03-01-2017, 08:15 AM | #89 | |
991
Rep 1,495
Then - E53, E85, E92, E82, F15, F80, G01
Now - F97, Macan S |
03-02-2017, 09:32 AM | #90 | |
BimmerPost Supporting Vendor
9596
Rep 10,884
jzmundy991.00 |
03-17-2017, 04:56 PM | #91 |
MBWorld Spy
316
Rep 831
IND's color match is always top notch. When my E60 M5's front reflectors were done by three different bodyshops in LA and they STILL couldn't match it and worse, it was yellow, IND came through and got it perfect.
Fast forward to years and years later, IND made me some color matched front reflectors for my Macao Blue paint. Thanks for this write-up, but I tried it and gave up. The stock reflectors were on tight and I couldn't maneuver my big hands well enough to get any grip. In fact the tips of my index and middle finger are still numb almost a week later. The good thing is, the place that did my clear bra was able to get them in for me. They did it in about 30 minutes, they had to jack the car up and use a heat gun, lol. But hey, it looks good now...
Time to participate in the douchey signature blocks Current: 2023 BMW M4 CSL, 2021 Ferrari F8 Tributo, 2020 Toyota GR Supra Notable Past: 2017 BMW M3 30 Jahre, 2019 Porsche GT3 RS, 2018 Porsche GT3, 2015 Porsche GT3, 2012 Nissan GT-R Black Edition Alpha 6+, 2008 BMW M5 Dinan, 2006 BMW M3, 2014 Mercedes CLA45 AMG |
03-20-2017, 10:22 AM | #93 | |
9596
Rep 10,884
06-01-2017, 09:20 AM | #95 |
9596
Rep 10,884
Upon return of your lease, your local BMW dealer shouldn't mind that there are painted reflectors on the vehicle. This being said, there is no good way to re-apply the stock reflector housings as the double sided adhesive is destroyed during the removal process.
06-01-2017, 09:24 AM | #96 | |
124
Rep 507
06-11-2017, 03:34 PM | #97 |
26
Rep 75
IND I'm just thinking ahead as I don't have the car yet, but will you guys be able to match the champagne quartz color? Thanks!
IND-Distribution9596.00 |
06-18-2017, 10:21 AM | #98 | |
Rep 3
I just installed this in alpine white on my car. 15 min for first side, 10 for second. Looks great! |
06-26-2017, 05:41 PM | #99 | |
9596
Rep 10,884
Yes, we have done that color a couple of times. Also great choice, its stunning.
07-06-2017, 04:16 PM | #101 |
Lobster Soup
152
Rep 210
Drives: 2018 M3 ZCP Black/Sakhir
Thanks for this post - just replaced them on my f30, took less than 10 minutes!
2018 M3 Competition Mineral Black/Sakhir Orange 6 Speed: Stock for now
2013 335i xDrive PWG: Bootmod3 Stage 2 | MPPK | FBO Dinan - CAI - Exhaust (Black) - Intercooler - Big Turbo - Fuel Pump | ER Downpipe | ER Chargepipe | BMS WMI Kit | KW V1 Suspension | Vorsteiner v-ff 103 | Michelin Pilot Sport 4S https://www.instagram.com/m3_blake |
07-21-2017, 04:31 PM | #102 |
1837
Rep 4,203
Just did mine via inner fender removal, holy christ was it a pita Mine is a early build 2015, prod date is July 2014. Those were on like cement. The first one separated reflector from backing plate, then it was easy....the other I just pryed and pushed on it at the same time and it blew right out. So I think these will sell with the car
BSM...match is pretty much perfect Last edited by horsepower_and_hounds; 02-13-2024 at 02:29 PM.. |
07-24-2017, 09:22 PM | #103 |
Rep 15
Just did mine. 01/15 build car so the original markers were really on there good. They would not budge until I used the hair dryer technique and they came off easily with a firm push starting from the bottom. The car also has parking assist and the cameras, so there was not much space to reach in behind the fender liner.
I heated around the edge of markers with a hair dryer for about 1 min, just blowing it about 1cm away from the paint all over the marker. Pushing from the bottom up it came off pretty easily, and for the most part the adhesive all came off with the orange marker too. After it was all off, i wiped the inside with alcohol to clean it. (wasn't really dirty anyways). I took the 3 screws off the fender liner and stuck one hand in to guide the new IND marker in, pressed it firm, and buttoned up the fender. Total time was less than 15 mins to complete both sides. I cannot stress enough: USE THE HAIR DRYER OR HEAT GUN, it's virtually impossible to push or tug the originals off without loosening up the adhesive. |
horsepower_and_hounds1837.00 JTK24121.00 |
07-26-2017, 03:58 AM | #104 | |
1837
Rep 4,203
billafin4.00 |
08-12-2017, 12:36 PM | #106 |
137
Rep 329
Man I wish I would have read this thread prior to starting. I wrestled for a solid 20 minutes with that stupid nylon pry tool. Eventually I said screw it and hit it with a hair dryer for 3 min and it came out no prob just using my hands.
Either way, they look great and fit awesome. Just don't blow money on that tool. |
10-03-2017, 06:16 PM | #107 |
290
Rep 1,079
Wow! Installed
Ok, I tackled my car today for the Ind-distribution painted reflectors.
First, I can't thank y'all enough for the excellent posts. This thread saved me a lot of pain. Second, the Indy reflectors are beautifully painted! Super high quality and I am very pleased with the outcome. Third, wow, this was not fun at all. Be prepared to sacrifice your hands and you will have several blisters when you are finished. It took me about two hours to do the job but I was taking my time and not in a rush at all. The actual lens removal time with hair dryer running: about 5 mins a side. Key points: 1. Hair dryer is A MUST HAVE!!!!! 2. No need to remove your wheel 3. Goo gone helps to remove the old sticky tape residue 4. Latex gloves help saving the hands while removing stock reflector My car was manufactured in May of 2017 and it is October. I removed 4 screws holding the wheel liner in place. The fourth screw above the tire is good to remove as it allows you to have more room to work on lens removal. It is key to start with the lower part of the lens first. This is because that is the only area you can get the blow dryer head on the lens sticky tape with the cameras in the fender in the way of your work. Use goo gone to remove remaining sticky tape that is stuck to the bumper. I hope that I don't have to do this again for awhile!
2020 X3MC, 2018 Porsche Macan, 2019 X3 3.0i, 2016 981 Cayman S
10-03-2017, 09:02 PM | #108 |
Assistant TO the Regional Manager
617
Rep 728
I spent the morning after bringing the car home, installing the painted reflectors and all the exterior black trim pieces I had purchased from IND over a month before delivery. I used a heat gun and installed the reflectors exactly as detailed in this video; didn't have to remove wheels or liner. Took less than 20 minutes in all. The black side grills were also just as easy as in IND's video but the OEM front grill removal is somewhat hilariously over-simplified in the IND video (no offense Ryan). Those took over an hour and I heavily relied on another YT video.
All in all, I am sold on IND's products and support. SSM can't be easy to match but they've dialed it in very well.
2018 M4 Coupe. 6MT.
Der stärkste buchstabe der welt |
04-20-2018, 07:15 PM | #110 |
617
Rep 728
You'll have to carefully/neatly cut the clear bra around the perimeter of each reflector. Then follow the standard directions and remove them from the bumper. Get the painted reflectors covered later or leave them as-is. They'll visually stick out either way to a close observer, but far less than the orange ones do.
