eserie didn't had time to check it.
The reason I did this is so that you get the latest offline files, but you have indeed get the data on the first launch of the application.
      03-04-2014, 06:02 PM   #72
Frogman
Right, but shouldn't those files go into the *********Database folder and not the ApPData/Local root?
      03-07-2014, 04:01 AM   #73
PandaNL
Netherlands
22
Yes, they will be in the next update. I will also supply default offline files for first startup to prevent any errors.
      03-07-2014, 10:48 PM   #74
VIEW200
Drives: 320I
Hi Guys
I am new owner of a 320I and interested to activate extra features.
Could you please let me know what i need to start with (i mean cable, software etc.), is there any step by step procedure?
      03-07-2014, 11:22 PM   #75
shawnsheridan
shawnsheridan's Avatar
Drives: 2018 Alpina B6 650ix GC
Originally Posted by VIEW200 View Post
Hi Guys
PM sent.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
      03-08-2014, 02:53 PM   #76
Derrymilk
Occasional Lurker
Derrymilk's Avatar
190
Drives: F87 M2 Competition
Originally Posted by shawnsheridan View Post
PM sent.
Hi, any chance you can send me the info too. Got a few bits I'm looking to add to my M-sport
Thanks
      03-08-2014, 04:57 PM   #77
shawnsheridan
Thanks
PM sent.
      03-09-2014, 06:18 PM   #78
Derrymilk
Occasional Lurker
Derrymilk's Avatar
190
PM sent.
Thanks. Will look into it this week
      03-14-2014, 08:11 AM   #79
PandaNL
Netherlands
22
V1.3.4 is out now that fixes the offline files problem.
      03-14-2014, 08:36 PM   #80
Pommie335i
Pommie335i's Avatar
Drives: 335i AW M-Sport 2012
Thanks
PM sent.
Hi there,
Any chance I can jump on this bandwagon and get assistance with coding my E92 335?
Thanks Shawn,
Gary
      03-28-2014, 05:08 AM   #81
BMWSKI
BMWSKI's Avatar
167
Drives: E63 AMG Saloon :)
Why can I no longer open the coding database successfully and what can't I connect / check for updates? I am running v1.2.2...
Any help would be appreciated or a link to the updated version would be awesome
      03-31-2014, 07:00 AM   #82
PandaNL
Netherlands
22
http://*********database.com for the latest version.
      03-31-2014, 11:52 AM   #83
sahajesh
sahajesh's Avatar
United Kingdom
2294
Drives: 2021 G05 X5 40i Tanzanite Blue
Corrupted URL
      03-31-2014, 04:41 PM   #84
PandaNL
Netherlands
22
This forum censors the words bmw and coding together.
      03-31-2014, 06:32 PM   #85
sahajesh
sahajesh's Avatar
United Kingdom
2294
Aha thanks!
      05-15-2014, 01:34 PM   #86
Shen23
Drives: F32 435i
THanks for sharing!
      05-20-2014, 12:12 AM   #87
Mr609
Drives: 2008 328xi e92
Originally Posted by Pommie335i View Post
Hi there,
Thanks Shawn,
Gary
Me 3
      05-20-2014, 05:38 AM   #88
shawnsheridan
Originally Posted by Mr609 View Post
Me 3
PM sent.
f30post
