      06-09-2008, 08:07 PM   #23
Kris
123
Drives: m3
Originally Posted by wrongprotocol View Post
nice color choices :-p it actually bothered me that I only had yellow, I wanted white to match the rest of the car haha!
OT: Dude, why are does your signature have a picture of you without your shirt?
      06-10-2008, 02:47 PM   #24
Peakrunner
Mile High Member
Drives: 2012 x5d
He's here to PUMP YOU UP!
I believe in Karma. That means I can do bad things to you all day long and assume you deserve it
      06-10-2008, 06:38 PM   #25
Kris
123
Drives: m3
Ah huh! I see
      06-28-2008, 12:56 PM   #26
hansenc
1addict, and proud
hansenc's Avatar
16
Drives: 128i
2008 128i  [0.00]
Alright I joined this mod today, I found that the 5/16th vacuum plug didn't stay in the actuator so I went back and bought one size down 5/32. This fit nice and wasn't loose at all. now for the tube I left the 5/16th male to male plug and the 5/16th plug on it. it was tight getting on there so it might stretch out the hose to the point where it won't stay on the actuator if I ever reverse the mod but if thats the case I will just cut a little off the hose.
Just thought I would share. Maybe the 135i and the 128i have a different size.
      06-28-2008, 09:49 PM   #27
wrongprotocol
wrongprotocol's Avatar
Drives: 128i MT, white
because i just moved to FL and i'm not used to it being so hot, and i was outside for a while washing the car/mowing the lawn
      06-28-2008, 10:26 PM   #28
hansenc
1addict, and proud
hansenc's Avatar
16
Drives: 128i
2008 128i  [0.00]
A lil off topic...
Where did you get your windows tinted? Look good, whats the %?
      07-15-2008, 03:36 PM   #29
ronnyek
Drives: 2010 Evo MR Touring
I gotta say I dont really notice *ANY* difference and I am the type of guy that noticed EVERYTHING... I did it at 100mi and were at like 138 now or so... idle sounds the same, only thing I noticed is it has SLIGHTLY more grown starting off from a stop for like 1sec
Yes the valve is open.
      07-15-2008, 04:24 PM   #30
blklacker
blklacker's Avatar
50
Drives: 135i
If you don't notice a differents try this. Reconnect the vacuum hose originally... start the car... Move to the rear of the car and disconnect the vacuum hose while the car is running.. you will hear the valve open and a slight increase in sound and exhaust flow from the rear. someone should do a dyno but its really not worth it to me.
-135i BSM, CRBL ,custom front lip/Indianapolis red fade, blacked out tail lights/corner headlights, golf tee, BMS Air intake, SSTT, CF spoiler,Powdered coated OEM rims gunmetal high gloss,custom Rear diffuser Black/Indianapolis red fade
      07-16-2008, 08:44 AM   #31
Qube
34
Drives: E39 540 :: 09 STi
Let it warm up a bit, then you'll notice a good change in sound. When cold, I don't hear much of a difference.
      07-20-2008, 12:59 PM   #32
JC Jai
E.I.T
Drives:
so what is the diameter of the hose itself ?
      07-21-2008, 01:33 PM   #33
backtoreality15
backtoreality15's Avatar
Drives: 2019 330i
1. Is it just me or is the vacuum plug really hard to unplug? (I tried pretty hard, but I didn't want to pull any harder for fear of damage. I just ended up using a zip tie)
2. Are there any negative MPG implications of performing this mod? :iono:
2019 M-Sport 330i | G20
      07-21-2008, 02:49 PM   #34
ronnyek
thats a rubber hose thing... just try and twist it a bit aruond the fitting get it to break loose, then give it a tug.
Gas mileage implications should not be noticable.
      08-02-2008, 03:00 AM   #35
123D-M
123D-M's Avatar
Spain
32
Drives: BMW 123d M-Sport Coupe
hmmm wonder if this would work on a diesel
possibly I don't want to hear the engine more...
