09-27-2022, 02:45 PM | #23 |
Rep 15
I could not wait until tomorrows better weather to make a run. So, in the interest of transparency here is todays run. I am new to not only dragy, but what certain speeds and times can say about a run. I am hoping someone can help me understand this slip a little better. First, I understand that this 1/4 ET is about what it should run stock, and certainly not impressive for a tuned M5 competition. However, before I call Noelle and complain; my 0-60 times are worse than stock, but my trap speeds seem to suggest I should have much better ETs than I do. It has been a bit cool out, and the roads were not completely dry, but I cannot be sure if I had wheel spin. It seems to bog down at first, then engage a second later. Again, I don't want to jump the gun and start complaining to Noelle without maximizing my results and having genuine data to report. Any thoughts or interpretation help would be greatly appreciated.
09-27-2022, 08:16 PM | #25 |
5234
Rep 10,616
That is about 3 mph trap speed better than any stock car.
ResIpsaLoquitur4092.00 |
09-27-2022, 08:23 PM | #26 |
4092
Rep 3,672
Drives: 2022 M5C
Wow, I'd be furious for all that to result in that minimal gain!
Not a BMW guy...but certainly an M5 guy.
09-27-2022, 08:48 PM | #28 |
5234
Rep 10,616
09-27-2022, 10:24 PM | #29 | |
4092
Rep 3,672
Drives: 2022 M5C
09-28-2022, 06:14 AM | #30 |
Rep 15
3k. While I’m certainly upset about the ETs, I guess I’m still curious as to what I need to improve in my launch and take off to get a true idea of what the tune has done compared to average stock (since I don’t have pre tune runs). I may still be irritated after all of it, but clearly this run suggests something is off with my launch.
I guess a better way to say it is if my 0-60 time improves to just average stock, my ET looks more acceptable. Which my trap speed suggests I should be running, correct? BTW, I appreciate the responses and help!! |
09-28-2022, 06:28 AM | #31 |
5234
Rep 10,616
ET is dependent on launch. You can work on that. There is a trans tune that some say helps, particularly if your car will no longer engage launch control (some say it is limited to 100 engagements).
09-28-2022, 08:02 AM | #32 | |
3619
Rep 4,532
09-28-2022, 10:39 AM | #33 | |
Rep 15
09-28-2022, 10:58 AM | #34 |
1416
Rep 1,564
What fuel are you using? I would be curious to see what difference you would see with a 95-96aki rating. Do you have access to E85 or race gas you can mix in?
09-28-2022, 11:17 AM | #35 | |
3619
Rep 4,532
09-28-2022, 11:42 AM | #37 |
Rep 15
You have to forgive my ignorance, but I did not know we could mix in E85 safely without a specific tune for it. My knowledge is not exactly vast on the subject (lol). I am using 93 from my local stations. I was told from my Trackhawk tuner that in my area, once October hits, the winter blend of ethanol is crap. There is a Sunoco about 15 miles away that has race gas I could try. While I definitely want my times better, my ultimate goal is to see what this tune did (or did not do) compared to stock since I do not have pre-tune dragy runs. I've tried launching every way I can imagine (except for using LC, which is next this afternoon), and I just spin. Just some background info, I bought the car (2019 M5 comp) 6 weeks ago with 2600 miles (not a typo). So while the tires only have 4k miles now, they are quite a bit old. I know this is not helping my launch. Should my 60-130 time be better than that? I thought stock was in the 8.2 neighborhood?
Again, I appreciate the help!! |
09-28-2022, 11:43 AM | #38 | |
Rep 15
I appreciate the response. I certainly do not believe the wild 850HP claims from Noelle, but I'm trying to determine if it did anything at all after reading some earlier threads from here on Noelle. |
09-29-2022, 05:17 PM | #41 | |
1416
Rep 1,564
Not a problem happy to help and yes mixing in E85 is no problem on any modern BMW platform, even on my 10 year old E70 I mix in 5-6 gallons per 20 gallon fillup for an effective 94-95aki rating. How much E85 you can mix in without triggering an check engine light is the question and this is different for each platform. Once you max out your fuel trims, you will start to run lean and the DME will trigger a check engine light with codes usually indicating an issue with mixture control. You have to start off on the lower end and watch your fuel trims, air/fuel ratio and go from there. However you indicated you have access to race gas so I would just toss in a 50/50 mix of 100 unleaded race gas and 91gas for an effective 95-96aki rating and see if your times improve. If it does improve, you can add in more race gas and see if there is any more improvement and find the sweet spot for your tune/engine. Even if your times don't improve, I would still recommend tossing in a few gallons of race or good E85 with each fill-up. It adds buffer to protect against knock/super knock on tuned engines. IMHO all tuned engines should be running at least 93+aki, |
09-29-2022, 07:37 PM | #42 | |
Rep 15
09-29-2022, 07:38 PM | #43 |
Rep 15
09-29-2022, 08:09 PM | #44 | ||
4092
Rep 3,672
Drives: 2022 M5C
