2Addicts
2Addicts
2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum What did you do to your 2 series today?
      03-10-2024, 10:11 AM   #5501
Dantesboyz
recovering e36er
Dantesboyz's Avatar
Drives: 2017 M240i Xdrive
Yesteday, sparkplugs on the daughters impreza, it was no fun in summary, lol.
Today, back on the bimmer, first drained the oil catch can.
Next gonna pull the TU pump off and sell it, need that last little financial bump to buy the Dorch DS25. Putting the oem hpfp back on in the meantime.
I'll have the TU hpfp posted for sale later today.
Got spring PM coming up, wanting to replace both the vanos solenoids on the back of the head, where's the go to for those these days?
2017 F22 M240i, Xdrive, M Performance Package
Active Autowerke Downpipe, Dinan Carbon Fiber Intake, Dinan Carbon Fiber Turbo Inlet, Dinan Mid-pipe, xHP Flashtool, MHD Stage 2
To do next list- #1- Wheel Spacers & Tires, #2- B58 TU Pump, #3- Flex Fuel Kit
Appreciate 2
JMcLellan2063.50
      03-11-2024, 09:29 AM   #5502
DS_BMW88
Sweden
21
Drives: BMW 218i Coupe
Retrofit M2 shifter
I installed my M2 paddle shifters and carbon insert on a 2 coupe. Looks so much better
Appreciate 2
      03-11-2024, 09:47 AM   #5503
owenscj21
owenscj21's Avatar
53
Drives: 2016 BMW 228i M Sport
Today:
Replace Shifter Shaft Seal
23 12 8 677 736 - Seal
Replace Thrust Arms
31 12 6 855 741- Thrust arm
31 12 6 855 742 - Thrust arm
Alignment
Last month:
Replace Headlamp Assembly
63 11 7 363 091 - Driver Module for Headlight
63 11 7 388 931 - Bi-Xenon Headlight
63 11 7 318 327 - Headlight Module
March 2023:
SPARK PLUGS - Remove & Replace
12 12 0 039 664 - Spark Plugs
INTERCOOLER - Remove & Replace
CTS-F20-F30-DF CTS TURBO BMWF20/F22/F23/F30/F31/F34/F36 1 SERIES, 2SERIES, 3 SERIES AND 4 SERIES FMIC KIT
F-N20-CPM VRSF Chargepipe
CTS-IT-345 CTS TURBO N20/26 BMW228I/320I/328I/428
CTS-EXH-DP-0054-CAT CTS TURBOF2X/F3X 228I/328I/428I & XDRIVE N26HIGH-FLOW CAT
BALL JOINT - Remove & Replace (Both)
SHOCK &/OR STRUT ASSEMBLY - Remove& Install or Remove & Replace (Both)
33 52 6 873 724- REAR SHOCKS
33 53 6 855 439- BUMP STOP WITHBELLOW
33 50 6 865 257- SHOCK MOUNT
Brake Fluid Flush
64 11 9 237 555 - Cabin air filter
FLYWHEEL (STD TRANS) - Remove &Replace (Coupe)
21 20 7 625 147- OEM CLUTCH KIT
21 20 7 638 306- DUAL MASS FLYWHEEL
It's been a costly 12 months. Luckily the clutch replacement was covered by insurance.
2016 228i M-Sport 6M RWD- CTS Intake, CTS FMIC, VRSF charge pipe, CTS catted downpipe, FTS Stage 2 ECU
      03-11-2024, 09:51 AM   #5504
tlum235i
Drives: BMW M235i
Just reached 140,000 miles. Had to do the valve cover gasket (I replaced the valve cover just in case too). I also did the MST turbo inlet since there was work needed in that same area. I should’ve done the turbo inlet pipe a long time ago. Don’t be like me and wait so long. The throttle response is so much better now; it kinda surprised me once I drove it after the install.
Appreciate 5
      03-14-2024, 02:11 PM   #5505
Freewheeling
Drives: BMW 128i
Waxed her up and went for a rip in the North GA mountains.
jzeiler4320.00
      03-17-2024, 01:20 PM   #5506
kz1000
Mensch
kz1000's Avatar
60
Drives: 2021 230i 6mt
Nothing. It's been at the body shop for 2 weeks. Hopefully. I'll have it back this week. The Honda SUV rental I've been driving is gonna breathe a sigh of relief.
      03-17-2024, 07:28 PM   #5507
dradernh
dradernh's Avatar
4412
Drives: 2017 M240i
I drove mine, which I now do less and less even though I enjoy it as much as I ever have.
From Cincinnati, I ran OH-131 out to Fayetteville, US-68 down to Ripley, and then rolled back on US-52 along the Ohio River (which was very high).
While out of the built-up urban areas, it was remarkable how few cars were on the roads. Living in a basketball-mad region (which I'm not from), I'm thinking maybe people were home watching one basketball tournament or another.
