Go Back   7Post - 7 Series Forum > BMW 7-Series Forums > (G11) 7-series General Discussions
      04-23-2024, 07:33 PM   #1
7fitty
Drives: 750
Does lowering via ISTA stick?
Lowered the car via ISTA this past weekend. 20mm a corner.
Looking at it today, it absolutely looks to be raised back up.
I haven't measured again, but I would bet money its back to normal.
Anyone had this issue?
      04-23-2024, 10:48 PM   #2
M_Bimmer
M_Bimmer's Avatar
588
Drives: G12 B7, G07 XB7, F02 B7, 991.1
ISTA has limit on the allowable reduction in height....I don't remember the value, but 20mm is the number that comes to mind....I'd have to fire up ISTA this weekend to check for you...but someone can weigh in to support or correct this claim.
It may try and lower, if the exceedance of the allowable adjustable range occurs, it will only cause the vehicle to use the previous "valid" values, not the new ones you entered....e.g. your new height adjustment will not "stick"
      04-24-2024, 10:13 PM   #3
forrby
Drives: BMW 530e (G30), 528i (E60)
If your looking to lower your car I would highly reccomend the CETE lowering module: https://tagmotorsports.com/cete-ble-...owering-module
It's a little pricey but it's been an absolute dream! You can lower your car down to -55mm and raise it to +30mm. I used to have lowering springs on my G30 5 series and now it seems like such a cave man thing to have your car lowered ALL THE D*MN TIME. With the module you can even save the lowered height for different modes. Like sport mode can have a lower ride height than comfort. There is also show mode where you can lower you car to -60mm.
7post
