2011 335D Shut Down Driving - Any Help With Codes
04-29-2024, 08:01 PM | #1 |
Rep 11
So I was driving to work today and the car just decided to completely die while I was just coasting along without even my foot on the gas pedal. I got it coasted into a business parking lot. It flashed something about the transmission on the gauge cluster, but that is all I noticed.
It would not start after that, usually wouldn't crank, but one time it cranked without firing. I got it towed in the afternoon and it was still in the same mode. Ironically after they got it off the flatbed in my driveway it fires up and drives just fine. Any help on codes and where I may begin my search to repair would be greatly appreciated. The car is getting old enough that trying to go to the dealership just isn't worth it. I am trying to post just applicable codes, as some may be related to the battery going dead and not cranking after not driving for a few months during the winter. CF33 - No message, receiver EGS, transmitter DME-DDE CED4 - No message (0xAA), receiver EKPS, transmitter DME-DDE E2C7 - CON: K-CAN communication fault E717, E71A, E71B.E720: Related to communication for climate system from DME-DDE transmitter A3AD - Message faulty (engine data, 0x1D0), receiver KOMBI, transmitter DME-DDE A3AE - same as the one directly above for some other engine data D113 - message missing (drive train data 0x1D0), RDC receiver, DME DDE receiver I would say that I am probably looking at a new DME-DDE receiver? Thanks guys! |
04-30-2024, 03:49 AM | #2 |
466
Rep 2,782
the power to your DDE is switched off during drive
that means that fuse and/or relay is burnt and that means that something which is connected to DDE has a short circuit this can be injectors or glow plug relay or ground straps are corroded and broken also the wiring to the lambda sensors can be damaged by wear and shorted to the ground (exhaust pipe or body)
E81 2007 130i 6cylinder Montego blue
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes. Last edited by ptpending; 04-30-2024 at 04:04 AM.. |
04-30-2024, 11:50 AM | #4 |
358
Rep 1,736
Yup, engine harness melting due to the pressure sensor coming loose would be a good bet.
That being said, check the ground strap first. If it started up and ran fine, probably not a engine harness issue.
'09 335D
05-04-2024, 10:37 AM | #6 |
Rep 11
I finally got to looking. No issues with the back pressure sensor melting any wires. I did a thorough look over of all wires in the top of the engine bay and I do not see any issues.
The car would not start, but this time it was that the batter was almost completely drained after just sitting for a few days. It is a brand new battery from last year. Does that lead to any hints of where to look next? After charging the battery it started up just fine, I let it idle for about 10 minutes with no issues, and finally drove it into the garage from out in the driveway. Once it cools down I will jack it up and remove the bottom engine bay cover and look at things from the bottom end. Thanks in advance! |
POBEP374.50 |
05-04-2024, 07:30 PM | #7 |
8
Rep 108
Test the battery! Like everything else, batteries can go bad too! Also, check your charging and see if all reads right. If the batteries aren't holding charge on these BMW's, all sort of bad sheet happens. You just might be lucky and its a bad bad battery....
05-05-2024, 06:52 PM | #8 |
Rep 11
It is not the battery. It holds a good charge. But I did remove it to check the positive post connections in the battery box since water intrusion before corroded one away. They both look good.
I tried to put everything back together this evening without finding any smoking gun, only to have it decide not to work again while it is now sitting in my garage. I did clean the codes before I started digging around, so here is all that popped up since I tried to fire it up tonight. It would occasionally crank, but would not fire. Module 1 - Car Access System: A0B3 Starter motor terminal 50 Module 2 - Transmission Control Unit EGS: CF33 - No message, receiver EGS, transmitter DME-DDE Module 3 - EFP Control Module EKP: CED4 - No message (0xAA), receiver EKPS, transmitter DME-DDE Moldule 10 - Climate Control: E717, E71A, E71B: Related to communication for climate system from DME-DDE transmitter Module 11 - Instrument Cluster: A3AD - Message faulty (engine data, 0x1D0), receiver KOMBI, transmitter DME-DDE A3AE - same as the one directly above for some other engine data Doing some additional looking around tonight and I have confirmed with my scanner than there is no communication with the DME as it calls it in the basic BMW scanner I have. Worthwhile to try a new DDE relay? That is the path I am leaning on at this point. Any other things worthwhile to check out? Thanks for all the support thus far. Last edited by tabascom16; 05-05-2024 at 10:06 PM.. |
05-07-2024, 11:47 AM | #11 |
358
Rep 1,736
Could be a failing CPS (Crank position sensor). Common problem.
Another thing I'd check is the battery connections behind the rear passenger wheel well lining. This is where they leave the battery compartment and head towards the engine bay. If you pull that off and the wiring is geen and corroded, you can get a repair kit.
'09 335D
05-07-2024, 01:52 PM | #12 |
466
Rep 2,782
then probably alternator failure
did you tried to measure voltage when engine is running ?
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes. |
05-07-2024, 02:02 PM | #13 |
I like cars.
Rep 8
I have the code D113 as well. Screen shows electrical system failure fault. Car runs fine otherwise. Let me know what you figure out! I'm thinking its a failed RDC module. I have an extended warranty so will be sending to the dealer to figure it out.
05-08-2024, 08:46 PM | #14 |
Rep 11
Soooo....the plot thickens. So the DME-DDE relay did nothing.
To answer some others, the cable connections at the battery are good. I made sure to check them. I had corrosion on them years ago from the battery box filling with water, so I replaced them. I decided to jiggle all the wire connectors in the DME-DDE white box, as well as some stuff behind the glove box that apparently connects with it reading some other posts from a Google search. And....well...it is doing something different now. It doesn't immediately flash up any errors when you put the key in, and when you push the start button it will try and crank for a split second, then it stops. It is so frustrating that it ran perfectly fine after it got off the rollback at the house for TWO days! Now I can't get it fired back up again. Something tweaky is going on. Can't really give it much focus until the weekend. Will report back then, but keep some thoughts of things to check now with the update! Last edited by tabascom16; 05-08-2024 at 09:07 PM.. |
05-08-2024, 10:23 PM | #15 | |
Rep 36
Load testing it is the only way to know. A bad battery can cause a lot of problems. Just went through this myself. Load testing is easy diy if you have a friend. Have them hold a multimeter over the posts. Turn headlights on, HVAC, anything that draws power. Then crank er'. If it drops below 9 ish V, battery is toast |
05-19-2024, 01:56 PM | #16 |
Rep 11
Finally getting a chance to mess around with the car today. I swapped a battery in from another vehicle last Sunday and let it sit. After a week it did not have enough power to perform a proper crank.
I jumped it and ran it for about 20 minutes. Tried to start it up again in about 20 minutes and it cranked for a few seconds but never fired up. Had to jump it again. Battery was as just 12.1V. Getting the 4121 code relating to the main relay. Seems like possible alternator woes. Also at the same time I really don't think it was my initial problem as those codes have gone away since I have squeezed and wiggled all the plugs in the DME box. Last edited by tabascom16; 05-19-2024 at 02:32 PM.. |
05-19-2024, 05:06 PM | #17 | |
Rep 36