2017 M240i: 23.8K, 28.9 mpg, MT, Sunroof Delete, 3,432#, EB, Leather, Driving Assistance Package, Heated Front Seats | Sold: E12 530i, E24 M635CSi, E39 520i, E30 325is, E36 M3 (2)
TC Kline Coilovers; H&R Front Bar; Wavetrac; Al Subframe Bushings; 18X9/9½ ARC-8s; 255/35-18 PS4S (4); Dinan Elite V2 & CAI; MPerf Orange BBK; Schroth Quick Fit Pro;
GTechniq Crystal Serum Ultra Ceramic; Suntek PPF
WolfGTI716.00
      03-17-2024, 10:07 PM   #5508
brakthru
83
Drives: 2007 BMW 335i
Originally Posted by Ajowhan View Post
Good question, I dont know the answer but personal opinion would be same or similar wheel well clearance on coupe vs convertible. Front camber is not adjustable I think so should be pretty similar, I think my rear Is 1.9. The springs definitely tighten up body roll. Its not much but its noticeable. Will it improve cornering speeds? this will highly depends on you as driver. Personally while I feel that I drive corner more confidently, I dont feel like I hit corner faster.
That makes sense. Thanks.
      03-18-2024, 11:35 AM   #5509
NKOTB2015
21
Drives: Lexus LS460, Toyota Sequoia, B
Over the weekend, replaced front and rear brake rotors and pads. Installed front lip. Now I have to drive even slower to get outta my driveway.
      03-18-2024, 10:07 PM   #5510
dradernh
dradernh's Avatar
4412
Drives: 2017 M240i
To exit and enter my driveway, I lay down 2X4s to fill-in the street-to-curb transition so the front lip doesn't wear the concrete curb away too fast.
The neighbors laugh, but they're all driving SUVs.
JMcLellan2063.50
      03-19-2024, 11:37 AM   #5511
NKOTB2015
21
I may need to look into something like that...
dradernh4411.50
      03-19-2024, 11:55 AM   #5512
freakystyly
2994
Drives: F22 B58 6MT
Entering/exiting driveways on an angle helps greatly too. I noticed stock ride height cars scrape on ours if you drive straight on. Probably not going to add a lip to mine, even though I have one sitting in the basement...
Post a picture of your lip if you get a chance!
      03-19-2024, 12:11 PM   #5513
albertw
116
Drives: M240i
I like Curb Ramps. They're heavy (made of recycled tires usually), stay in place when you drive over them, and kids can't move them. They look like they belong (somewhat), instead of like random trash.
18 M240i RWD auto
Previous: 01 Z06, 99 323i
Mike F.103.00
      03-19-2024, 01:05 PM   #5514
JMcLellan
JMcLellan's Avatar
Drives: 2024 M2
I gave in and put a front plate on my car. This removes that nervous feeling I get when I drive by cops here in MN (where front plates are required) though I have not heard of anyone getting pulled over for not having a front plate. I really like the product that Sto n Sho has making it so easy to take the plate and mount on and off. Definitely starting slow with the mods. A couple weeks back I had the full front and the rockers PPF'ed, and window tint done. Next up is wheel spacers.
2024 M2
2019 M240i- Sold
Appreciate 4
      03-19-2024, 05:34 PM   #5515
jzeiler4
jzeiler4's Avatar
Drives: 2021 M240i xDrive vert
Your M2 actually looks pretty good in that color, did not like the baby blue one I saw.
JMcLellan2063.50
      03-19-2024, 06:43 PM   #5516
cooolone2
cooolone2's Avatar
625
Drives: 20' M240iX B58, 01' 330XI E46
Actually registered it in another State that'll allow me to wear just one plate (rear)... So happy! Lol
Front tow bracket plate holder probably for sale soon, hahaha.
No pics because I need to get home and swap plates first!
      03-19-2024, 07:31 PM   #5517
Dantesboyz
recovering e36er
Dantesboyz's Avatar
My 17 yr old daughter bought me the red button for Christmas on all on her own initiative.
It wasn't really on my mod list, but finally got around to installing it. I appreciate that she thought to get me a thing for the car, and then did her own research and proud she actually got the right part.
Appreciate 6
      03-19-2024, 08:21 PM   #5518
freakystyly
2994
Drives: F22 B58 6MT
Needs more duct tape
https://www.carscoops.com/2024/03/de...but-duct-tape/
But yeah, the BSM looks best.
JMcLellan2063.50
      03-19-2024, 09:23 PM   #5519
dradernh
dradernh's Avatar
4412
Drives: 2017 M240i
I'd be golden if I had a two-car garage, but the driveway for the one-car garage I've got isn't wide enough to achieve the sharp angle I'd need with the car lowered and the #*!@$+ curb higher than it should or needs to be. On both sides of me are units with two car garages, and they've got curbs I could easily clear.
      03-20-2024, 07:15 AM   #5520
NKOTB2015
21
One of my neighbors had one of these...i saw it for a while but then he removed it. Didn't think much of it but then I asked and he said he received a letter from HOA to remove it from the stree.
I have a fairly wide driveway so I have plenty of room to angle out...i just go super slow when I reach the end of the driveway.
      03-20-2024, 08:50 AM   #5521
JMcLellan
JMcLellan's Avatar
Drives: 2024 M2
I had a chance to get a deal on a ZF blue one but it never felt right for the shape of the M2. I also didn't want a flashy colored car and get unwanted attention. I'm good with the BSM blending in but keeping it clean and free of waterspots is a nightmare. I might have to pony-up for ceramic coating.
2024 M2
2019 M240i- Sold
jzeiler4320.00
      03-28-2024, 03:40 PM   #5522
k1drapela
Drives: BMW 228i
New Stuff
I ordered a new windscreen for my 2016 228i XDrive convertible and some exhaust tips.
2addicts
