05-31-2022, 02:37 AM | #1 |
1540
Rep 2,008
m5 comp dropping boost
Anyone else take their cars towards the electronically limited speed? I've noticed my car has easily 22-24 lbs of boost in 1st and 2nd, drops to around 17-19 in third and 4-5th towards redline I was maybe around 12-14, 6th towards redline I was looking at like 10 lbs. Is this normal? Honestly took the f90 longer to get to 170 than my camaro with 460 hp did... and by 180 was almost struggling... 70 degrees outside and wasn't pushing the car too hard prior so definitely not heat soaked or anything. Coolant was around 170-180 (drops when you floor it) and oil around 200. This is all based on the in car boost gauge so not perfectly accurate as far as readings go (you have 0 15 and 30 so it's guesstimates in-between those values) but still when it's reading under 15 at WOT I'd say somethings not quite right...
05-31-2022, 02:51 AM | #3 |
1540
Rep 2,008
Interesting, mine definitely drops off towards redline, comes back a bit after the shift and immediately drops off again... it's just gets lower and lower, are you stock? Not even sure how I'd bring this up to bmw... so hey I was doing 180 and noticed my boost was super low... it'll be one of those "customer states" videos lol. Like how would they even verify that kind of fault since I know they won't test drive the car over 80 and it's more or less fine until 100...
05-31-2022, 04:40 AM | #4 | |
982
Rep 1,797
05-31-2022, 10:35 AM | #6 | |
1540
Rep 2,008
And yes I'm at 3k miles now, did break in just under 1200 last week or so. |
05-31-2022, 11:06 AM | #7 |
5234
Rep 10,616
My car is tuned and gains boost or stays pretty steady (drop is slight if any) to redline in 3rd and 4th and 5th according to my data logs. For example, one log shows 5th gear, 6750 rpm, 145 mph, 22 psi.
That is what impresses me so much about this car - the way it keeps pulling at high speeds — over 100 (fastest I have been so far is an indicated 164). |
micvite1540.00 |
07-05-2022, 02:02 AM | #8 | |
1540
Rep 2,008
https://youtube.com/shorts/NhQm2PNke6s?feature=share https://youtube.com/shorts/NhQm2PNke6s?feature=share |
07-05-2022, 09:24 AM | #9 | |
3619
Rep 4,532
The factory gage is not very accurate based on our logs vs gage. |
11-23-2023, 11:41 AM | #10 | |
Rep 13
Did you ever figure this out? I have an M8 GC comp doing the same exact thing. 1-3rd seem okay, 4th higher RPM’s boost starts dropping off. 5th for sure is now between 16-17. I logged it using JB4 and scan tool and it’s confirmed. Even on Map 0 I got new plugs and dinan coil packs and it didn’t help. |
