05-07-2021, 02:54 PM | #1 |
26
Rep 74
Tire replacement question
I know this may be a strange question, but I'm thinking about replacing the tires on my '19 M5C. The backs are pretty bad, but the fronts have a bit of time left on them. I'm thinking about replacing the rears first with something else, maybe Michelin. It's not a daily driver, more like a fun, nice day car. Do you think I'd have an issue if I replaced the rear with Michelin's and waited to swap over the fronts to Michelin's? I'd be using stock sizes and was curious if anyone thought that would be a problem. Thanks!
05-07-2021, 10:24 PM | #2 |
239
Rep 407
I have no direct personal experience, but the conventional wisdom is that it is a bad idea to mix older worn tires with new tires of the same brand. Mixing brands on top of that sounds like a risky proposition.
05-10-2021, 11:12 PM | #3 | |
1834
Rep 1,327
You could luck up and get spot on or you could overheat or destroy the center differential function of the transmission. Shawn |
05-11-2021, 05:33 AM | #4 |
5234
Rep 10,616
I would not worry the least bit about changing the rears only. Many heavy or high performance cars will wear out the rears up to twice as fast as the fronts. You won’t do any harm to your transmission or differential.
05-12-2021, 10:52 PM | #6 | |
239
Rep 407
My point was that old vs. new tires and even more so different brands of tires will have different traction and grip characteristics and mixing them can create unexpected and unwanted handling issues at or near traction limits. |
05-14-2021, 08:43 PM | #7 | |
1834
Rep 1,327
Manual also specifically states not to mix tires from different manufacturers and different tread. MOST manufacturers recommend replacing all four tires simultaneously on any all wheel drive car. So, just sayin' Shawn |
05-15-2021, 06:06 AM | #8 | |
5234
Rep 10,616
Yes, there could be minor differences in grip and minor differences in diameter or width with different brands. They are minor, very minor. I would not put 265 snows on the rear and 275 PS4 on the front, but I would not worry about substituting Conti EC Sport for PS4 at one end and I would not worry about running new PS4 at one end and worn out PS4 at the other end. I would not even worry about running new PS4 at one end and worn out EC Sport at the other end. I would not, except very temporarily, run any more extreme combination such as my first example of the the narrow snows in the rear and the wider high grip summers in the rear. |
05-15-2021, 08:04 AM | #9 | |
1834
Rep 1,327
From the looks of it to me, the ZF unit looks robust enough to handle a fairly significant difference. But, I just don't KNOW for sure. Frankly, I'm not chancing it. I've been tracking cars for so long it's just too easy to put the same tire front to back on the same wheel on a $100,000 car, that's what I do because at 160 MPH on the back straight I cannot afford to be guessing. Been burned one too many times going off the beaten path of conventional wisdom. Seen people get away with a lot of sketch stuff, though, stuff that's KNOWN to be dumb. This, not known to me. So, to OP, conventional wisdom vs. what you can probably do. I dunno personally. Shawn |
05-16-2021, 06:45 AM | #10 |
5234
Rep 10,616
I don't know anything about GTRs, but I think you and I recently had a discussion about going up or down in tread width on one end, which has a similar effect. You agreed in that thread that there was no issue. The situation at issue here is much the same -- wider tires than stock at one end will have more grip and be a slightly different diameter. Likewise, similar performance tires from 2 different brands will have slightly different handling, and worn performance tires compared to new ones will have slightly different diameters as the 8mm of tread depth wears down to 2mm. Are you comfortable driving your car with half worn tires at one end (pretty common to see the rears much more worn than the fronts)? Where do you draw the line? But each person should do what he or she feels comfortable with.
05-19-2021, 11:09 PM | #11 | |
1834
Rep 1,327
The implied data from OP suggests that he will be changing brands of tires. So, at first he would be worn Pirelli's in front and new Michelins in rear. Will that exceed tolerances? Hell I don't know honestly. I do think you can get away with mixed worn sane brand same size front to back, but I've only had 3 brands of AWD track cars, and one of them was sensitive to mixed diameters that were supposedly pretty close. So, to OP, might be fine, might not. No one has tried what you are thinking yet. Shawn |
