01-13-2023, 07:51 PM | #1 |
204
Rep 243
why are the front brake calipers so much bigger than the rear?
For both steel and carbon ceramic breaks, the calipers on the front wheels are much bigger (and look better) than in the rear. Why?
01-13-2023, 07:59 PM | #2 |
1122
Rep 2,328
01-13-2023, 08:49 PM | #3 |
106
Rep 191
Because when you brake weight shifts to the front so you need more stopping power on front. The brakes are engineered to what is necessary for performance/safety goals rather than aesthetics…. But I do think big brakes and calipers look cool.
01-14-2023, 02:59 AM | #5 |
337
Rep 578
BMW cost cutting.
2019 M5 - Marina Bay Blue/Silverstone
Adiiirn7.50 Maverik2594146.00 |
01-14-2023, 08:02 AM | #6 |
986
Rep 1,805
Maybe this is his first car.
Maverik2594146.00 |
01-14-2023, 08:05 AM | #7 |
5269
Rep 10,666
Don’t scare away new members. Some may need help learning and we can help them. Others may know a lot and teach us something. It all balances out.
01-14-2023, 08:21 AM | #8 |
1480
Rep 1,312
Only for plebs who driver forward all the time. Reverse gang 4 life.
Current: 2022 M5 CS
Past: 2021 M550i (BSM) Past: 2010 535 xDrive (Alpine White) |
01-14-2023, 08:27 AM | #9 |
2274
Rep 3,302
Fell out of my seat laughing.
Some posts deserve the flame suit. Oh, why are the tires wider in the back? Why does the passenger side mirror have that warning? What are those lines going across my rear window? Mike
Maverik2594146.00 |
01-14-2023, 08:35 AM | #10 |
2043
Rep 1,849
I don't care that the rear calipers are smaller than the ones in the front.
The only thing that bothers me is that the finishing isn't as good as the front ones. The paint is granular instead of being nice and smooth. First world problem I guess |
01-14-2023, 10:43 AM | #11 |
2274
Rep 3,302
You will change front brake pads and rotors twice as often as the rear. So the rear's don't do as much work of breaking. Physics is a bitch.
Mike
01-14-2023, 10:58 AM | #12 | |
4146
Rep 7,164
Drives: F90 M5 / F15 50i
What I hate is the cost cutting doesnt afford a separate parking brake like most high end vehicles. BMW can get away with the floating caliper for performance but fixed will always be the better performer and aesthetically superior choice. Integrating the parking brake into the rear caliper just sucks. Haha
'07 Yamaha R1 (sold)
Alberta2042.50 |
01-14-2023, 11:41 AM | #13 |
5269
Rep 10,666
I thought the front calipers were fixed and the rears were sliders? Floating is a term I have heard only for 2 piece or semi-2 piece rotors.
shawnhayes1838.50 |
01-14-2023, 03:39 PM | #15 |
4146
Rep 7,164
Yes sorry I swapped them on accident. And yes the “sliding” calipers are the same as floating calipers. Funny as I’ve never heard them called sliding before. Haha
01-14-2023, 04:09 PM | #16 | |
1839
Rep 1,328
"sliding" calipers are on a fixed mount that has a sliding rail which the calipers move left and right to compensate for brake piston wear (and perhaps disc movement). "Floating" usually referrs to the rotors. So, you're technically correct from the engineering standpoint, but we try to keep sliding and floating separate to make it easier. Most people don't understand brakes. At all, in any way. Shawn |
01-14-2023, 04:16 PM | #17 | |
4146
Rep 7,164
01-14-2023, 04:18 PM | #18 | |
1839
Rep 1,328
https://www.allrotors.com/blog-65-wh...or-rear-brakes Graphical answer: Technical answer: https://www.autoevolution.com/news/b...le-112010.html Shawn |
BayDriverSF203.50 |
01-14-2023, 04:27 PM | #19 | |
1839
Rep 1,328
Man this is old, and our hero is so so young. Since "floating" rotors came along (thank you McLaren), people have begun to refer to "floating" brakes to be the rotors, and calipers as "sliding" Honestly, you are completely right. You can ACTUALLY have both a "floating" caliper, and a "floating" rotor (but once the rotor floats, the need for having the caliper move has gone away). Shawn |
01-14-2023, 04:37 PM | #20 | |
1839
Rep 1,328
For BMW to put the same piece of garbage caliper on an M5 CS with carbon ceramic brakes as much cheaper and no where near as fast cars should be a CRIME. However, for those of us who have owned fast, heavy cars on track in the past, the rear brakes do so little (unless you leave DSC on, or the brake bias is set badly), that the beauty of having a relatively inexpensive, shared caliper that easily integrates into the family and has an electronic parking brake that easily integrate into the caliper makes a lot of economic sense. This is the reason, pure and simple. That little rear caliper can provide all of the braking and cooling that the car can use in even heavy track use. The front needs to be so much bigger because it does so much more. BMW getting away with using a cheaper part where a cheaper part does just fine. Shawn |
01-14-2023, 05:02 PM | #21 | |
2940
Rep 2,538
Not helpful
Not helpful Not helpful Fair point Spot on. I think it makes some people feel good on the inside to put others down. That and some people are just plain mean. |
G30 B581555.00 |
01-14-2023, 08:25 PM | #22 | |
1543
Rep 2,021
