08-22-2022, 12:08 PM | #1 |
541
Rep 228
Drives: 2022 BMW M340i
2022 M340i WIFI dropping out often?
Recently my WiFi keeps dropping out. I lose Spotify and the ability to receive directions sent to my car from the App.
I'm in MA and usually have cell service everywhere. This just started 3ish weeks ago? Anyone else have this issue or has any suggestions? TIA!
2022 M340i XDrive, Oxide Grey Metallic/Tacora Red/Shadowline. 2004 330Ci (Sold), 2007 335i (Sold).. Last edited by chris_1001; 08-24-2022 at 12:47 PM.. |
08-24-2022, 12:47 PM | #2 |
541
Rep 228
Anyone? This is getting annoying, as the songs will stop and I cannot get BMW App forwarded locations sometimes to the car.
2022 M340i XDrive, Oxide Grey Metallic/Tacora Red/Shadowline. 2004 330Ci (Sold), 2007 335i (Sold).. |
08-24-2022, 07:10 PM | #3 |
1052
Rep 1,173
Drives: 2022 M340i Mineral Grey
This happens to me on occasion but not regularly. Sorry, can't help much.
Have you tried restarting your phone?
Present: 2022 M340i Mineral Grey
Past: 2019 330i, 2012 Evo X GSR |
08-26-2022, 09:53 AM | #4 |
541
Rep 228
Yup, Phone is not seemingly the issue, but the cars built in Wi-Fi.
If I launch Spodify from the phone it works fin, but the built in spodify cuts out after a 1-3 songs.
08-27-2022, 12:15 PM | #6 | |
541
Rep 228
I'm about due for an oil change, I'll see if they can take a look.
09-07-2022, 03:25 PM | #7 |
Rep 19
Subscribed for updates.
My android phone doesn't always want to play well. It will drop my BT audio via android auto, then it won't pick it up again. Resetting radio (20 second power press) doesn't fix it. Sometimes toggling phone wifi does. It gets annoying, but not super regular. |
08-20-2023, 07:01 PM | #9 |
Rep 17
Drives: 2021 BMW G20 318d
If you guys are referring to WiFi connection between headunit and phone when using CarPlay or Android Auto, or any headunit WiFi dropouts, then it's related to interferences with other WiFi networks when driving around the town. And I can support you with a fix to minimize these WiFi interference for a more stable connection.
But If it's something else related to cellular then I have no clue. |
superfuel22.50 |
09-07-2023, 10:24 AM | #10 | |
208
Rep 472
09-07-2023, 12:44 PM | #11 | |
Rep 17
- WLAN_2G_TX_POWER = 20 - WLAN_5GHZ_CHANNEL = 36 - WLAN_5GHZ_CHANNEL_WIDTH = 20 - WLAN_5G_TX_POWER = 20 - WLAN_CHANNEL = 11 - WLAN_DIAGNOSE = aktiv - WLAN_DOMAIN = us - WLAN_WIFI_MODE = ap+go In BimmerCode, you can find those in the expert mode of Headunit ECU, then search for "WLAN". Test those parameters for some time, if you don't notice improvement change the following parameters to reduce transmission power : - WLAN_2G_TX_POWER = 14 or lower but each time you decrease the power check if the signal on your phone is still strong enough - WLAN_5G_TX_POWER = 14 or lower with same checks as above I hope it helps and please let me know the outcome. |
09-08-2023, 10:37 AM | #12 | |
208
Rep 472
09-11-2023, 09:57 AM | #13 | |
208
Rep 472
09-12-2023, 08:42 AM | #14 |
Touring Guy
17
Rep 14
Let us know if it ends up working better!
07/2023: BMW G21 /// 330e Touring M Pro - Brooklyn Grey
09-21-2023, 12:57 AM | #15 |
208
Rep 472
Today I drove past an area my wifi always drops out enough to drop android auto.
Even with these changes it still dropped out. Not sure if maybe it took longer before it actually dropped out, so it may have helped but not enough. I might drop the signal strength back to 14. |
03-31-2024, 08:59 AM | #16 | |
Rep 7
I am going to test some parametres change, but need help with these, what it changes/means exactly ? - WLAN_DIAGNOSE = aktiv ...? - WLAN_WIFI_MODE = ap+go ... ap=acces point, go=....? |