2009 123D Coupe | Sedona Red | Black Boston Leather | Brushed Aluminium Trim | Tinted Windows | M-Sport Package | 6M | Comfort Access | Heated Seats | Navigation | Park Distance Front & Rear | USB | Bluetooth | Voice Control | Efficient Dynamics | Rain & Light Sensors | Xenon Lights
My blog: http://urbanemusings.wordpress.com/
      08-03-2008, 12:03 AM   #36
1Ronnie
Ronnie
1Ronnie's Avatar
15
Drives: '08 Sedona 128i
I just did this today with a plastic cable tie, bent the hose, and put a loop of the cable tie over the bent hose, and tightened it. As for change, I didn't notice anything at all just idling, but when I was out, I was pulling out of a carpark at around 1100 revs, and the resonance just came out of it. My wife noticed it, and thinks it sounds great.
So now I have to decide between all the windows and sunroof open and the great engine noise, or everything closed up with the great audio from the Premium sound ... aaahhh choices choices !!!
:roundel:
"Lucy"
128i / Sedona Red / Coral Red / Premium Package / Premium Sound
      08-03-2008, 05:45 PM   #37
akak1997
akak1997's Avatar
64
Drives: BMW 135 @ 135mph
2008 135i  [0.00]
Hi, I's trying to do this mod just now. but the 3/16" vacuum cap is too big for the nipple on the actuator. Is it necessary to plug the actuator nipple (i.e. if I don't plug that, will the flap be permanently closed instead of opened?)
Thanks
      08-10-2008, 06:13 PM   #38
d3syd
d3syd's Avatar
Australia
50
Drives: 135i MT, LMB, ProNav
2008 135i Coupe  [0.00]
Im really confused......
Sorry guys this topic has be discussed ad nausium but this is what I have observed and the way I see it:
When you start the car cold, the flap is closed and exhaust gas exits from only the left (?) pipe. After a little while the flap opens with a little klank noise.
I find that with the flap closed (in the short period after initial start up), idle actually sounds deeper with the one pipe than with both pipes are open.
Now FIRSTLY if you were to disable the flap with the golf tee mod, you are going to have both pipes open all the time, to me this = quieter idle. SECONDLY, the default position of the flap after a few minutes is OPEN anyway, so why bother with the mod?:iono::iono:
So basically what I'm saying is with no mod, I get a deeper idle at start up (one pipe operating), and then after a few minutes once the flap opens (two pipes operating) I get exactly the same thing as a modded car.
I really appreciate comments on this one please....
Fun Car: 135i Manual LeMans Blue / Beige Leather / Grey Poplar / pro nav / euro plates. Delivered 24 June 08
Family Car: Land Rover Discovery 4 SDV6
Spare Car:
Volvo V70 Sydney Car: MB 420SEL
      08-10-2008, 07:49 PM   #39
WhiteOne
Drives: 2008 AW 135i
At idle all the exhaust runs through the full muffler and out the rightside tip. Once you rev the motor the valve opens and allows some of the exhaust to "bypass" the muffler. The golf tee mod allows you to stay in the "bypass" mode all the time. Since the turbos keep the exhaust quiet not much of a muffler is required.At least that is how I understand it. I could be wrong...
      08-10-2008, 08:46 PM   #40
TP 135i
TP 135i's Avatar
Drives: 2008 135i SGM MT
The valve doesn't open with temperature, it opens with rpm. Even with the engine up to operating temp the valve is closed until you get over 3000 ish rpm.
2008 135i SGM
      08-10-2008, 10:35 PM   #41
d3syd
d3syd's Avatar
Australia
50
No I don't think that is the case. When I first start up, there is definitely only one pipe working, after a short time, while still idling, the valve opens and both pipes emit exhaust gas. So it is not rpm driven on my car at least. Can you check if this is the case with your car?
If what you are saying is correct, then whenever rpm drops below 3000, only one pipe is working. No so.:iono:
Spare Car:
      08-19-2008, 04:48 PM   #42
imported_mega
123
Drives: various bmw's
my car keeps that valve closed at idle, even when warmed up
      08-19-2008, 05:19 PM   #43
ronnyek
I am certain mine did too, but in any case who the f cares... I absolutely positively noticed exhaust being a slight amount louder... better enough to spend a ton of time doing the mod? Probably not, enough to spend 5 seconds the mod takes to do? Absolutely.
      08-19-2008, 10:47 PM   #44
AlpineWhiteMan
Drives: 2008 BMW 135i
Is there any diff between the cable tie method and the disconnect/plug method?
135i Apine White, Sports Pkg, 2 JL Audio 10W6s, JL 1000/1, Juicebox 1, Carbon Fiber Mirror Caps
