      04-18-2012, 03:21 PM   #221
Golden3ye
Golden3ye's Avatar
499
Drives: 2020 BMW M2 CS
this is a old post, just curious if the same method will work on a N55?
2020 M2 CS | Black Saphire Metallic | DCT / CCB
SOLD:
2012 135i | Le Mans | 6MT
1986 535i | Cirrus Blue Metallic | 5MT
      04-27-2012, 04:10 PM   #222
bradleyland
TIM YOYO
Drives: 2013 M3
Yes, the N55 uses the same vacuum controlled flap in the exhaust.
His: 2019 R1250GS - Black
Hers: 2013 X3 28i - N20 Mineral Silver / Sand Beige / Premium, Tech
Past: 2013 ///M3 - Interlagos Blue Black M-DCT
Past: 2010 135i - TiAg Coral Red 6MT ///M-Sport
      05-10-2012, 12:08 AM   #223
J-Sin
The Artist
J-Sin's Avatar
Drives: 2011 E90-LCI & 2008 E82
2008 BMW 135i  [0.00]
2011 BMW 328i  [10.00]
ok, i've searched and searched, is there an image of how you ziptied the line?
Did you kink it first then zipped the kink or just zipped it tight enough to cut off the flow? Do you do this while the car is off or on? I want to do the Zip tie mod =)
Betty White - 2011 E90LCI 328i - SOLD
Black Betty - 2008 E82 135i
      05-10-2012, 02:09 AM   #224
Nugget
Nugget's Avatar
650
Drives: G81 M3 Touring, GR Supra GTS
2011 BMW 135i  [10.00]
I think you can do either.
I kinked and zip tied the kink so it would be easier to cut off if I wanted to.
Don't think I'll be doing that
      05-10-2012, 01:11 PM   #225
bradleyland
TIM YOYO
Drives: 2013 M3
Kink and zip tie. I'm not sure you could pinch the line hard enough just by placing a zip tie around the circumference.
      05-10-2012, 08:52 PM   #226
J-Sin
The Artist
J-Sin's Avatar
Thanks figured it out when I got down there and actually took a look at it. A little bit of a distinct difference.
      07-08-2012, 05:43 PM   #227
erabmw135
erabmw135's Avatar
Drives: 328i
Trying it tonight
      07-09-2012, 08:29 AM   #228
bradleyland
TIM YOYO
Drives: 2013 M3
How'd it go?
      07-16-2012, 10:39 PM   #229
erabmw135
erabmw135's Avatar
Drives: 328i
Great!! Sounds good very simple.
      07-29-2012, 07:32 PM   #230
dorkdog
Big Mouth No Filter
dorkdog's Avatar
Drives: 128i Montego Blue 6MT Sport
Me too... almost 3 years later!
Originally Posted by imoz View Post
I did this on Sunday... I used a zip tie. Simple! It sounds mean, I love it.
Me too. Noticed a diff immediately on my 128.
We do not inherit the Earth from our parents; we borrow it from our children
      07-30-2012, 12:33 PM   #231
katsooba
katsooba's Avatar
85
Drives: bmw 135i
btw guys, no need to get under the car
you can also do it from inside the trunk with 3 mins of work.
135i N55 / KW V3 / MHD Flash / Tons of grip mods / CP-E charge pipe / CP-E 7" FMIC
      08-03-2012, 12:22 PM   #232
ve3cnu
Drives: 2011 128i E82
How is this done inside the trunk?
      08-03-2012, 12:42 PM   #233
WPG D33Z
23
Drives: 2008 135i vert Cobb Stage2
Took me 30 seconds with a zip tie under the car. No need to jack it up just poke your head under there.
      08-04-2012, 10:13 AM   #234
ShocknAwe
1Addict
ShocknAwe's Avatar
3234
Drives: E82 Mutt, M57 Truck
Did the mod this morning. Used a 3/16" plug, 3/16" male to male connector, and 5/16" plug in the actuator. Tucked the vacuum line in one of the pockets on the inside of the bumper cover.
Dunno how people can't hear the difference. Sounds great, and I love the burble too!
2010 135i 6MT Jet Black
N54/3 FE82 Mutt | BUILD THREAD | GARAGE SALE
      08-04-2012, 12:30 PM   #235
katsooba
katsooba's Avatar
85
Drives: bmw 135i
no need even to get under the car
just pop the left inner lining around the brake light and find a connector like this
just do what he does in this video
      11-27-2012, 02:13 PM   #236
Bob Z.
Drives: 2013 135i Vert
Silly question: if the line becomes unplugged what indications would be present? CEL? Strange radio changes?
      11-27-2012, 02:33 PM   #237
bradleyland
TIM YOYO
Drives: 2013 M3
I believe you'll end up with a CEL if you unplug it altogether. This flap is vacuum operated, and the vacuum system on your car is largely "common" (meaning all the parts are interconnected), so you'd lose vacuum if you just unplugged it.
That's why the original mod involves plugging a golf tee in the end of the tube: to prevent loss of vacuum.
I doubt you'd notice anything in your radio though. That'd be really bizarre.
      11-27-2012, 02:42 PM   #238
Bob Z.
Yeah, I did not buy the radio thing when I read it in another thread; however, it seemed the volume went up & down slightly. But I had not eaten all day and combined with back meds I am amazed I did not hear other weird things.
Anyway, what I was getting at is I had the Berk Race cat-back exhaust installed yesterday and the tech had a problem getting the supplied screw in the tube so I wondered what symptoms I would get if the seal was not tight, or the screw came out.
      11-27-2012, 03:21 PM   #239
bradleyland
TIM YOYO
Drives: 2013 M3
I think that all BMWs come with an adaptive volume control that adjusts the volume based on speed. As you go faster, the volume goes up. Whoever did the install might have adjusted this setting to "do you a favor". A louder exhaust can make it difficult to hear the stereo.
      11-27-2012, 03:22 PM   #240
bradleyland
TIM YOYO
Drives: 2013 M3
Also, I would get that vacuum tube plugged. You don't want crud getting sucked up in to your vacuum system. There are diaphragms and stuff that can be damaged by contaminants.
      11-27-2012, 03:28 PM   #241
Bob Z.
I'll have to drive the car again and listen closely...I am aware of the speed compensating volume but it still seemed to vary at constant speeds. But I guess I can rest assured the line is still plugged since there are no CELs or other symptons (so far) and the car sounds great with the Berk Race and BMS Intake.
      12-02-2012, 12:21 PM   #242
JM_128
Drives: 128i with M Package
Is that mod on the video also for the 128i?
