F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Strange humming noise from 100kmh till 130kmh
ARMA SPEED
      09-02-2023, 05:37 PM   #23
seabassmty
seabassmty's Avatar
Drives: 2018 430i Grand Coupe
I am new here,
I just got a 430i from auction trying to fix all error codes, now finally just have two that I am not sure how to solved, 1. blind spot detection malfunction and 2. lane warning change.
On 1 how do I know if my car has the blind spot system, I dont see any light indicator on the mirrors or doors.
2. The error code on the lane change warning is related to the vibration motor in the steering wheel, and is not motor installed or connection on the steering wheel.
So my question, is possible that the previos owner add or code this options by mistake or by lack of information. If this can be the case which is the best options to get the car back to normal, is posible to use the esys or other software to the deactivate this functions or options.
any help will be kindly appreciated.
      09-02-2023, 07:42 PM   #24
undertaker
64
Drives: 2015 BMW 328i
Having similar symptoms. Intermittent humming from left side at above 60 mph. Heard same sound few months back, rear differential was replaced. Thinking wheel bearing this time.
      10-12-2023, 09:54 AM   #25
Octaanridder
Drives: BMW 320i F31
Hi Guys,
I read your post about the noise between 100 and 130 km/h and I have exactly the same thing. It also drives me crazy and everything (tyres, wheel bearings, suspension, etc etc.) has been checked. New wheel bearings installed, 4x new tires and nothing helped. Now the presumption is the differential.
Did you finally find out what it was?
Regards,
Koen
      10-12-2023, 11:53 AM   #26
Eschmacher
Car Hypochondriac
Eschmacher's Avatar
Drives: 2014 335i M-Sport Estoril Blue
2014 BMW 335i  [0.00]
Just chiming in with my personal experience with this... I started getting a constant pitch hum starting from 60 and hitting max volume at 80. It was coming from the front left and I thought it might be a wheel bearing, but I noticed the noise got louder with gusts of wind. Turns out it was in fact the underbody tray.
I have always been missing one or two of the underbody screws, and the last time I dropped the tray, I didn't put one of the screws at the corner behind the left wheel, near where the wheel well liner is. This let the panel drop down just enough to vibrate in the wind.
      01-28-2024, 01:26 PM   #27
gasoline
Turkey
36
Drives: 530i Xdrive
Originally Posted by Robertjuhh View Post
The noise / sound is also coming from the front. I dont hear it rear....
Hi Robertjuhh
Did you come up with a solution?
I guess I have the same symptoms, a wavy/pulsating noise around 120 km/h
I came across a same problem and solution in the link below;
https://www.e46fanatics.com/threads/....952372/page-2
It says the cause is a combined effect of buckled rims and out of round tyres.
Could you update us, if you hopefully, solved it?
      01-28-2024, 11:46 PM   #28
gasoline
Turkey
36
Drives: 530i Xdrive
Hi,
A very similar issue seen on a Subaru, sharing the link.
This is due to front bearings, cause is water damage.
https://www.ultimatesubaru.org/forum...comment-762807
      01-30-2024, 01:23 PM   #29
TX552
Drives: 2021 M340i, 21 X3
Check all mounts for wear and tear, motor and transmission. Check driveshaft, guibo rubber things and driveshaft center support bearing.
      02-13-2024, 11:14 PM   #30
gasoline
Turkey
36
Drives: 530i Xdrive
Originally Posted by zrile View Post
I had similar situation, from 140 to 160 kmh! Any revs,any gear, same sound... mechanics said differential, or xdrive unit, or chain.....problem was in empty a/c system! After 20 dayswith that sound and expensive diagnosis "this or that", a/c stopped cooling. I got to refill a/c gas, go along my way and noise was gone! Try with that first! Cheapest fix!
Hey,
An old post but was your ac causing vibration also, in idle? And did you have this noise as a pulsating manner on highway, like a tyre noise?
zrile91.00
      02-13-2024, 11:16 PM   #31
gasoline
Turkey
36
Drives: 530i Xdrive
Hello all,
I am from the netherlands, so my english is not perfect. I have a problem with my F31. Until 100kmh its perfect, no noise. From 100kmh till 130kmh, i have some humming or pulsating noise. Noise sounds deep, you feel it in your ears but its absolut not a loud noise. My wife does not hear it but i am freaking about it. My garage has mounted a new differential but the noise is still the same. Now i am a few weeks further and i think the sound is coming from the front. I think wheel bearings. Is this possible or does anyone another idea?
Did you find a solution? Are you still with noise?
      02-14-2024, 08:15 AM   #32
zrile
zrile's Avatar
Croatia
91
Drives: BMW F31 320xd
Originally Posted by gasoline View Post
Hey,
No, i did not have any problems with ac, except on longer drive and high speed. Fixed by refilling ac system.
      04-25-2024, 12:59 PM   #33
RonalddeBoed
Drives: BMW F11 535I
@Robertjuhh did you ever solve this problem and can you tell us what the problem was?
      05-04-2024, 07:30 PM   #34
gasoline
Turkey
36
Drives: 530i Xdrive
Again a topic left answerless by the owner.
f30post
