BIMMERPOST Universal Forums General Automotive (non-BMW) Talk + Photos/Videos    Are composite or plastic engine parts that bad?
      02-06-2024, 06:46 PM   #1
spicyB48
spicyB48's Avatar
79
Drives: 2019 BMW 330i
Nearly every automaker (not just BMW!) is using composite materials (fiberglass reinforced thermoset plastic) instead of cast aluminum for certain parts, especially valve covers and cooling system parts.
VW/Audi cars are known for those composite oil pans that crack easily, BMWs are known for composite cooling system parts that leak, even Toyota, a brand known for reliable cars, is using composite valve covers and cooling system parts.
In infrastructure, plastic and composite materials are used for everything from water and gas mains to high voltage utility pole insulators (instead of ceramic). Modern materials can be strong, lightweight, flexible, and corrosion resistant.
So, are plastic auto parts a bad thing? Or is it just another "they don't build them like they used to" thing from boomers?
      02-06-2024, 08:58 PM   #2
Efthreeoh
Drives: The E90 + Z4 Coupe & Z3 R'ster
Your question is about 35 years past due.
Appreciate 2
eugenebmw1480.50
cooolone2625.00
      02-06-2024, 10:33 PM   #3
chris719
7334
Drives: '08 M Roadster
Both. They are mostly fine except when they aren't, and that's the only problem.
      02-07-2024, 05:49 AM   #4
chassis
chassis's Avatar
6557
Drives: 9Y0 Cayenne S
Is this a chatbot thread?
      02-07-2024, 08:01 AM   #5
///MPhatic
The Seeker
///MPhatic's Avatar
13863
Drives: OG M2 • Exige
For the consumer; yes, they're junk, and don't hold up over heat/time.
For the manufacturer; no, they're junk, and don't hold up over heat/time.
Always remember that cars are engineered to be a multi-year source of income for a brand through parts, and labor. The vehicle needs to survive, but it has to nickel and dime you as it gets older. In the case of brands like BMW, Merc, Aston, etc, they need to cause the 3rd owner to become a mechanic to be able to afford to keep it on the road.
Appreciate 2
Donatello.1083.50
      02-07-2024, 11:26 AM   #6
spicyB48
spicyB48's Avatar
79
Well, considering that Toyota is also switching to plastic parts (a few years ago they started using plastic valve covers) and they are known to be very reliable, plastic can't be too bad.
      02-07-2024, 12:38 PM   #7
DocL
DocL's Avatar
Drives: 2018 M3
I needed a new palstic gas tank and valve cover for my 2018 M3. I've never had to replace either of those parts in any of my previous 70 cars. Luckily I have a 3rd party extended warranty as it has covered almost $7k in these repairs the past five months.
This plastic shit is crap.
2018 F80 M3. YMB/BLK. ZCP. Three Pedals.
"Education will never be as expensive as ignorance."
      02-07-2024, 01:02 PM   #8
Efthreeoh
Do the words "That ship has sailed" ring a bell?
chassis6557.00
      02-07-2024, 01:25 PM   #9
///MPhatic
The Seeker
///MPhatic's Avatar
13863
Is it now that I should remind you that Toyota isn't infallible? That they have many engine oil issues causing the need for rebuilds at 90-150K? Do a little research, they make mistakes.
Appreciate 2
Donatello.1083.50
chris7197334.00
      02-07-2024, 01:31 PM   #10
heavyD^2
heavyD^2's Avatar
3689
Drives: X3M Competition
I don't think in most cases they are bad but some manufactures struggle with sealing the plastic parts to metal surfaces. Honda hasn't been able to design a plastic valve cover that doesn't leak oil on their turbo 4 cylinder engines. VAG hasn't been able to make a plastic water pump or thermostat housing that doesn't leak coolant for a good decade. I think they work better on parts like intakes as with 3D printing they can now make intakes that are lighter and flow much better than cast aluminum. In general most engine bays today are filled with plastic and cars today are as reliable as they have ever been so I don't think it's much to get concerned about.
      02-07-2024, 02:35 PM   #11
XutvJet
5554
Drives: 2011 Cayman Base, 2016 M235
In most cases, no, it's not a problem. Plastic these days is pretty robust. Though, there are some parts that shouldn't be plastic, especially those in high heat, high stress areas, and/or not easily accessible areas. Engineers should know better.
