BMW X5 and X6 Forum 2014-Current
      01-23-2023, 05:43 PM   #331
Qsilver7
Qsilver7's Avatar
Drives: F06 650ix GC / F15 X5 50i
Originally Posted by ArthurMorgan View Post
Is it possible to leave GFHB enabled but disable VLD?
I honestly don’t know. But if anyone does…it would be the “coding masters”…see if you can find any mention of coding one and decoding the other (VLD) on the coding forums.
Good luck.
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral.
      02-02-2023, 05:09 AM   #332
Almaretto
Almaretto's Avatar
2376
Drives: Test Vehicles
Good luck.
They are independent options and can be enabled or disabled separately; though not sure why someone would.
      02-02-2023, 09:49 AM   #333
ArthurMorgan
Right to Repair Enthusiast
ArthurMorgan's Avatar
95
Drives: '17 X5 M
For what it's worth, I've gotten acclimated to it at this point. Before coding on the GFHB and VLD, I had a habit of turning the fogs on because I thought it looked nicer at night. I think I was just used to all of that light dumped directly in front of the car. It's really not as bad as I felt it was, it just takes some getting used to.
      02-22-2023, 01:43 AM   #334
irzayev
Drives: BMW X5 F15
Hi, where can I download latest working ESYS Cheat Codes to do automatically step2/3?
      03-03-2023, 02:23 AM   #335
Almaretto
Almaretto's Avatar
2376
https://github.com/packetpilot/bmw-f/tree/master/cheats
      03-07-2023, 06:42 AM   #336
lauritzm
lauritzm's Avatar
Drives: 2017 BMW X6 xDrive50i
Originally Posted by Almaretto View Post
Thanks!
      03-31-2023, 09:33 AM   #337
irzayev
Drives: BMW X5 F15
Coded, seems working, but one question,
i just don’t remember if it was same previously
So:
If headlighs (lowbeam) on
And I turn on fog lights
Left(driverside) headlight changes focus to left(moves focus to left)
upd: Read the thread and found that it's ok.
But is there any way to have both hump (drivers and passengers sides) without Fog lights? I think yes, but what do I need to code?
Seems need to change some settings in FLE
      07-03-2023, 03:49 PM   #338
radioshackguy
Drives: 2009 335i
Amaretto, thanks for everything you have done to make this stuff possible. A quick question on my end. I have a 2016 40e which I notice that my FLE passenger side seems to be refusing FDL coding for a few register values. This was mentioned earlier in this thread where the value are coded, cheat sheet or manual, and then after rereading the values, I get an unknown for the first byte. This is always 14 rather than 04 for say Stadt_V_Idx position 1. You worked with another member on this issue, but I'm not sure if there was resolution. Based on some of the issues I've seen with the VLD coding and GFHB, I think for now I am going to revert to stock. I'd rather have good even light output rather than sub performing headlights that may do more harm than good. Just to confirm, the coding worked exactly as desired for driver side. Passenger side registers seem to be the only issue.
      07-04-2023, 05:27 AM   #339
irzayev
Drives: BMW X5 F15
Hi, after activation of VLD and GFHB my KAFAS2 shows Speed Limit info but didn't show me "overtake prohibited" sign.
Any ideas?
      07-08-2023, 07:47 AM   #340
Variante Alta
Variante Alta's Avatar
96
Drives: 2015 X5d M Sport Metallic Whit
Any ideas?
I did this coding for the LED headlights a couple years back - love the option! I also coded for SLI and TJA - when completing that task I recall that there are a couple ‘HUD’ settings for the ‘overtake prohibited’ indicator as well which I enabled - it works fine (both on the dash and in the HUD) even here in Canada where we don’t really have official zones like that (it comes on mostly on freeway off-ramps and on-ramps). Search for the HUD settings and do some looking at them (I don’t recall the specific name) - perhaps they got disabled when you coded. Sometimes these things just need a couple days to start working correctly again after coding. Hope that helps.
      04-12-2024, 05:31 PM   #341
david_594
Drives: 2016 BMW X5 40e
I'm many years behind here as I just realized this was a codeable option on my F15.
Has anyone done with BimmerUtility?
      04-29-2024, 01:57 AM   #342
tonyec7
19
Drives: 228i M Sport
Hi there! Looking for someone to be able to code this remotely. Pls PM
      05-03-2024, 06:44 AM   #343
m4forum
85
Drives: M3
does anyone has the step by step to enable anti dazzle? I did that in the past but cannot find the steps. At that time had to change several items into individual modules.
      05-03-2024, 11:36 AM   #344
blue dragon
1193
Drives: '22 Tesla MY + '23 Tesla MY
You don't need step by step, just use the launcher cheat codes
| '22 Tesla Model Y P - My daily | '23 Tesla Model Y LR - Wife's daily | '17 F15 35D - missed daily |
      05-03-2024, 04:31 PM   #345
m4forum
85
Drives: M3
Esys or BimmerUtility?
      05-04-2024, 09:08 PM   #346
blue dragon
1193
Esys
xbimmers
