05-03-2018, 10:07 AM | #23 |
2052
Rep 3,714
I use HAWK DTC 70 for slicks and DTC60 for NT01. They have really high heat ranges, good modulation and pedal feel, just enough initial bite and are a great value. I get about 8-10 days.
chief1richard383.00 5.M0NSTER3359.50 |
05-04-2018, 05:59 PM | #24 |
103
Rep 2,317
+1 - Did Buttonwillow without a problem but took it to Laguna Seca (Hard on brakes anyway) and torched the pads and rotors with overheating and uneven pad deposits. LOTS of shuddering. 6K miles and new pads/rotors!
05-06-2018, 07:23 AM | #25 |
420
Rep 594
Drives: 2018 M2
YMMV but just to throw my experience in this thread...I too had stock pads/rotors and after an event I got the shuddering and deposits that others speak of, but that went away after <1,000miles of driving.
06-07-2021, 02:45 PM | #26 |
Rep 11
Hawk HP?
Anyone run Hawk HPs?
Got deposits yesterday at Calabogie with the stock pads. Are they aggressive enough to clean the rotors? I use the car only for summer fun (i.e., spirited drives and track) so not too worried about noise, stop and go, winter, etc. They're available through my favourite shop and cheap, so I thought I'd ask before going with the Pagids... Cheers! |
06-09-2021, 10:06 AM | #27 |
68
Rep 74
I was talked out of the HPS by someone who knows a lot about this stuff. Said they are harder on rotors than other equivalent pads. I was never impressed with my HP Plus for Autox use, so I wasn't in a hurry to try HPS any how.
The m2 is heavy enough that I think a dedicated track pad is worthwhile. I find the stock pads to be inadequate on track. Swapped to Ferodo DS1.11 and AP R4 fluid and was really happy. But I would not use those pads on the street other than to/from the track. You might want to look at DS2500. Better than stock, but not a full track pad that will need heat to work. I found the DC2500 to work great year round even at 25-30deg F track cross events. Regardless, you should clear the pad deposits before you swap to another pad. Essex has some great videos on this. Basically you need to nearly do a bedding procedure, but not allow the pads to come up to temp to the point of leaving a new transfer layer. Essentially you just want to scrape the old layer/deposits off. Then you can swap to new pads and bed those in. You can even use that procedure to clean and then re-bed your brakes with a fresh transfer layer before events or if they develop a judder from unevenness in the existing transfer layer. https://www.essexparts.com/support/learning-center--faq |
bentom2335.50 |
06-09-2021, 04:22 PM | #28 |
///M2
104
Rep 104
I ran pagid RS29Ls/Castrol SRF fluid on the stock M2C brakes and they felt good. Only issue was pad knock back, especially after chicanes that required a quick tap before really getting on the brakes for full power. Annoying...
06-09-2021, 05:36 PM | #29 |
2281
Rep 2,516
Pagid RS29s. Hard to source right now, but they stop like the hand of God.
?16 M2 Long Beach Blue/Black, 6MT
'22 X5 4.0 M Sport Black Sapphire/Tartufo ?22 Tesla Model Y Performance Midnight Silver/White |
06-13-2021, 10:39 AM | #31 |
3492
Rep 9,708
Always a bad idea to mix pads unless you know what you are doing and need to correct a particular problem. Dedicated track pads have higher COF and also COF temperature curves.
06-14-2021, 05:14 PM | #33 |
707
Rep 886
You need the EBC RP-X race pad. High coefficient of friction, very high temp range, no squealing, slow wear rate, nice on rotors. Pairs VERY well with Girodisc 2-piece rotors
2015 M3 - AW 6Spd w/ CCB
MCS 2WR Dampers, Spec Twin Disk Clutch, MaxPSI CH, F80Paul Ethanol Tune, 3.5in DPs |
VicF87OG72.50 |
06-15-2021, 02:02 PM | #34 |
1232
Rep 2,602
I did the Ferodo DS 2500 pads front and rear. Expensive but worked well at Barber. Also decent on street and no more noise than stock pads.
Although the real test will be Carolina Motorsport Park, which is hard on brakes.
2020 X3M non-comp, Alpine White over black : Exec Pkg, ventilated M Sport seats, 20"s
2020 M2 Comp, Sunset Orange/Blk: Orange stitching, DCT, exec pkg, bicolor rims Gone '18 M550i, '16 X4 M40i, '15 M5, '13 X3 35i, '12 335is, '11 X5 50i, '09 Z4 35i, '08 550i, 06 X3, 06 650i, '02 M5, '99 540i |
06-15-2021, 03:22 PM | #35 | |
3360
Rep 1,823
Thinking about using DTC60s with 285/305 Goodyear F1 Supercar 3 tires. (on a Camaro 1LE)
2017 BMW M2 German Spec
6MT, Driver's Package --> SOLD 2018 Camaro SS 1LE. Because race car! "Redline a day keeps the mechanics away" |
06-17-2021, 08:07 PM | #36 | |
229
Rep 555
Try DS1.11 or some more aggressive pads for track duty.
F87 M2 Competition Sunset Orange
IG: M2C_SO |
06-17-2021, 08:16 PM | #37 |
229
Rep 555
I had good experience with DS1.11 but they were too expensive to run. I recently switched to Gloc R18 and R12 combo and had very good experience on my laguna seca track day (very brake heavy track).
IG: M2C_SO |
06-17-2021, 08:40 PM | #38 |
3360
Rep 1,823
Gloc/Carbotechs are good. They don't leave uneven deposits, and have great fade resistance. But at least the R12 disappears in 4 track days when up front. Never used the 18. Curious how long they last for you.
06-18-2021, 08:42 AM | #40 |
1105
Rep 1,263
Drives: 20 BMW M2C 17 Mazda MX-5 RF
Ferodo DS3.12's
Great feel, rotor friendly, and now my go to pad after running Carbotech's & Porterfield R4's for over 20 years. Stunning stopping power and linear thru the entire heat range... I swap out to the 2500's for street use.
2005-2006 BMWCCA Boston Chapter president
2004 Mazda Rev It Up Finalist 2002-Present HPDE Instructor My 2020M2C Build: https://f87.bimmerpost.com/forums/sh....php?t=1696726 |
F87source7320.00 |
06-19-2021, 03:53 AM | #41 | |
229
Rep 555
IG: M2C_SO |
5.M0NSTER3359.50 |
06-19-2021, 02:20 PM | #42 | |
3360
Rep 1,823
That said I just ordered a set of Hawk DCT60 for the Camaro. Less that $500 a set, and supposed to last 6-8 days from what I hear.
Fabb228.50 |
06-19-2021, 08:59 PM | #43 | ||
229
Rep 555
IG: M2C_SO |
5.M0NSTER3359.50 |
06-19-2021, 11:12 PM | #44 | |
7320
Rep 7,487
But yeah I liked using Ferodo in the past too, really good stuff.
Click on the link below to see a compiled list of every review I have ever written:
https://f87.bimmerpost.com/forums/sh...2#post30368242 |
