Sound Clip | INJEN CAI for the N55
07-06-2011, 03:16 PM | #89 | |
188
Rep 5,417
07-06-2011, 05:36 PM | #90 |
657
Rep 8,801
Jeff@topgearsolutions seems like a good guy.
always post in the turbo section, with his suggestions. seems pleasant enough and doesn't appear to be a douche. he talks amounst the enthusiast without being to much of a business man lurking the threads for sales from unsuspecting forum members.
FrankiE90 AKA:.[The TANK] *CLICK THE SIG
E90s (been gone but not forgotten) • KW clubsports • • • • • • • • • • 18" BBS GT4 // Build E30 (pending) + E46 M3 Wagon ESTORIL Blue |
07-06-2011, 09:06 PM | #91 |
173
Rep 1,343
Drives: BMW M3 DCT
07-07-2011, 10:07 AM | #92 | |
188
Rep 5,417
07-09-2011, 09:49 PM | #93 |
Book Worm
52
Rep 554
Hey Frank,
Just installed my Injen intake system today, same one as you have but in wrinkle black. I have a slight problem with fitment though because when i close the hood it hits the intake cone as well as the pipe right near the red injen sticker. Ideas? I tried adjusting it but there's little room for adjustment as the whole pipe that comes up from the engine is one piece. Thanks
| 2015 MW F82 M4 DCT | 2018 BS F30 340XI Msport 6MT | 2011 AW E92 335XI Msport 6MT Pic Thread |
07-09-2011, 10:46 PM | #94 | |
Rep 194
TiAg 2011 E92 335i X-Drive 6MT M-Sport
JB4 Stage 2 | AR 4" DP | Injen CAI | Eibachs |
07-09-2011, 10:56 PM | #95 | |
Book Worm
52
Rep 554
How did you manage to bend the flap section on the hood? With plyers? +1 for the 135i fitment, seems like it might be slightly off. I'm wondering if I should have gone AFE now.... Can't beat the injen sound though
07-10-2011, 12:41 AM | #96 |
New BMW owner
22
Rep 185
thanks!
Albert
2011 335i M-Sport Le mans blue Coupe |
07-10-2011, 01:30 AM | #97 | ||
Rep 194
Found out the hard way .... I also have a bald spot on the tube bc of the hood lol. But yeah plyers
07-10-2011, 01:32 AM | #98 |
Rep 194
Although i dont have a problem with the cone, was just the pipe section
07-10-2011, 07:53 PM | #100 |
188
Rep 5,417
My wrinkle black fitted perfectly actually... I guess you have to make sure you seat it deep into the turbo housing connection. Only problem I had was that the cone touched the hood, and the PROcede harness was too short for the maf sensor
07-10-2011, 08:27 PM | #101 |
Book Worm
52
Rep 554
Adjusted it today, really had to use some force to get the pipes in a better position but it worked out more. The cone doesn't even come close to the hood anymore and the pipe barely touches the underside of the hood (way better than before...have a huge gash in the black paint now oh well).
Thanks @ Cuffss for the help and advice Sloppy: Maybe the e90 and e92 have slightly different hood designs? Its basically this one metal tab piece thats perpendicular with the hood metal and just so happens to come down right where the pipe is.
07-10-2011, 09:37 PM | #102 | |
657
Rep 8,801
injen changed the location of the coupler. check out my picts on the 1st page again. does ur midsection coupler sit'n in the same place or is the coupler closer to the driver side? if u got the one closer to the driver side - that's the updated one. the e92 and e90 have the same clearance. 135 has more room, for sure. if ur cone is hitting ur inner hood. loosen the mid section coupler, adjust and bend down. while hold'n that down tighten the coupler. that should angle it down. if u have the old design intake (like the one on the 1st page) - I would contact injen and let em know, they corrected this problem early on so most of you guys should have the updated ones. My updated intake, the cone did hit the inner hood 1st few days - but it just needed adjustment from the midsection coupler -bending that tab is a good idea. The mid section doesn't rub anymore.
07-11-2011, 09:39 AM | #104 |
188
Rep 5,417
wrinkle black is where its at... just one bad point is that cuz of these tight fittngs, sometimes the black gets peeled off the edges of the pipe cuz of inserting it into the rubber hoses etc. no biggy cuz you can't see it... just make sure that shit doesn't fall into your turbo housing area
07-11-2011, 08:45 PM | #106 |
1567
Rep 4,109
Drives: BMW M3
DO WANT ...
Note to self: stop reading the tuning forums. But seriously, the whooosh is addicting. I could get used to hearing more of it. Already pronounced with the N55 stock.
2024 BMW M3 Sedan Frozen Pure Grey II/Fjord Blue, 6MT
Past: 2021 Z4 M40i Frozen Grey II/Black Alcantara | 2017 F30 340i Mineral Gray/Coral Red, 6MT | 2011 E92 335i Le Mans Blue/Black, 6MT |
07-12-2011, 12:35 AM | #107 | |
Book Worm
52
Rep 554
I adjusted everything and thought that nothing really touched anymore. So I touched up the paint on the hood and had to buy heat resistant black paint to touch up the 4inch gash in my midsection of the intake. Just came back after chilling with some friends and what do I find...the cone is STILL hitting the hood, basically taking off the touchup paint and the hood metal lip is STILL scratching the area where the gash is. Now there's black paint on the hood metal lip. I'm honestly fed up with this intake system. The sound is nice but it basically ruined the underside of my hood paint and the midsection of the intake now has a huge gash. Sorry but I had to rant...the fitment is probably just millimeters off but it already ruined everything cosmetically...
07-12-2011, 12:43 AM | #108 |
657
Rep 8,801
try pad'n that area with thin foam. use double sided tape on the inner hood.
at least it'll rub on the pad.
07-12-2011, 12:50 AM | #109 |
Book Worm
52
Rep 554
I was thinking of this but wouldn't I have to find some kind of pad and double sided tape or adhesive that can withstand the heat within the engine bay?
07-12-2011, 01:03 AM | #110 |
657
Rep 8,801
should be fine-
report back if it doesn't work.
