09-19-2022, 07:58 AM | #2 |
271
Rep 425
They're not the same. There are physical differences. The most obvious being that there is a bridge that joins both sides of the caliper behind the pads, preventing the pads being removed without removing the caliper first.
My understanding is that there's a number of difference across the whole brake system also. |
09-19-2022, 09:05 AM | #3 |
5269
Rep 10,663
I think there is a slight width and diameter difference to the rotors that the calipers may accommodate or that may be handled through pad size. But I think you can buy aftermarket steel rotors for the carbon spec calipers and you can buy aftermarket carbon rotors for the steel spec calipers. I would probably not mix and match stock parts, but I have not tried.
09-19-2022, 11:51 AM | #4 | |
4146
Rep 7,164
Drives: F90 M5 / F15 50i
'07 Yamaha R1 (sold)
09-19-2022, 12:26 PM | #5 |
271
Rep 425
You might be right. I’ve been reading about brakes that much that I could be talking about the F80 versions. I have read that the hardware is different though. Apparently the brake booster is a different part number also.
09-19-2022, 04:57 PM | #7 | |
1839
Rep 1,328
However, the rotor backing plate for the CCB is bigger than the steel ones. If there's any good reason for the difference, it's so when your dumb ass (me, that is), yanks the wheel off and lets the wheel barrel drop more than you want it to, it hits the backing plate and not the rotor. Trust me. It is clearly designed to do that. But to address the rest of the discussion, I've looked into this one A LOT. The calipers are physically different. They are because the CCB rotor is 410 x 38 mm. The metal rotor is 400 mm x 36 mm. You can THEORETICALLY put the metal rotor and pad into the CCB car, but there will be a 5mm difference in the edge of the rotor. There's AT LEAST a 2mm overhang of the CCB rotor over the caliper (the pad is inboard 2mm from the edge of the CCB). So the metal rotor may not engage about 3mm of the pad. This WILL work, and WILL stop the car. BUT, there's a caveat that I do not know now. I do NOT know the "backspacing" of the rotor. I do NOT know if the metal rotor, shoved into the CCB rotor caliper, will be "centered" within the caliper. I just have no clue. RacingBrake had to buy a used F90 metal caliper to figure out all their dimensions. I don't know if they bought a CCB caliper and rotor to work it out. One thing I can say FOR SURE, is that you CAN buy the "blue" calipers from the base car and bolt them on with the metal brakes. The upright is the same. There's no other conclusion. Front and back. If you get the blue calipers, you're golden. Bolt them up, with metal rotors, and go. I have theorized that the rear brakes will use the metal rotors just fine. They are both 396mm. The metal rotor is 24mm wide. The CCB is 26 mm wide. I'm really really certain the caliper is EXACTLY the same (just as every OTHER shitty back caliper on a BMW with electronic parking brake. The mount frame MIGHT be different, but the caliper is the same.). I cannot confirm this for sure. Shawn |
Chubbiejones892.50 |
09-20-2022, 11:44 AM | #8 | |
4146
Rep 7,164
really just need someone to take a pair of "measuring" calipers and get the inner dimensions of each caliper and see if the CCB ones are 2mm wider. I know that when you put in new pads you do have some wiggle room when sliding them over the rotor. question is, is that wiggle room equal to at least 1mm of travel for each bank of pistons. bottom line is i bet the blue ones would fit.
09-20-2022, 11:55 AM | #9 | |
1839
Rep 1,328
$1000 pads every two track events is getting OLD. I could PROBABLY get three, but I don't wanna risk it. Shawn |
09-23-2022, 10:07 AM | #10 | |
4146
Rep 7,164
09-23-2022, 11:29 AM | #11 |
1839
Rep 1,328
09-25-2022, 12:03 PM | #12 |
4146
Rep 7,164
Yes. You shouldn't have issues going smaller. I know most that buy used cars with ccb just replace with iron on the F10. Should be the same. Only issue I could see is pad wear issue if it sits too high on the steel rotor. But I believe there is a slight west line on oem rotors where the pads don't make full contact as it is.
09-25-2022, 08:07 PM | #13 | |
1839
Rep 1,328
Shawn |
09-26-2022, 09:04 AM | #14 |
5269
Rep 10,663
As someone changing pads and rotors to send you worn out pads and one rotor for a test fit. I would not worry about the 2mm thinner rotor (when new) even if it is not evenly spaced and all on one side. If there was an extra 1/4 inch of pad at the top and bottom, that would be more concerning. Maybe using steel spec pads in the CF spec rotor would address that or maybe only partially. Probably pad material could be trimmed off the backing plate but I have never tried that.
09-30-2022, 02:27 PM | #15 | |
1839
Rep 1,328
Shawn |
10-10-2022, 12:33 PM | #16 |
1839
Rep 1,328
Confirmed. Steel rotors and pads WILL FIT the ccb calipers.
ResIpsaLoquitur4145.00 Maverik2594146.00 |
10-11-2022, 07:02 AM | #17 |
5269
Rep 10,663
Are you going to buy a new set to try at the track? I am curious to see your impressions of the difference in braking performance. And whether the steel rotors and/or whatever pads you choose for them wear faster enough that the cost savings disappears.
10-11-2022, 08:17 AM | #18 | |
1839
Rep 1,328
Shawn |
10-11-2022, 10:29 AM | #19 |
5269
Rep 10,663
2018 was not competition. Maybe the 2019 comp models changed the rear brake bias in MDM or maybe it was part of the LCI update. I would hope BMW is improving software over the years.
shawnhayes1838.50 |
10-11-2022, 12:05 PM | #20 | |
1839
Rep 1,328
Shawn |
