2Addicts
2Addicts
2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum quickie on cooling system
      03-22-2024, 10:13 PM   #1
nazali
nazali's Avatar
1310
Drives: 230 2020 vert F23
Just a quick ask
1> Can I just do a top up of the exp. tank, if its a little low (no errors)
2> IF doing a drain and fill must I use a vaccuum system
2a> if yes, there is the high and the low, which would I use ?
txs
      03-22-2024, 10:16 PM   #2
nazali
nazali's Avatar
1310
sorry another one,
why can I not just use a watering can method and then "BLEED" it using the factory procedure ?
txs
      03-23-2024, 08:59 AM   #3
MarcoZandrini
Drives: 2018 M240i
1. Yes, you can top off the coolant levels (1 for the engine, 1 for the intake manifold intercooler).
2. The system has to be filled by using a vacuum filling system.
3. There a procedure, listed in the BMW TIS, that outlines how to bleed the system. So, no, you can not bleed it the traditional method.
      03-23-2024, 10:30 AM   #4
freakystyly
2994
Drives: F22 B58 6MT
You can still use the old method (look it up, there's a lot of steps) but it isn't as effective. BMW recommends the vacuum method because it removes more air from the system and also their liability for error.
      03-23-2024, 02:04 PM   #5
nazali
nazali's Avatar
1310
txs all,
so what I've looked into further from also your replies,
1> yes
2> there is a high and low and both must be vacuum filled
a> but it looks like the drain point according to NewTIS is the same point for both
There appears to be a fill section in TIS for high and low
and also there seem to be 2 separate bleed sections again for high and low
Would iot be simply easier to get BMW to do a refill at that point if I wanted a system change done
Have you guys done it your yourselves
awesome
2addicts