The old mechanics that bitch about this stuff and talk about the glory days of when everything was "metal" seem to forget that cars back in the 50s, 60s, and 70s were generally looked upon as disposable. People bought new cars every 1 to 5 years and most cars rusted out within 7-8 years if they lived in an area with salt treated roads. In general, people own their cars far longer longer and cars in stay on the road longer as well. Cars are also far more reliable than they've ever been, all things considered.
I have little sympathy when people bitch that their 10+ year old car has developed a rash of issues. Stuff wears out over time, regardless of mileage. The reality is people have gotten used to how reliable their cars are and tend to loose their mind when they actually have to make some repairs. Cooling systems, regardless if they are metal, plastic, rubber, etc. are under a ton of stress. It's not odd that a lot of cooling system parts may need to be replaced at 10-15 years. No manufacturer is immune to this. It was like this in the 1950-1990s too.
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
Appreciate 4
chassis6557.00
Holset274.00
heavyD^23688.50
      02-07-2024, 02:52 PM   #12
spicyB48
spicyB48's Avatar
79
I agree. Cars are harder and more expensive to repair nowadays, but repairs are needed far less often. A 10-15 year old car will likely need some parts to be replaced, but your engine probably won't need a full teardown and rebuild until 300k or more. Unless you have a Volvo, then the engine will fail before 100k.
      02-07-2024, 02:53 PM   #13
spicyB48
spicyB48's Avatar
79
Doesn't VAG use plastic oil pans that are notorious for cracking when hit by debris?
      02-07-2024, 02:54 PM   #14
spicyB48
spicyB48's Avatar
79
Nope, I know that Toyotas have plenty of problems too. I think their reputation for reliability came from a few models that have that "refuse to die" reputation, but they will need maintenance and repairs just like any other car.
      02-07-2024, 03:18 PM   #15
///MPhatic
The Seeker
///MPhatic's Avatar
13863
I'm the opposite, I lose my mind when manufacturers SELL you the dream of extended life and reliability only to have their product need a transmission or engine at 100K miles when in the 70's they could make an engine that lasted a million miles.
If they're going to sell me their products that way, I'm going to hold them to it. Now, if they didn't sell it that way, if they didn't play the reliability/longevity card it'd be different, but they do, and are therefore responsible for negative outcomes if I've done all my service.
      02-07-2024, 03:23 PM   #16
4JawChuck
216
Drives: 2013 128i SE
The problem isn’t the plastic, it’s designing that same plastic part in the same way we built aluminum products.
Plastic is soft, ages and distorts over time and generally needs far more ribs/gussets and additional material for it to compete with metal.
Trying to save weight where you shouldn’t is the engineering issue, I should never have to replace a $500 valve cover because it cracked or warped from age.
End of story.
Appreciate 2
///MPhatic13862.50
lakefront560.50
      02-07-2024, 03:28 PM   #17
eugenebmw
eugenebmw's Avatar
1481
Drives: G82 M4, G22 M440, E92 335i
Don't get me started. Nowadays cars manufactures are switching to soy based insulation wire to wiring their cars. Easy to say from the car manufactures to keep our planet green. Very expensive repair for car owners to fix the damage from rodents chewing through the insulation of the wiring.
      02-07-2024, 03:38 PM   #18
spicyB48
spicyB48's Avatar
79
That sounds a lot like start stop systems - reduced battery and starter lifespan, no real benefit to the consumer. Except it is far more expensive to fix.
Grüne? Nein danke!
eugenebmw1480.50
      02-07-2024, 03:55 PM   #19
eugenebmw
eugenebmw's Avatar
1481
Grüne? Nein danke!
Exactly. End up we are producing more wastes to our planet and we have less money in our pockets.
      02-07-2024, 05:54 PM   #20
chassis
chassis's Avatar
6557
All the Germans use plastic oil pans.
      02-07-2024, 07:46 PM   #21
Donatello.
How's My Driving?
Donatello.'s Avatar
1084
Drives: Hellcat & Miata
The plastic crap on my E90 335xi was a joke. Plastic is bad & doesn't belong in a lot of places.
2018 Charger Hellcat
2019 Miata 30th Anniversary
2021 CX-5 Signature
2009 Mazda6
      02-07-2024, 10:36 PM   #22
XutvJet
5554
Motors back in the 70s rarely made it to 150k miles, especially domestics.
chris7197334.00
