10-14-2021, 09:29 AM | #3 |
767
Rep 1,683
Yep, and for JB4 too
22 M4 Competition xdrive
19 M5 Competition sold 16 F-Type S AWD sold 11 Audi RS5 Misano Red--sold 08 E92 M3 Jerez Black 6MT--sold 08 E92 335i 6MT traded in for M3 |
10-14-2021, 11:41 AM | #4 |
974
Rep 1,795
10-14-2021, 12:23 PM | #5 |
Starlink
24
Rep 92
you can but your bmw uploads/stores all kinds of data including torque, boost, hp, speed etc. numbers and they can see that you were outside the stock numbers and hence decipher there was some sort of tune in place.
10-14-2021, 06:50 PM | #6 |
Rep 38
I took off the JB4 and the drivetrain faults and malfunctions went away. Car was underivable. Hooked back only the TMAP connections an d car drive fine. Started it again and same drivetrain fault and underivable
10-14-2021, 08:53 PM | #7 |
974
Rep 1,795
This is on you 2021 M5C? I hope you get it sorted out.
10-14-2021, 09:35 PM | #8 |
213
Rep 548
You need to update your JB4 firmware. Version 12 I think. If you have the previous 9, it will produce driveline fault in LCI comp pkg, with ewg connected.
You can also disable ewg by clicking bit 5 in the advanced menu, however, this isn’t required with firmware 12. |
10-15-2021, 10:21 AM | #9 |
Rep 38
10-15-2021, 10:22 AM | #10 | |
Rep 38
10-15-2021, 10:48 AM | #11 |
3618
Rep 4,532
10-17-2021, 08:25 PM | #13 |
Rep 38
10-30-2021, 05:24 PM | #15 |
Rep 38
Got the car to Auto Couture. After diagnosing it, the people who installed my downpipes didn't secure the transmission harness properly which led to it melting. Getting a new transmission harness hoping that it will be ready to go. Wasn't a JB4 issue but still won't be hooking up the EWG and only will stick with the TMAP as the Map1 with TMAP pulls harder than with EWG for some reason.
10-31-2021, 10:27 PM | #18 |
213
Rep 548
Do a wide open run from 3rd to top of 5th or 6th gear and post the zoomed in of the WOT section..
Add in more cylinders of timing, boost, trims2. I want to compare yours to mine... What year is your car? Edit, NM, I see a 21, same as me. Did you do a draggy run to confirm it wasn't pulling harder with EWG? Be nice to see a log from that too. I had to turn FF down to 40 on mine the boost was going too high in map2. |
11-07-2021, 11:22 AM | #19 | ||
Rep 16
2020 BMW M5 Competition
Donington Grey |
11-21-2021, 09:19 PM | #20 |
1231
Rep 4,106
I just ran a 10.3 with just tmap plugs in and map 2. 21 comp
Current: 21 M5 Comp, 17 X5M, 06 M3, 14 Ferrari FF, Tesla Model S Performance.
