Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > 2011 335d - Occasional Belt Squeal at Start Up
      06-27-2014, 04:44 PM   #89
m80theWolf
m80theWolf's Avatar
Drives: 2011 BMW 335d
I didn't read the whole thread, but this happened to me also. It ended up being an oil leak, leaking out onto the ac belt primarily. Car would squeal for about 10 seconds after turning on ac, especially common on startup.
      06-29-2014, 12:54 AM   #90
DieselRacer
BMW Advanced Diesel, 2011 BMW 335d M sport...
DieselRacer's Avatar
Drives: 2011 335d M sport
Mine just did it today for the first time, 52000 miiles, I have an extended warranty but I don't think they will take care of me on this one, I heard there was a bulliten poseted about this with bmw, maybe I can use that as leverage, anyone have any ideas if I can get them to cover it....
BMW Advanced Diesel, 2011 335d M sport...
      06-29-2014, 04:15 AM   #91
Pierre Louis
Drives: 2016 535d
I had mine fixed under warranty - a rattle that was the AC unit - new unit put in.
Later (around 40,000 miles) it needed a new belt, which is what the squeak on startup was.
PL
      06-29-2014, 12:03 PM   #92
Yozh
Yozh's Avatar
870
Drives: 2011 335d M-Sport
If your warranty will not cover it, your can swap the belts yourself. They are cheap to buy, a bit of a pita to snap on there, but doable. Another option is you can try tightening the belt before you replace. Tightening is done with the compressor bolts.
      06-29-2014, 12:46 PM   #93
DieselRacer
I just got a belt for $8, Autohauz AZ, 11-28-7-520-177, oem new recommended part, it is not a BMW belt persay but it is the one recommended here and by BMW now...
      06-29-2014, 01:03 PM   #94
Yozh
Yozh's Avatar
870
Yeah, they are about $20 for the genuine. BavAuto and ECS has them for $10 Continental made ones.
      07-01-2014, 11:24 AM   #95
myculito
11
Can you provide some guidance here on how the belt can be changed? Do you know of a DIY?
      07-01-2014, 11:33 AM   #96
myculito
11
Originally Posted by taibanl View Post
I would approach them again.
The original part was defective the day it rolled off the production line, that is why they switched parts. Though you may not have had symptoms until after warranty expiration, the defect existed during your warranty.
My dealer would do it under goodwill. Problem is, I don't want a $140 repair to eat up one of the 3 goodwills we get.
I had a service manager tell me that BMW recently changed their policy on providing goodwill fixes, and that owners will get three, and it's on a sliding scale.
      07-01-2014, 11:37 AM   #97
DieselRacer
I would love to see paperwork on that...
      07-01-2014, 12:38 PM   #98
myculito
11
So would I to be honest with you, but I'm powerless in this situation.
      07-01-2014, 12:58 PM   #99
DieselRacer
Just talked to my SA, Monday I take car in for the check on this, I need to find the SIB so I can show them, makes it easier to deal with them...
      07-01-2014, 10:39 PM   #100
Yozh
Yozh's Avatar
870
Please do so at your own risk. I'm not responsible as this is only what worked for me and based on my limited experience. I do not have an official repair manual nor have I got any instructions from any official source. I'm sure dealers use special tools.
You will need to remove the under tray. AC condenser is held by three long bolts. See here:
http://www.realoem.com/bmw/showparts...96&hg=11&fg=18
http://www.realoem.com/bmw/showparts...21&hg=64&fg=50
Loosen the front two (front-rear as in reference to the front-rear of the car). The rear one is the one that controls the tension on the belt. Start releasing the rear bolt. You will see the condenser tilt towards the front and belt will loosen. You may have to nudge it a bit. Remove old belt, install new. Installing the new one will be difficult as you will still need to stretch it onto the pulleys. I did this by removing all three bolts, this may be necessary. I was doing some other repair and thus needed the compressor off anyway.
Anyone else that wants to correct me, please chime in.
      07-08-2014, 05:19 PM   #101
myculito
11
So you essentially removed all 3 bolts?
Did you have to remove the serpentine belt as well?
      07-08-2014, 06:01 PM   #102
myculito
11
Okay, so I've researched this a little more, and it may not be necessary to loosen those AC compressor belts to install this belt.
Lisle makes a tool for this. Tool model is 59370, and looks like this:
Video of how it works is here: https://www.youtube.com/watch?v=OEI_06b1F_8
      07-08-2014, 11:03 PM   #103
DieselRacer
Bmw would not fix my belt for free, im at 51000 with extended warranty, said it was a maintenance, then I told him its not because your not going to replace it with the same part because it the wrong size, he did not know what to say and I went on my way. He also compares diesels to a prius and does not know why anyone would buy them with all the maintenance problems, I explained its not a diesel problem but a BMW bad design problem, lets just say he learned a few things after I explained the whole engine to him in a half hour, WHAT A JACKASS...
      07-08-2014, 11:38 PM   #104
Nushibo
Nushibo's Avatar
23
Drives: 335D
2011 BMW 335d  [0.00]
Just replace it yourself when you have the time. Its not worth creating a fuss at the dealership.
      07-09-2014, 12:10 AM   #105
DieselRacer
As soon as I drove off the lot I changed it, right after I hooked back up my JBD, I ordered a belt last week, they did fix my brake lights it was flickering so all were replace free...
      07-09-2014, 12:58 AM   #106
myculito
11
How did you change it?
      08-07-2014, 02:55 PM   #107
Nushibo
Nushibo's Avatar
23
Drives: 335D
Same question. Im looking at the compressor and the 3 bolts are in a very tight spot. Diesel did you use a special tool? id be easy if it had it but im looking for another method.
      08-07-2014, 03:24 PM   #108
skychismo
Drives: 2011 335D
They replaced my belt under warranty at BMW north scottsdale because of squeaking.
      08-07-2014, 03:25 PM   #109
skychismo
Drives: 2011 335D
That sucks. BMW north scottsdale replaced mine for free with the updated one under warranty.
      08-07-2014, 04:33 PM   #110
DieselRacer
What is your millage, if I was under 50k they would have, im at 52k with extended warranty and no go...
