BMW
X1 / X2
BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Auto hold
      09-16-2016, 01:41 PM   #1
lrd300
Drives: BMW X1 M Sport
Auto hold
Is it possible to retofit or code the auto hold function on the x1?
      09-16-2016, 05:25 PM   #2
ttimbo
ttimbo's Avatar
282
Drives: F48 X1 25i AW; F20 M135i AW
There is a semi auto hold function...of sorts. If you're stopped in traffic, apply the park brake, lift your foot from the brake and the car will hold. Traffic starts moving, so press the accelerator and the park brake automatically releases. Works well enough for me in these situations I need it.
BMW F22 M240i; F48 X1 25i, BMW F20 M135i
Peugeot T9 308 GTi 270
Renaultsport Megane 3 Trophy-R, Renault Clio Sport 182.
Appreciate 2
CliveL163.00
nathanm4684.50
      09-16-2016, 06:43 PM   #3
brissim
86
Drives: X3 30d (2011 F25) - now sold
I'm sorry but what you've written there is just plain nonsense - you have to manually engage the park park - that's not auto hold. What you have described is the auto-release function that every car with an electronic park brake has.
In answer to the original question - no I don't think you can. I asked about this when I was looking at the X1 and realised (in our Australian market and apparently yours as well) it didn't have an auto-hold function. While most of the work is just coding, you still need the button to engage auto-hold (which is blanked off in X1s in our market) which works with the coding.
Tony
      09-17-2016, 01:59 AM   #4
ttimbo
ttimbo's Avatar
282
Geez, calm down Tony....I did say "semi-auto hold", which does everything auto hold does AFTER you've engaged the park brake. And no, there's no coding alternative in any market, so far as I'm aware. Which is as good an answer to the question as anything else. OK?
Appreciate 2
MJE60681.00
wcs2229170.50
      09-17-2016, 03:28 AM   #5
E90Fleet
South Africa
1312
Drives: BMW
No X1 anywhere have Auto Hold., so it cannot be coded or retrofitted.
BMW if you are reading, I need a job, Please.
      09-17-2016, 03:40 AM   #6
The Beast
The Beast's Avatar
United Kingdom
268
Drives: VW Transporter Sportline
It's really frustrating that they left this feature off the X1! Just can't see the logic in not having it present.
I do the same as ttimbo although it's nowhere near as smooth as auto hold and you have to have your foot firmly on the brake or it triggers the stop start when you release your foot from the brake
      09-17-2016, 03:56 AM   #7
Nivarox
Quadrex
Nivarox's Avatar
1094
Drives: W212 Mercedes=Benz E Class
I have BMW i8 ,it doesn't have it either . However, it works when you are on the hill and apply the brake for 2 seconds then you let your foot off the brake pedal without having to press the electronic P button ,the car holds . Slightly touch the gas pedal , the car moves.I find it a bit weird given the fact that it only works only when you're on the incline
Comparing BMW i8 to Tesla Is Like Comparing Apples to Pineapples
      09-17-2016, 07:49 AM   #8
E90Fleet
South Africa
1312
Drives: BMW
Thats hill assist. Most BMW's have that. Auto Hold is a bit different
      09-17-2016, 07:56 AM   #9
E90Fleet
South Africa
1312
Drives: BMW
It was never incorporated into the Mini F56 systems the X1 systems are based on
      09-17-2016, 06:29 PM   #10
brissim
86
And your answer is still nonsense - clearly you don't know what auto-hold is.
Tony
      09-17-2016, 06:34 PM   #11
brissim
86
That's the aspect of auto-hold we really appreciate - the way it interacts with the engine stop/start system. With auto-hold engaged you can take your foot off the brake and the engine remains stopped. Much more relaxed city and town driving. After 5 years of it in our F25 X3 we are very reluctant to go without in our next car.
Tony
      09-18-2016, 08:41 AM   #12
The Beast
The Beast's Avatar
United Kingdom
268
Tony
I know I was astounded it wasn't present when I test drove the X1, I have it on my F10 and on my previous E70 too. I appreciate it's a Mini platform but surely it can't be difficult for BMW to add it as it's just a button and some programming.
However it wasn't a deal breaker as for us the X1 was a much better vehicle than the alternatives we were looking at... I've got used to using the electronic brake when I drive the car, it's not ideal but workable
Current: VW Transporter Sportline, F48 X1 20i M Sport. Previous: F10 530d M Sport, W176 A200 CDI AMG Evolution, E70 X5 3.0 SD M Sport, F20 120d M Sport, E81 120d M Sport, E46 325i M Sport, E46 318ci & Many Others...
      09-18-2016, 09:32 AM   #13
E90Fleet
South Africa
1312
Drives: BMW
Tony
BMW's way of getting you to rather buy another X3 or higher.
Higher models always have better equipment and fittings.
      05-15-2019, 10:22 PM   #14
tinymilad
Drives: 14 i3 Rex
I opened the electronic parking break switch and the switch to turn on the auto hold is there on the circuit board behind the e-brake, it even has the led light. It activates auto hold without the need for any coding, But no actual actuator button is there. The enclosure does not have a place for a button for activation of auto hold. I drilled a hole so I can activate the auto hold switch with a thin metal rod, but that is not the cleanest way to do this, buying switches on eBay to see if any of them can be retrofitted. I'll post photos tomorrow
Appreciate 4
      05-16-2019, 06:59 AM   #15
Douggie
145
Drives: BMW X1, X3
Wow. That's interesting! Keep us posted on this. Thanks.
iceman7117.00
      05-16-2019, 11:52 AM   #16
MJE60
MJE60's Avatar
England
681
Drives: BMW G01 xDrive M Sport
Is it possible that an X3 park brake switch could be fitted in place of X1 switch?
http://www.bavarianmw.com/guide-3174.html
      05-16-2019, 12:48 PM   #17
tinymilad
Drives: 14 i3 Rex
The x3 switch won't fit
      05-16-2019, 12:50 PM   #18
tinymilad
Drives: 14 i3 Rex
Photos
iceman7117.00
      05-16-2019, 12:53 PM   #19
tinymilad
Drives: 14 i3 Rex
Photos
iceman7117.00
      05-16-2019, 12:54 PM   #20
tinymilad
Drives: 14 i3 Rex
Photos
iceman7117.00
      05-16-2019, 12:55 PM   #21
tinymilad
Drives: 14 i3 Rex
Photos
Appreciate 2
iceman7117.00
COUWK21.00
      05-16-2019, 01:14 PM   #22
tinymilad
Drives: 14 i3 Rex
Photos
xbimmers
