BMW M5 F90 (2018+) General Forums iDrive, Nav, Stereo, Bluetooth, Electronics    m5CS coding
      01-20-2022, 11:41 PM   #1
micvite
1540
Drives: 2009 mazda RX8
m5CS coding
Anyone have success coding in the anti dazzle high beams and the extended laser light range yet? Is it basically the same as a regular f90?
r33_RGSport12971.00
      01-28-2022, 08:51 AM   #2
r33_RGSport
r33_RGSport's Avatar
Drives: G09 XM, G05 X5 40, 991.2 T
It is still the same headlight to any other F90 LCI.
I don't think it has laser though.
Let me know if you need to get it coded.
I have done it many2 times.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com
PM for Everyday DEALS!!
MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri
Active Autowerke • KW • H&R • Ohlins • Remus • and more...
      01-28-2022, 02:31 PM   #3
micvite
1540
M5cs has laserights. I'd like to get the lights coded to factory eu spec aka the long range for the lasers and the full adaptive led highbeams with the anti dazzle.
r33_RGSport12971.00
      01-28-2022, 03:13 PM   #4
r33_RGSport
You are right, I just checked BMW parts catalog. CS do come with laserlight.
Maybe Wild Blue can chime in whether his X7 laser light has increased the range after I code it.
AFAIK, US spec laser range is limited by hardware.
I've done many coding on Laser headlight, but can't confirmed whether the coding has increased range or not since it is hard to test it in LA.
      01-29-2022, 01:10 AM   #5
micvite
1540
haha I know I'm right, I was shocked to see it at the dealership when it first came out lol.
That would be great if he can confirm if range increased, I thought it was coding for the shortened range on the laser lights.
r33_RGSport12971.00
      02-03-2022, 12:22 AM   #6
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
When I code the headlamps, I do not change the range. But, with NGHB enabled, the high beams project bright and far enough.
      02-13-2022, 11:02 PM   #7
m5_mbb7
223
Drives: M5CS, M5C, M2C
Could it be possible that it has the laser lights but not the blue outline? Because it says laser lights on the headlight housing but there is no blue thing in the headlight for the cs
      02-14-2022, 09:42 AM   #8
micvite
1540
Correct, the blue is just a design element anyway it doesn't affect anything.
      02-14-2022, 01:47 PM   #9
crypto
crypto's Avatar
1471
Drives: 2022 M5 CS
I'm interested in the results of this if someone does it. Assuming the full laser feature is in there and can be turned on for US cars it would be great. I think the distance the lights on the G30/F90 get is dirt in the best of evening weather conditions.
Current: 2022 M5 CS
Past: 2021 M550i (BSM)
Past: 2010 535 xDrive (Alpine White)
      02-14-2022, 06:37 PM   #10
micvite
1540
Well the full laser is there it's just dummied down to 300m of range vs 800m I'm still trying to find someone that can access an EU spec car and just copy the coding over 100% to get what essentially is factory EU headlight operation.
      02-23-2022, 08:32 PM   #11
Bigcohiba
Drives: M5 CS
Following
      03-02-2022, 04:32 AM   #12
Almaretto
Almaretto's Avatar
2374
E-sys can easily generate ECE spec files so there is no need to pull files from an actual vehicle.
