07-30-2017, 01:28 PM | #1 |
1014
Rep 638
oil testing for Rod bearing failure
You can send away for an oil testing kit, but it often takes too long
I've found that best way to test for impurities is to taste it. A little bit on your finger, it should have a strong nutty flavor, should not smell or taste burnt, if you feel any grit in your mouth or if your gums bleed, could be excessive metal fillings. However don't try this method however with PS fluid or antifreeze, AF always has a sweet taste so you wont tell much and PS fluid smells and tastes gross, you'll probably hurl. I've got that good at tasting oil, I can blind taste oil and tell you which engine it came from, N52 is my favorite, synthetic of course ! Oh and ALWAYS get a professional do do your oil change |
07-30-2017, 01:37 PM | #2 |
63327
Rep 24,658
You can burn your tongue .
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
jaye9441014.00 |
07-30-2017, 02:06 PM | #3 | |
4658
Rep 1,395
Drives: Porsche 993, 2014 MB GLK
excellent shoes for working around the shop
jaye9441014.00 |
07-30-2017, 02:12 PM | #5 |
10785
Rep 8,852
Drives: '15 SO M4/'20 Z4 M40i
Shouldn't this thread be titled "oil tasting" instead of oil testing?
Tejas Chapter, BMW CCA, mem #23915, President 27 years, www.tejaschapter.org
07-30-2017, 02:27 PM | #6 |
4658
Rep 1,395
07-31-2017, 10:51 AM | #8 |
3848
Rep 2,873
You can try, but it will never be as good as doing this prank on new residents with the urine samples.
And it opens up new vistas in the 'which oil' dept - now we can search for one with a distinctive nutty leathery fruity presence, and with good mouth feel. |
07-31-2017, 12:54 PM | #9 |
Hoonigan
6825
Rep 3,000
Drives: '09 328i, '98 Wrangler
She could probably drain out all my oil.
"Yeah, but your scientists were so preoccupied with whether or not they could, they didn't stop to think if they should."
-Dr. Ian Malcolm, Jurassic Park |
07-31-2017, 12:57 PM | #10 |
747
Rep 1,119
On the serious side, is there a mileage interval that you can send your oil to get tested? I've been wanting to do it, but I just did an oil change like 3k miles ago
07-31-2017, 01:03 PM | #11 |
Hoonigan
6825
Rep 3,000
There is no set mileage you need to have. I have used Blackstone Labs many times. I'd go 7k miles or so then send it to the lab and see what they say. Usually if wear metals look good and the oil has additive life left, they will say it can go longer.
07-31-2017, 02:40 PM | #12 | |
747
Rep 1,119
Should've done an oil analysis when I first bought it |
07-31-2017, 04:00 PM | #13 | |
298
Rep 410
07-31-2017, 10:45 PM | #14 | |
Hoonigan
6825
Rep 3,000
Usually you do one sample to establish a baseline, then compare the samples after that.
08-03-2017, 01:02 PM | #16 |
1014
Rep 638
///M Power-Belgium63326.50 |
08-03-2017, 01:51 PM | #17 |
63327
Rep 24,658
Meanwhile ..How sounds your voice , Oily ?
jaye9441014.00 |
08-03-2017, 01:56 PM | #18 |
Captain Fatbelly
1422
Rep 1,994
Depends what you want from it. I do a sample every 1500 miles or so. Costs $28 and takes 30 seconds to pull out a couple oz of oil. The thing about uoa's is that the more frequently you do them, the better your chances are of catching a disaster before it happens. Sure sometimes it's a slow wear that kills a bearing but many times it happens very quickly and the only way to catch it is frequent testing.
2013 c63 Amg coupe p31, v7 tune, plm headers, armytrix downpipes, EflexFuel
2008 dct coupe, evolve engine/dct tune, ttp, ms intake, megan exhaust, cf ds. Sold. |
