09-22-2014, 02:10 PM | #45 | |
349
Rep 2,347
Drives: TT Flat Six
http://www.2addicts.com/forums/showthread.php?t=1032487 |
09-22-2014, 07:11 PM | #46 |
2040
Rep 25,989
VMR|Wheels | 714.442.7916 |
09-27-2014, 04:34 PM | #47 |
430
Rep 1,115
I picked up a set of 335 17s, plan on running 225/45/17 with 18mm spacer on the rear and 15mm on the front. The wheels clear the calipers pretty well (5mm), but for added insurance against stones I decided to add the spacers.
09-27-2014, 04:55 PM | #48 |
349
Rep 2,347
Drives: TT Flat Six
15mm spacers on 335i wheels will put you at roughly et 15... The wheels will still very far outside your fenders
09-27-2014, 05:12 PM | #49 |
430
Rep 1,115
Yeah perhaps I need to revise my order down to 5mm, the wheels are ET34 17x 8's for some reason I thought they were 7's and the wheel wouldn't stick out that much. I already test fit and they poked out a bit but I'm probably going too far.
10-15-2014, 08:23 PM | #50 |
Rep 4
I was looking on tirerack and they are saying that 16"s will fit the 2015 228i xdrive without the M brakes. Has anyone tried? I live in a big snow area and would love to have the extra sidewall for the snow.... Any thoughts?
10-17-2014, 09:06 PM | #51 |
65
Rep 326
Drives: 2020 X3M40, 2000 Z3M, 2017 X1
I have the RWD 228 without M brakes. I tried a set of 17" and they fit but had very little clearance to the front calipers, so I doubt 16" will fit. Base 228's come with 17" so I guess it is OK. I ended up buying 18" off a 135i to make sure I had clearance.
11-26-2014, 10:44 AM | #52 |
103
Rep 1,254
What tire pressure do you set your winters too?
I have a square setup 17 inch. I have staggered for summer setup. Car sticker says 32 psi front and 38 psi rear. I wouldn't think that would be correct for the square setup winter tires.
11-26-2014, 11:27 AM | #53 |
1779
Rep 4,516
Used on my 3 series touring [ski trips to Europe] and now on F20 M135i - very good.
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI.. |
11-26-2014, 12:26 PM | #54 |
25
Rep 120
Drives: 2018 BMW M240i
+1 for TS380. It's the tires BMW uses in the cold weather package paired with the style 380 wheels. It's available in Canada and Europe, but not in the US. I got a chance to use it when I did ED earlier this month.
