Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > Ultimate compilation of part numbers, please help out !
      04-02-2007, 01:35 AM   #23
teknochild
Your resident 4um troll
teknochild's Avatar
125
Drives: 335 coupe
anyone got the part numbers for the euro keyhole cover and the bumper reflectors on the e92?? or know where theres something i can look through to find them
RAWRrrrr
      05-28-2007, 09:11 AM   #24
thealbert
thealbert's Avatar
32
Drives: G20 M340i xDrive
Part numbers for E90 BMW OEM CF Trim.
01 INSTRUMENT PANEL TRIM, CARBON, LEFT x1 - 51450416198
02 INSTRUMENT PANEL TRIM, CARBON, RIGHT x1 - 51450416200
03 TRIM COVER, DOOR, CARBON, FRONT LEFT x1- 51410416202
04 TRIM COVER, DOOR, CARBON, FRONT RIGHT x1 - 51410416203
05 TRIM COVER, DOOR, CARBON, REAR LEFT x1 - 51420416204
06 TRIM COVER, DOOR, CARBON, REAR RIGHT x1 - 51420416205
07 CENTER SET DECOR STRIPS, CARBON x1 - 51160416207 - (it's another part number for those who have I-drive, I-drive cars - 51160416209).
08 CLIP, OUTER DECOR STRIPS x2 - 51457146752
09 THREADED BOLT D=6X30 x7 - 51458266813
10 PLUG-IN RETAINER x10 - 51457152442
11 CLAMP x18 - 51418215806
12 GASKET, DECOR PANEL x4 - 51166952674
      07-17-2007, 06:07 PM   #25
g9sBMW
g9sBMW's Avatar
23
Drives: 2007 BMW 328i
2007 328i Sedan  [0.00]
2007 e90 328i Brake Calipers
Left Front Caliper
34 11 6 769 091
Right Front Caliper
34 11 9 769 092
Brake Carrier Front
34 11 6 769 095
Front Clips
34 11 9 776 526
Left Rear Caliper
34 21 6 768 697
Right Rear Caliper
34 21 6 768 698
Rear Brake Carrier
34 21 6 768 696
Rear Clips
34 21 1 157 046
[2007 328i|Black Sapphire|Terra Leather|6 MT|Xenon headlights|BMW Alarm|Clear Bra|Stainless Steel Pedal Pads|Black Line Tails|MTEC V3.0 Angel Eyes|HUPER OPTIK 30 Ceramic TINT|GPThunder Fogs|LED License Plate mod|Sport Shocks/Springs upgrade|ZHP Shift Knob|//M Dead Pedal|Matte Black Grill|Aluminum Strut Bar|Cyba Air Scoops|Rear Fog Switch|Perforated Mtech Wheel|Miro 935s|Hankook v12 evo Tires|BMW SSK]| BMW PE
      07-19-2007, 05:35 PM   #26
Sundance62
Sundance62's Avatar
Drives: '07 328i - SG w/black leather
I'm trying to find out info about part # 51.11.8.165.146 - I believe it is a euro front license plate frame, but the only description I can find is 'reinforcement'.
Anyone know this part?
      10-06-2007, 08:00 PM   #27
Alex@TAG
Alex@TAG's Avatar
Drives: 16 RS7, 488 Spider, i3 REX, 57
looking for part number for Euro Non-Xenon (halogen) headlights
      03-29-2008, 07:14 PM   #28
cn555ic
cn555ic's Avatar
Drives: 335i
Need part # for the engine cover of a N54 engine?
      08-25-2008, 12:17 PM   #29
txusa03
550
Drives: TS330iPPSP6MT
here is part number for the 06 e90 passenger door system latch (some call it actuator). My prediction is this will be a very popular and expensive item to replace #51217059974. See photo..
I heard there is a SIB on this so I am heading out to look for it and see if I the process is easy to do. If anyone know where this SIB is, please kindly point me to the right direction
under construction!
      06-19-2012, 12:51 PM   #30
Khabbaz
Khabbaz's Avatar
Drives: BSM-Coral Red- 6MT
Anyone know the part number for the ECU power supply? That little green piece that your ECU connects to for power...
      01-21-2014, 12:50 PM   #31
fernanj1
Drives: 2007 BMW 335i Sedan
PCV Valve Part Number?
Can someone tell me what is the part number for the oem pcv valve.
Thanks
      02-18-2014, 12:16 AM   #32
GB-335xiCoupe
Libertarian
GB-335xiCoupe's Avatar
Drives: 29k mi per year.
N55 Spark Plugs:
ZR5TPP33 or BMW part# 12 12 0 037 582
2011 335xi Coupe BSM (e92/N55/ZPP/ZCW, Alpina B3 Flash)
Bought 08/09/2013@53,340mi Current 3/13/2019@206,283mi
Fail(s): tstat hous/water pump 89k, Chargepipe 106k, coolant tank 114k, FRM3 114k
Maint: Walnut blast 101k, Trans/T-case Fluid 103k, OFHG 195k
