TRSVC on E91 & 3AG coding problems; now completed
12-15-2022, 07:52 AM | #111 |
coding BMW.....
487
Rep 875
actually i have a non-OEM setup on my e87 just like you described and an OEM setup with iCam and EVO on my e92. i was curious on how exactly he installed his oem setup on the e87 (looks good).
thanks for your reply |
12-24-2022, 01:56 AM | #112 |
15
Rep 45
https://www.1erforum.de/threads/ruec....245568/page-4
Here are some pics of the mounting on the E87/81. we did it like the F20 habe it. I can’t make any pictures anymore, sold my 1series and bought an F26 30d |
dumitru.o487.00 |
01-11-2023, 05:12 AM | #113 | |
coding BMW.....
487
Rep 875
can you please confirm this part # also works for the PDC ? 9252638 |
01-11-2023, 10:25 AM | #114 |
Rep 11
That part is no good for this retrofit. It's for front and rear PDC on a lot of E series chassis’ but has a smaller ROM on the microprocessor and lacks the 'Park Master' settings to active the reverse camera. You need a 9252636 ideally as it came with the latest firmware, but you can also use a 9225822, 9224465 or 9216138 as they can be software upgraded to become a 9252636 if they have not been updated already. These parts were only available on the E84 X1.
01-11-2023, 12:15 PM | #115 |
coding BMW.....
487
Rep 875
this module comes from e84 x1 car....... now, i ve order it but will search for those part # too....
9252636 is for Rear PDC only, i need front + rear PDC found these two from the same car x1 e84 i should be fine with these Last edited by dumitru.o; 01-11-2023 at 12:21 PM.. |
01-16-2023, 01:50 PM | #119 |
coding BMW.....
487
Rep 875
managed to read the modules on bench ( i use can bridge and icom) and both are from X1 E84 manual ( my car being e87 automatic)
attached the TRCs from modules, clearly the PDC has a totally different TRC than an e9x PDC module/ should i upgrade them to the latest version of software? which config should i tweak for e87 and how? |
03-24-2023, 05:32 PM | #120 |
9
Rep 66
I will do the Retrofit in my E92 LCI as well.
Currently have the JBB3 in my car which came from factory. So all I need is the Camera Handle from Aliexpress, the OEM Camera, the OEM Harness, the TRSVC with Letter instead of Number, the X1 PDC Module. Coding will be done by myself. My only question: Where do I have to put the fuse that comes with the Harness ? Which Position ? |
05-08-2023, 12:23 AM | #121 |
Rep 14
@Sangria
Hi! Cheers from Mexico! Man how do you know that you have a European PDC Module? My car its a e92 335i LCI and I have update all the modules to 2018 lastest software with Ista P, I Have front and rear sensors, M JBE and I have an Fseries TRSCV Module and Camera with all wiring Oem new retrofit. My ISTA+ said ECE type of my vin when I run the complete identification. So what do you think this setup will work? |
05-08-2023, 04:10 PM | #122 |
990
Rep 1,353
F series TRSVC wont work on E series. They have different CAN bus.
E93 M3 6MT , Nav, Prem, Cold Weather, Sports package, & CA, RGBW DTM with RGB Demons + Eisenmann Race + BE + ARP + Brembo GT 380s, $3AG, $5AC, $508, $6NF, $601
Please "Appreciate" If you like my post! DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue, , F85 ACC Retrofit |
07-29-2023, 12:25 PM | #123 |
9
Rep 66
I tried to change the Values in Nettodat File.
I could default code the TRSVC and tried to code the Nettodat because of the lines. E92/E93 with chinese varient handle (I've estimated this as the camera is set left of centre) |70 0E|D6 FF|52 03| = | 3696mm | -42mm | 850mm | Tried these values but the Cam view got messed up. So I reverted back. The default Values are: E0,0D | 80,E9 | 00,00 | I also have the Chinese Variant Handle. Maybe SyphonX can help out ? |
11-29-2023, 09:22 PM | #125 |
990
Rep 1,353
Hello I believe 2005 has K-Line you need to convert to D-Can first then you can use JBE3 i believe!
11-29-2023, 11:17 PM | #126 | |
Rep 14
I had found this info in the BMW info steps of how to retrofit an automatic double clutch transmission: Part4 ( Replacing JBE ECU ) ( if you have 2007/09 > skip this part ) You can find JBE ECU under the feet of the passenger seat. First you should replace it on new one JBE2 or JBE3 ECU (61359286790 ). After this you should integrate D-can bus line for new ECU. ( Old cars have K-line and new ECU will not work ) Change pin on OBD2 socket 7 to 14 and put the additional wire between OBD2 socket pin 6 and JBE ( blue connector ) pin 17 Do you think that will be all to make the change to the D-Can line? |
12-07-2023, 04:00 PM | #127 | |
Rep 14
12-13-2023, 02:57 PM | #128 |
Rep 12
Is there some specific PNs that need to be used for PDC? When looking in the lists it seems like E84 and E9x is sharing the same part numbers?
Will a E7x TRSVC always make up fault codes due to the missing side cameras, or are there any workaround for that? |
03-19-2024, 01:11 PM | #129 |
20
Rep 67
Hello,
All the parts except for the camera has been sitting in a shelf for a couple of years now............ Can you point me in a direction what camera to use F series i suppose, part number? Thanks Christian |
