09-05-2023, 06:42 PM | #1 |
26
Rep 75
Rear diffuser
Has anyone had this issue where the rear diffuser in gloss black fades? I just noticed this the other day on my M5C and wasn't too happy. I have no idea why just that piece would fade. Thanks and please let me know!
09-05-2023, 06:55 PM | #2 |
850
Rep 485
Haven’t seen that on the forum. How many miles on the car? Is it outside in the sun all the time?
Typically plastic trim gets faded by sun exposure. If that’s what it is you can remove a lot of the oxidation with a tire/rubber cleaner which helps bring back the black look. Then ceramic coat it to help protect against recurrence. If it’s really bad you can get a trim restorer kit like this that actually puts black pigment back into the trim piece and ceramic coats it. https://adamspolishes.com/products/c...30207961858145 |
09-05-2023, 07:09 PM | #3 | |
26
Rep 75
Kinda frustrating a car of this quality having a piece fade that quickly. |
09-05-2023, 07:21 PM | #5 | |
850
Rep 485
09-05-2023, 08:17 PM | #6 | |
776
Rep 569
Drives: 2019 M5 Competition
Unless you're the original owner of the car? Maybe previous owner had a carbon fiber version and removed before trading or selling? Ive also seen some people paint the OEM one to be color matched or different variations (which looks terrible). Of course if you are the original owner of the car that would de-bunk that, and could just be a defect. Or maybe it was replaced at some point and never painted to begin with? Do they come just black primer colored plastic from BMW if it's replaced? I dont know, but it shouldn't be fading unless there is something else in play here. But, im I live in AZ, and while my car is garaged the majority of the time, it still sees a lot of sunlight, and not a hint of fade on mine, unless the entire black piece is faded on mine evenly to match the diffuser. |
09-05-2023, 09:01 PM | #7 | |
26
Rep 75
09-05-2023, 09:56 PM | #8 | |
776
Rep 569
It’s very possible it is an actual OEM bmw part, but still been replaced due to some one backing up into to something or other type of damage. I don’t believe they come painted when replaced. So if someone replaced it and had a poor paint job done on it, or not painted at all that would be the issue. The rest of the black insert I would imagine is original. It’s possible That insert is original also just painted outside of the factory for some reason. Damage it wanted a different color and changed mind who knows . But that’s my guess |
FSHNGRY2389.50 carseatsm5849.50 |
09-10-2023, 02:54 PM | #9 |
2390
Rep 2,060
Drives: INDIVIDUAL F90 M5C LCI
never seen that before. But I'm in line with what he said ^
CURRENT: '21 M5| FSHNGRY | TARTUFO | CCB | MPE | KW | IND | EVENTURI | EISENMANN | DINAN | LOADED |
GONE: '15 F82 M4 | YMB | IND | MPERF | KW | BM3 | LOADED GONE: '11 E92 335IS | BLKSPHR | OYSTER | LOADED GONE: '05 E46 ZHP | LOADED | DINAN STG3 PKG | IG: @FSHNGRY |
09-11-2023, 07:57 PM | #10 |
31
Rep 85
I just noticed the same thing on my car the last couple of weeks, my car is also ceramic coated, not as bad as urs but def has a blue haze to it, i thought it was only on my car
Jeffrey jaquez
09-11-2023, 09:54 PM | #12 |
776
Rep 569
Hard to tell in the photo, it looks glossy based on some of the shadows and highlights, but for clarification is the piece more matte in its fading ?
Like not just the color turning grey-ish, but is the finish also dulling? not as glossy ? This photo almost appears it is like a black plastic piece and not even painted at all. Much like it would be on some cars with black bumpers or wheel well trim the is just black plastic? It almost looks like it's a piece from a gray car. It's very odd. Because if it was like UV fading from sun exposure etc, I would think it wouldn't fade evenly like that. Like the part that sees the most sun would be more faded than say the bottom of it. Pull it off and see if it's a BMW OEM part, and if it's even painted. If the car is under warranty maybe they would replace it, maybe there was a batch of these that got bad paint? Very odd part to fade especially where it's located on the car. even in sunny climates I would think that area wouldnt be fading much from UV. |
09-21-2023, 09:15 PM | #13 |
44
Rep 134
I just replaced mine with a carbon fiber diffuser. It had started doing the same thing and it’s OEM. Not near as bad as that, but it has started the fading process.
09-28-2023, 01:16 AM | #15 |
1659
Rep 2,406
Definitely isn't right....if they won't replace it, just wrap it in gloss black.
That diffuser is the same material as the black plastic piece above and around it....so it's odd that piece is fine.
2022 M8 Comp GC, 2021 AMG GT53, 2022 X5M Competition, 2021 X7 40i, 2019 M5, 2018 M550I, 2017 Audi Q7, 2014 M6 GC, 2013 Mercedes CLS550, 2011 750LI, 2008 M6 Cabrio, 2008 Porsche Cayenne S, 2004 Mercedes SL55 AMG, 2003 Mercedes SL500, 2000 Mercedes CL500, 1993 Lexus SC400, 1989 525i, 1985 318i
